Author Topic: Airlink  (Read 8403 times)
Offline drew1021
Airlink
« on: February 08, 2022, 10:03:18 AM »
I’m considering adding the Airlink to my VP2 suite and have a few questions for those who own one.
First, are there any replacement parts available such as temp/hum sensor, or is it integrated onto the pc board? Also I’m concerned about the internal fan reliability over time, is the fan available and user replaceable? Second, has anyone rigged up a solar charging system to power the device. Specs show the DC input to be 5Vdc. Davis offers a solar panel with battery that is rated at 6Vdc output, would this work?
Thanks for your assistance.
BTW tech support not any help.
VP2 with 24 hour FARS. WU: KNCLEWIS2. CWOP/APRS: DW4712, COCORAHS: NC-FR-7
Offline mcrossley
    • Wilmslow Astro
Re: Airlink
« Reply #1 on: February 08, 2022, 10:30:57 AM »
The T/H sensor is integral - I did not see a separate sensor when I have had it apart - it may even be integral to the sensor unit.
The fan is integral to the sensor unit (as all the consumer grade sensors I have seen are).
Mine has been installed outside since Nov. 2020, and - touch wood - no issues so far.
Sorry, but no idea on the solar panel.
Offline drew1021
Re: Airlink
« Reply #2 on: February 08, 2022, 11:44:17 AM »
I suspected that the sensor and fan were integrated onto the main pcb. That’s a shame. So sounds like there currently are no replacement parts available. I’m not going to purchase it knowing that it is most likely disposable. I typically replace my temp/hum sensor on my vp2 annually.
Offline mcrossley
    • Wilmslow Astro
Re: Airlink
« Reply #3 on: February 08, 2022, 11:56:45 AM »
Its not that they are on the circuit board, they are integral to the Plantower AQ sensor module itself, which is then part of the main board. I do not know of a consumer grade unit that does not use a integral third party sensor module (Plantower/Sensirion/Nova/whatever)
Offline drew1021
Re: Airlink
« Reply #4 on: February 08, 2022, 06:16:39 PM »
I’m curious if Davis will have flat rate repair/pm on the device.
Offline jon_iz
Re: Airlink
« Reply #5 on: October 17, 2023, 11:24:20 AM »
I've had an Airlink since they first came out.
Recently I've had two instances where it has stopped reporting and flatlined.
Gut feeling is the fan in the sensor may have started to stick.
Todays event has resulted in a blast of compressed air to wake it up.
However, while I've had it in pieces, i can confirm that you can remove the Plantower PMSA003 from the board easily - it's socketed.
They are also readily available from ebay or Aiexpress for under £20 - which is a lot cheaper than a new Airlink, or the spare component part sourced from one of the "Main outlets"
So, I'll order one to have ready at that price.
Offline Weerstation
    • Westland De Poel
Re: Airlink
« Reply #6 on: June 16, 2024, 03:55:35 PM »
My Airlink is completely dead.
Last week I had problems with stopping and resuming reporting.
Also no data for pm1, pm2.5 and pm10, 0.
Installed since January 25 2022.
Warranty expired.
Cost me over 200 euros and a new one will cost 229 euros these days.
Tried to reset but no more blue lights appearing.
Bummer
So you can just pull the plantower from it's socket, no soldering?
« Last Edit: June 16, 2024, 04:01:36 PM by Weerstation »
Offline jon_iz
Re: Airlink
« Reply #7 on: June 16, 2024, 06:58:44 PM »
So..
I still have the replacement.
I swapped it and still had intermittent operation, so put the original back.
The real fault with mine was the cheap and nasty switch mode PSU Davis supply. It was clearly not very well. While it was providing power to the Airlink, I suspect it was low, or noisy.
(ESP32's don't like dirty power)
I swapped it with another 5v 1A psu I had - an amazon kindle charger.
It's worked fine since.
Yes the PMSA003 just lifts off - make sure to pry it up vertically.
Offline Weerstation
    • Westland De Poel
Re: Airlink
« Reply #8 on: July 07, 2024, 12:21:34 PM »
 [tup]
Thank you so much for this great tip.
Ordered one from Aliexpress June 30th and arrived here July 7th.
14.40 Euros and free shipping.
Airlink is working again.  =D>
