Author Topic: Min/Max Temp times don't change  (Read 335 times)
Offline mikey1299
« on: May 05, 2022, 10:10:57 AM »
I am using WeatherCat to feed my website and the WCT_realtime.txt and WCTtags.php have updated data for yesterday and today's times of the min/max but they do no ever change in the display. Any suggestion on where to look or how to fix this?  Thanks.
Re: Min/Max Temp times don't change
« Reply #1 on: May 05, 2022, 12:05:54 PM »
What is the URL to your website.. I'll take a look.
Offline mikey1299
« Reply #2 on: May 05, 2022, 04:04:35 PM »
mrstiller.com
Looks like if I do a hard refresh it will sometimes change but no when it is doing the 60 second auto refresh. Other values will change then.
« Reply #3 on: May 05, 2022, 07:18:08 PM »
The values for the times in the Yesterday/Today min/max temperatures are all from WCTtags.php and reflect data in WeatherCat.
from your WCTtags.php?sce=dump shows
$WX['STAT:TEMPERATURE:MAX:TODAY'] = '62.0'; // Highest temperature today
$WX['STAT:TEMPERATURE:MAX:TODAY:TIME'] = '17:06:00'; // Time of highest temperature today
$WX['STAT:TEMPERATURE:MAX:YESTERDAY'] = '60.9'; // Highest temperature yesterday
$WX['STAT:TEMPERATURE:MAX:YESTERDAY:TIME'] = '17:18:00'; // Time of highest temperature yesterday
$WX['STAT:TEMPERATURE:MIN:TODAY'] = '39.2'; // Lowest temperature today
$WX['STAT:TEMPERATURE:MIN:TODAY:TIME'] = '06:00:00'; // Time of lowest temperature today
$WX['STAT:TEMPERATURE:MIN:YESTERDAY'] = '35.2'; // Lowest temperature yesterday
$WX['STAT:TEMPERATURE:MIN:YESTERDAY:TIME'] = '06:13:00'; // Time of lowest temperature yesterday
For the 24hr difference number display, it uses
$WX['STAT:TEMPERATURE:CURRENT'] = '59.6'; // Current Temperature
$WX['STAT:TEMPERATURE:24HRSAGO'] = '59.9'; // Current Temperature value 24 hours ago.
Only the Today min and max temperatures are updated by AJAX (ajaxWCTwx.js) from the WCT_realtime.txt file, otherwise all the data is from the uploaded WCTtags.php file.
