To be fair, we do not really know how either system does the sampling - or do we? They both *could* be using a sliding window for the gust speed and transmitting that every 1 or 2.5 seconds. However I doubt it.
So, with the one second sampling of the Ecowitt, are you taking a sliding average of the last three readings for the gust, or just using the peak? To be comparable with "standard" met data should it be the former? Is it still 20% higher than the Davis then?
The transmit intervalls to the console are stated in the specs: 2.5s on the VP2 and 16s on the WH65 (4.75s on the WS80). But the VP2 only sends one value and that is just the 2.5s wind value, no additional gust value unfortunately (at that price they could well equip their ISS with some cache/memory for faster gust sampling, just like the FO sensor array does).
And for the FO/Ecowitt Stations, as you can read in an earlier post, the Ecowitt Support confirmed the 1s sampling window. In their previous message i got they also statet it, as i asked them about the WH2310 vs WH65 readings:
The sensing timing is same: once per second it count up the wind pulses.
Well there is no possibility to generate a 3 second-in-a-row sliding average with the FO setup, as it dismisses the other values apart of 16s average wind and fastest 1s gust per 16second. To be comparable with standard met data it really depends how the met offices configured their sensor/measuring equpment too. In my country at least it is not 3 second but 1 second, so..
As i said: It depends on the gust duration, a long gust >5s will be accurately recorded with the VP2 in any case, a shorter than 2.5 second gust not, that's plain maths. But the difference wouldn't be 20% anymore. The - on average - 19% difference i observed at a measuring height of 2m above ground, where gusts can be especially shorter. But it still will be a few % sometimes, if you'd compare to a 3s floating average, because a 3s gust could be averaged to 5s if it falls in between two 2.5s samples. What I also compared is a 0.8s sampling 2m above ground (Windmaster2 hand anemometer) vs. the VP2 2.5s sampling 6m above ground, where the difference still is around 10 to 12% on average, even with the height advantage for the VP2.
But the WH65 tri-wing results seem to be a bit lower than the WH2310 and the Windmaster2, in my first comparison so far. Still figuring out why, could also be the rain cup being in the way or too close, depending on wind direction. In this forum someone compared the WS80 with the WS68 and got higher gust readings on the WS68, even though the WS80 already measures peaks better than the WH65. If only the WS68 would support the battery extension cord...
