Author Topic: WeeWX and Meteo-Pi-Ethernet Logger  (Read 3145 times)
Offline rcnz
« on: February 08, 2022, 01:19:30 PM »
Long-time fan of WeeWX.
Worked perfectly with my Meteo-Pi WiFiLogger.
I recently installed the Meteo-Pi-Ethernet Logger from the same vendor.
Because its output goes directly to several sites (WL/WU/WOW/CWOP), I'm seeking a way to continue using WeeWX to send data to WeatherCloud, AWEKAS and the other sites I fed via WeeWX
Has anyone tried it?
Could the MySQL feed be used?
« Last Edit: February 08, 2022, 02:02:53 PM by rcnz »
Davis Vantage Pro 2
WeeWX 4.10.2 | Meteo-Pi Ethernet Logger
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
https://www.wunderground.com/dashboard/pws/IAUCKLAN159
Offline gszlag
  • ..have you calibrated your barometer today?
Re: WeeWX and Meteo-Pi-Ethernet Logger
« Reply #1 on: February 08, 2022, 01:49:37 PM »
You can upload to many weather services and it works well.
WeeWX has built-in capability to upload to:
[[AWEKAS]]
[[CWOP]]
[[PWSweather]]
[[WOW]]
[[Wunderground]]
..and can be extended to a bunch of others:
    Meteo-Services
    OpenSenseMap
    openweathermap
    previmeteo
    weatherbug
    weathercloud
    wetter
    windfinder
    windguru
    windy
For the full list check out the weewx wiki:
https://github.com/weewx/weewx/wiki/
Ambient Weather WS-2000
Ecowitt WS3900 console
Ecowitt GW1000/GW1100
Ecowitt WS68: Anemometer, UV/solar
Ecowitt WH40: Rain gauge
Ecowitt WH57 Lightning sensor
Ecowitt WH32E: Outside T & H sensor
Stratus Rain Gauge (manual)
Raspberry Pi 3B+ (WeeWX/CumulusMX)
Raspberry Pi Zero 2W (WeeWX/MQTT/Belchertown)
Barometer wiki: http://meshka.eu/Ecowitt/dokuwiki/doku.php?id=barometer#barometer
http://weather.glenns.ca (pwsdashboard - live)
http://weewx.glenns.ca
http://glenns.ca/cumulusmx2/index.htm
Uploading to: AWN, ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW
Offline rcnz
« Reply #2 on: February 08, 2022, 02:00:38 PM »
Thanks, gszlag.
I was able to do all that with my Meteo-Pi WiFiLogger, which fed my VP2 data via WeeWX.
I probably asked the question the wrong way - because my logger feeds directly to the internet, its data bypass WeeWX. I'm trying to find a way to get data to WeeWX.
It has a MySQL output, but I have no knowledge there...
Davis Vantage Pro 2
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
Offline bahuga
    • Meteo-Sciez
« Reply #3 on: February 25, 2022, 11:06:01 AM »
....I'm trying to find a way to get data to WeeWX.
You will have to modify some parameters of the [Station] section of your weewx.conf  file.
If your WeeWX is configured right now for your Wifilogger,  you will have just to change the "host" line, so that the new IP address will be the one of your Meteo-Pi-Ethernet . Verify also that the "port" is 22222 and that the "type" is ethernet . See http://weewx.com/docs/usersguide.htm#[Vantage]
Finally, don't forget to stop ans restart Weewx so that these changes will be effective.
Davis Vantage Pro 2
http://meteo-sciez.fr
Offline rcnz
« Reply #4 on: March 02, 2022, 01:20:34 AM »
 [tup]
Very many thanks, bahuga. Everything fixed per your instructions.
My WeeWX setup was too modified to work properly with everything you suggested, so
Short version:
Saved weewx.conf
Uninstalled WeeWX
Installed 4.7.0
reconfigured the clean weewx.conf
Perfect! WXCloud still being awkward, but I'm very happy, thanks
Davis Vantage Pro 2
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
