Author Topic: PHP 8.1 and ajax-dashboard6.php - new deprecated notices  (Read 5618 times)
Offline cirrus
  • Kevin Hough
  • Davis Vantage Pro2 Plus
    • Gorge-East Weather
« on: January 19, 2022, 12:39:26 AM »
I just started seeing these notices, after doing todays Saratoga script updates:
Deprecated: Function strftime() is deprecated in /home/thedalle/public_html/altdash6/ajax-dashboard6.php on line 419
Deprecated: Function strftime() is deprecated in /home/thedalle/public_html/altdash6/ajax-dashboard6.php on line 420
Deprecated: Function strftime() is deprecated in /home/thedalle/public_html/altdash6/ajax-dashboard6.php on line 421
Deprecated: Function strftime() is deprecated in /home/thedalle/public_html/altdash6/ajax-dashboard6.php on line 425
ajax-dashboard6.php
lines 418 - 425:
strftime() is now deprecated with PHP 8.1 and will not work at all in a future PHP 9
I'm using @ for now to suppress those deprecated notices
if (!isset($avgmonthrain1) or $avgmonthrain1 == '') {
    $avgmonthrain1 = ${'avrain' . @strtolower(strftime("%b"))};
      if(isset(${'avsnow' . @strtolower(strftime("%b"))}) ) {
      $avgmonthsnow1 = ${'avsnow' . @strtolower(strftime("%b"))};
      } else {
         $avgmonthsno1  = 0;
    $avgmonthtemp1 = ${'avtemp' . @strtolower(strftime("%b"))};
Regards, Kevin
« Last Edit: January 19, 2022, 12:42:47 AM by cirrus »
Regards, --Kevin
Re: PHP 8.1 and ajax-dashboard6.php - new deprecated notices
« Reply #1 on: January 19, 2022, 11:50:28 AM »
Yes, I spotted that deprecation also as I'm rummaging through the scripts doing fixups for PHP 8.1.
I'm doing all my currently released standard scripts first, then I'll move on to the legacy ones I distribute from my site.
The strftime() issue will also happen on the mesonet-map and global-map scripts, and I'll have updates for them soon.
Offline cirrus
  • Kevin Hough
« Reply #2 on: January 19, 2022, 05:16:55 PM »
Sounds good, Ken.. Thank You [tup]
Best Regards, Kevin
Regards, --Kevin
Offline andro700
  • Chuck
    • Gobles Weather Page
« Reply #3 on: March 28, 2022, 02:43:29 PM »
Here is the errors I am getting since I updated to PHP 8.1. I have updated all of my saratoga  pages. I am running ajax-dashboard.
https://www.goblesweather.com/index.php
Fatal error: Uncaught Error: Undefined constant "month" in /home/goblesweather/www/www/AltAjaxDashboardConfig6.php:187 Stack trace: #0 /home/goblesweather/www/www/ajax-dashboard6.php(78): include_once() #1 /home/goblesweather/www/www/index.php(89): include_once('/home/gobleswea...') #2 {main} thrown in /home/goblesweather/www/www/AltAjaxDashboardConfig6.php on line 187
Deprecated: Directive 'allow_url_include' is deprecated in Unknown on line 0
« Reply #4 on: March 28, 2022, 02:51:41 PM »
Please post your AltAjaxDashboardConfig6.php as AltAjaxDashboardConfig6.txt here.. the errors are in that file.
Offline andro700
  • Chuck
« Reply #5 on: March 28, 2022, 02:55:26 PM »
Here you go Ken. I have several errors on different pages I have to look into as well.
« Reply #6 on: March 28, 2022, 03:26:51 PM »
Change
$month = $today[month];
$day = $today[mday];
to
$month = $today['month'];
$day = $today['mday'];
For the
.. that may be in another script (as an ini_set('allow_url_include','1'); ) or may be lurking in your .htaccess file .. I suspect the latter since loading https://www.goblesweather.com/Settings.php shows the error message (and it shouldn't show anything but a blank/zero content page).  Check .htaccess file for that.
Offline andro700
  • Chuck
« Reply #7 on: March 28, 2022, 05:29:09 PM »
Looks like I have some work to do to get my pages php 8.1 compliant. Thanks for the fix.
Chuck
Offline andro700
  • Chuck
« Reply #8 on: March 29, 2022, 04:06:17 PM »
Here are the errors on my ajax-dashboard6.php that are showing up on my main page.
Deprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 240
Deprecated: substr(): Passing null to parameter #1 ($string) of type string is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 289
Deprecated: Function strftime() is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 327
Deprecated: Function strftime() is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 328
Deprecated: Function strftime() is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 329
Here is another fatal error on the page.
Fatal error: Uncaught Error: Attempt to assign property "date" on null in /home/goblesweather/www/www/ajax-dashboard6.php:3238 Stack trace: #0 /home/goblesweather/www/www/ajax-dashboard6.php(1212): getMoonInfo() #1 /home/goblesweather/www/www/index.php(89): include_once('/home/gobleswea...') #2 {main} thrown in /home/goblesweather/www/www/ajax-dashboard6.php on line 3238
Wish I knew how to fix the errors. I hate to keep on asking for help.
Chuck
« Reply #9 on: March 29, 2022, 04:20:03 PM »
You seem to be running Version 6.95c - 19-Apr-2019 of the alt-ajaxdashboard6.php.
Try downloading 6.95e which is fixed for PHP8.1 (https://saratoga-weather.org/legacy-scripts/AltAjaxDashboard695e.zip)
It's likely easier to install and customize the new version than to find all the errors I'd fixed in the old version :)
Offline andro700
  • Chuck
« Reply #10 on: March 29, 2022, 05:02:16 PM »
Sorry did not realize there was a new version of the dashboard. I will download it and edit it it as needed.
Chuck
Offline andro700
  • Chuck
« Reply #11 on: March 30, 2022, 03:13:55 PM »
I updated to 6.95e. I have a couple of issues. First trying to find the current conditions. It is showing png as my image but should be jpg. Cannot find where to change that setting.
The next thing is deprecated errors under in my tides section under ajaxdashboard6.php script.
Warning: Undefined array key 2 in /home/goblesweather/www/www/ajax-dashboard6.php on line 3592
Deprecated: substr(): Passing null to parameter #1 ($string) of type string is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 3592
Warning: Undefined array key 2 in /home/goblesweather/www/www/ajax-dashboard6.php on line 3593
Deprecated: substr(): Passing null to parameter #1 ($string) of type string is deprecated in /home/goblesweather/www/www/ajax-dashboard6.php on line 3593
Warning: Undefined variable $string in /home/goblesweather/www/www/ajax-dashboard6.php on line 3649
Here is the link to my homepage.
https://goblesweather.com/
« Reply #12 on: March 30, 2022, 06:42:06 PM »
It's likely that the tide data is not being found and that's why the messages about 3592/3593 lines are happening.  I don't use/have the tide data, so I can't help with that other than to have you shut off the messages by changing
#error_reporting(E_ALL ^ E_NOTICE ^ E_WARNING);
error_reporting(E_ALL);
ini_set('display_errors','1');
to
error_reporting(E_ALL ^ E_NOTICE ^ E_WARNING ^ E_DEPRECATED);
#error_reporting(E_ALL);
For the 3649 error, change
function time_till_tide($time) {
    // takes a time diff like 6740 secs and formats to '1 hour, 52 minutes'
    $hrs = (int) intval($time / 3600);
to
    $string = '';
Offline hcorrin
    • Ballaugh Weather
« Reply #13 on: March 31, 2022, 06:33:33 PM »
hi
just tried a test version https://www.hc-iom.co.uk/WD-AJAX3/index.php and got these errors note still using 7.4 PHP
at top of page
Notice: A non well formed numeric value encountered in /home/storage/129/3316129/user/htdocs/WD-AJAX3/ajax-dashboard6.php on line 480
Notice: A non well formed numeric value encountered in /home/storage/129/3316129/user/htdocs/WD-AJAX3/ajax-dashboard6.php on line 481
Tide section gives similar numbers as already posted
i have added the amendment already posted so the other error went
Daytime Records
 Notice: Undefined variable: rtemp in /home/storage/129/3316129/user/htdocs/WD-AJAX3/ajax-dashboard6.php on line 3003
Notice: Undefined variable: rtfdate in /home/storage/129/3316129/user/htdocs/WD-AJAX3/ajax-dashboard6.php on line 3003
NaNC
NaNC
Nitetime Records
NaNC
NaNC
if the error lines are swapped the errors disappear but the daytime nighttime records give NaNC
have left with full errors for time being
« Last Edit: March 31, 2022, 06:36:25 PM by hcorrin »
« Reply #14 on: March 31, 2022, 09:13:39 PM »
hi
at top of page
Daytime Records
NaNC
NaNC
Nitetime Records
NaNC
NaNC
I think the 480/481 errata are caused by having the units be in testtags.php for
$dayrn =  '  0.0 mm';    // today's rain
$monthrn =  '0.0 mm';    // rain so far this month
$yearrn =  '215.8 mm';    // rain so far this year
  you can fix that by either turning off the units in WD or changing the lines from
  $rndiff = $monthrn - $avgmonthrain1; // calculate difference in rain vs avg
  $rndiff_mtd = $monthrn - $avg_mtd_rain; // calculate difference in rain vs avg month-to-date
to
  $rndiff = strip_units($monthrn) - $avgmonthrain1; // calculate difference in rain vs avg
  $rndiff_mtd = strip_units($monthrn) - $avg_mtd_rain; // calculate difference in rain vs avg month-to-date
The ones for 3003 are likely a failure of the regex to parse your data from testtags.  The regex
    if(preg_match('!^([\-\.\d]+)\s*([F|C])\s+on:\s+(.*)$!',$rtfdata,$M)) { is expecting something like mine:
$mcoldestdayonrecord = '50.9F  on: Mar 05 2022';
$mcoldestnightonrecord = '41.5F  on: Mar 06 2022';
and what it is getting from your testtags.php is
$mcoldestdayonrecord = '50.0°C  on: 31 Mar 2022';
$mcoldestnightonrecord = '50.0°C  on: 06 Mar 2022';
which fails the parsing due to the (unexpected) '°'.
Change the regex to be
    if(preg_match('!^([\-\.\d]+).*([F|C])\s+on:\s+(.*)$!',$rtfdata,$M)) { and it will likely work with your data.
Offline andro700
  • Chuck
« Reply #15 on: April 01, 2022, 01:27:28 PM »
My condition icon is pointing to png. All the settings I see are jpg. Trying to figure out where to find why it is showing png. Also my temps have decimal points on my main page.
Chuck
« Reply #16 on: April 01, 2022, 03:20:43 PM »
In your Settings.php, you have
$SITE['fcsticonstype']= '.png'; and that is also set for the conditions icon.
Change it back to
$SITE['fcsticonstype']= '.jpg'; or, if you want to keep the large icons for the forecast, then change ajax-dashboard6.php
if (isset($SITE['fcsticonstype']))  { $condIconType = $SITE['fcsticonstype']; }
to
# if (isset($SITE['fcsticonstype']))  { $condIconType = $SITE['fcsticonstype']; }
to avoid the override by Settings.php.
The temperature data from testtags.php has one decimal point -- you need to leave that so the Metric/Imperial display switch with JavaScript will correctly change the values as appropriate.
« Last Edit: April 01, 2022, 03:23:27 PM by saratogaWX »
Offline hcorrin
    • Ballaugh Weather
« Reply #17 on: April 01, 2022, 05:10:59 PM »
Hi
thanks Ken those mods have sorted the errors described
Harold
Offline andro700
  • Chuck
« Reply #18 on: April 06, 2022, 12:44:45 PM »
Seems like the DualImage I am getting intermittent issue with the icons. You can see it on my main page and my NOAA forecast page.
When you right click on the broken icon and open in a new tab here is what it shows.
Deprecated: Implicit conversion from float 21.5 to int loses precision in /home/goblesweather/www/www/DualImage.php on line 498
Warning: Cannot modify header information - headers already sent by (output started at /home/goblesweather/www/www/DualImage.php:498) in /home/goblesweather/www/www/DualImage.php on line 345
PNG  IHDRVV4  pHYs+ IDATxeٲeIr=b};ͩ*z@bh2 "e0@?7d'@ %졺+;p_|}7OٵN{·V}rZj;;߬RRU"e'RR]&* jD{eVKA ԔO/pxͫ1"$\گHA !( ( @@A :SR= j AS X92!>MsgKɴD IyqBg2ږ&DH HvBۿI %"S)w8LSgJrES7{]]^`tO4q#Kjj@™x'ӷ^<򋏲C= B@*FCR>!%h "Cj@AR @ V"ED 0Pŝ_{dz *}0&ݫ"7Sy߼KI9X)\: GZ@D@a\qxiႀjfTn?Ci]!BEbApvTZ ZKE#ԺA7P D0%Rڶ [VBa i2 M*%ԉL>M֙F6 C)VF0"BB5c+$$\CDRT# Rʓi#q'P!&ȶV!`m2biqh/LA^~\&fMr6h&**%T@p Sx /UZ#+7ZrAhdЪ!@CQC? i]b!hmݥ(}׭Zj,"rAU(B%)B< UUUTK:G<>۷Q*PE ֫4X P$.fI_6΁QՁ)iިLjLru @52O4T!tf)VBT5j  T*;[ _~˗v1 05#o>PʥjaͷLeyНZ V1gRZ?j+mws),{G N.G IJ"*RHIDfYoj-'G<ڔӣi!"R!\@ n<%E2"dȡfٜӸߏut XU뢺- *ʹW']}Z9wz}{~ǃJ< 1Э> ǐRIa؇rC`5l @ ARBgv#ʹw[J< IU<ڧh0pUh2QЏj3T,<՛Ͽ=YfF  6?q*߯@hYmzS-f- @Iތ7`43Kf)u9'U2XD5Y~_=@ ~urRJl{ qw7dw A_! @h"J02(IJHØKćKaMx;Mc8,u˹[ $uК64)A nw{s]BJ]QkyM^щʭcuA!<�e@Be,/3*k2>z+* Lڈi-^q ?z=>:$U')2g+KQ#xG7f8yZ~0?{ۛ U`FxDm@SڬW9Ό"1j)>X (]f(f"-Z{Z< *L&k%U%Mn'OonooKӧV4"R Y)D[=jS^o۞,fOv9y>-M("" 0_P0Ü7+TM_P P,%SѽsQI)=x:^^ߜ=|fl<ĮJ)6S)~,??C͖DUI "RbIIB\m'6 ﺮ=wj5 }7s)"/d2ON Y@dbFDu-j( D{S|LJï D,pQB 8QiO~A> "J Zo[55nw_}WO޽{Kْʁ0]RirǴo=JqvmTM}: e6H@6jؒ? 3;aN²), 'x>>Yo>|̎GϞO.޿۬z{qn~ۈpNQ*,a]Ҿ}C 7K30U~t֯ $ #VB0DP`ЖmtaQY?PFFrʢ^o?g]o_^^<'f&*r}}R/NoqߌDBf֙&I4.uf}w#T< iI "QQ="E:I1IrkT~%$,qm1D*fjfz:^S>:;nn֝;N}DTY&";joGFYE-xw#@73HiB)S, Kff/NNN~Ϟ}O>d|Q-EUOONizExn.MJs76MĐه{Ο<͛jyXɝ苧ZL{U(* 8}ECgj:=D žˢTXj"iJzu_|7~_iy..sJg9MjǽuDT.ê Bu^8OHn<͝fVx?yð+BD8i<,#jxE*02UQ BXD  cAq$wokj=|믿:=9ۛ-/lWk*8*f-R::: 9/w']ҌD 6"-MA\:4$-5jDO@ L PmHRLãJL =iٞlO^zy|tߖ nf 5ss2Du8^ojuqqy~AJ|QL5QBMp(n^7t EI&QIIDETe&S?Dx ҖnɌ@iZYJ**޾yۓӣI)~؏?mܕ%t蓼=laUkSzuNTY-rPMBW㕕<3H0YJː,*Q D4ZGa) ɡr<o뜻~'0iZ89PU uy$Ӳ䢪U"@UC+RЙ3YTԈZI8i N`v5i" o N  R6TuV/~_Eaj}NA?M>[9td4ZCIkV~Z=xom,uxÔjdn3vDjPEBƛc&"AatR0(>mE G296uw}MYՄ܏Z&Qo~UjmeXZ D4 4sxǜqv!PLCV0@0*BCJ&Q~hF8V'0AKҨ'8I -AnĘ;aW*WyB#*ADPU圳(TuO R`Nݰn_|1n<xt2VOB*agX=@ x! *DĚ]gi׍wm*"NkQSMf Jr|T"6^7f &@?g £EUe N"i8VJcV*D"C H""Q"TN($ ""H"P(y&.|4=Ax]׭VarJj*uF 3QB-C0Oypy{yy7 PPEU{fp00|Y#`\J$Pp NTEJM43. "w@DLoUxkp$TU33Snt9L/Dk RE  EEZFPd@l<ט% ־ "6:  d kJ)'S[\7 bE-؃8^]_z."*D*h[dDHpa5%0\6B=gl% hd8H:5+f^hW- obQN/ӛzJ![ k.q!jE ń QBD)S `B I h$2U 5~rizh6gh[&q xm4~DU!_v7S(  w4]"T(AfJAhP 6,-ltYVi`p4)6MJuԯVFah<@?Hڊ # ,4I4Ͽ/^z7_ޮ7|$#a jYjqajT, z׺ IQ& HxbYm qh,4DWFt.j2SuP!>==}蓃v7tکde&.-MZرP8 )"EDՖ LA¶T2)j)XՒ^cKs)K F h 68{۷r>1iuv&RLT4=Ąb,dx$LB&*ĩ h>9VYDgP"$A  &ýFTzEPu RYWׯDϻMn>j\L}fVVIN#45~Չ`WlD8HʈKq'@P#NZrL%.wd7lZp"8PvglS8\_FL%|J(N&a ECf#J.l r J J! ?umHWC33۷ԭ֭ZˆF +VjBQ4fj?8 6CIJEm6=zRt9{s(`-(}+,ݴog?͟ ǫ0??wv9>>>΂>+D1J9#,b,j̸򃉊T +?4$9L/|ff{}y9l9w*Z")#RRK^K*"fZ~jY 6<`{ǟ<~XowǏxWwsL#%D \AJL-Fg,}Dz8.0P\N is)(uٞ"gGg~P3lؗaiKF<8?y~?L1уp?w)w XJt]9]}tjU*E$¨/>6 !ԈXBq ,Ktd;LA RH }g'.  Anv:ʹﻇv]=>NM C-׿<_|fyٽ"oNDPD mhSśʂTb(sDf*XH^XD[H@D[_O~wwnon~XmƛҩO7om2pWo/Gz^?}g"'?ϦyLj}<ߵ[Tz%K֌429Sh46& edy6υ/Vtºi*|1?{Nvߌwn7OMߥG=rWJ˙Wo_/<D;K]_M)OӇw㓓> )^DP УӘD%B`$d,Velm4!Ha oC(\_GOٳo^df׏M=z=M?nvRǥ(Gd=nݬշ}^ ]=>a!!¨^HtMd&4"biAmqoIA`q'%Fyͺ/N}?8vR)H~ԪZA=nӽ4_hݻw9jHɂ軼^Ǐ?&E!Zh%/BܛPN?0$!d4Pdr!4K<"(!fyG>y-Wx=$ZoiM3nX+PQ!<>):xG^>s?V)m.`V:!KJ5.Vp4OFiZB%zj _UNR IDAT~ވfRIΆM.q)+-@Ta5M^uڕ25\&faeRq_^LӞΒ%#'O?ZX^62)R"D5A)NkHhLD,U3 Eu)m@#@$wYUXcd 囬t8Mh  )%53MB^]_WS겈Xd}w]?/޿W.2 j &ШTT kj!II"P8E"5Qdh1aBxII$ZvDQ Dfv9w 2Vurl'{$27_\0f?z!M@4f\N>Q EZ7Q.|UdhhPqPഝfRӺ׫˿zWu Y$M)Jaʪ_xڭvTӪlS9W߿)%!K)NbhV 7 ]E"yhҺD;6?[m\&(jy^i6I.j;V}o˚Vj_?r CzV˖%l $LҾrbfթƙO nI@]M8|NY"Mn!?5x`P2Di{>?+Vy6[w=MP:ك'/7'?/zXHLj2Abʄ;r]?NWXH8AK4NAT05XqKO QdB[mAG &HG'~ԣ'?zxuUdWIPꋟ_ٍrh?z=w,.%5 aTkɑE[ f * gЃ)~ שM4pqbI6P d Gbvx7=1N|Tˊ}?MEe4l{o ]doA-*EЮHi}JT{Q>) UeݱDMQ[6U Uy@(`4d۔xt"?^':XׯWկɘ@T,Rr@!f!M)0'zex3#C{ `;B"!AqBfh֘eoG^$ӺVETۀE*sL)?>=/nw#爀wɶ t@""H*jK[" ܵX(cZ8!(ApG Sa,YCr-* 2uݪ?ł&&]Hu=jP ܓkKiL3xI49 k%;Y* ~<uNpy0/]:D.,hd'#Pp  iZ9T)m`ҵVzZ˦l52.;;לq)Emfc셐0RU! a6:#t/1w!K7ëTB2vˍ]pASEk*0S6 7M -c?hHIC0|?8fbV]κR͔B4&TI)u>x3)x9w'?|ݷexRՋ_$uQi*4 J2$!u=T4є7% 'sN]ʤQzaHB.Y)9t8w6Oe}L, "ڧ{* H D-%Znwxf)t'"193:VQ5b,FX-8ēx Fe-jaDQ} AL ATTNh8I-H:;RYȔDm>:"*e4Hfbt!on.)?v$pݬ%e{Tq/`H(:ND7RSSM>VDTJ^gMd`ܯ)F5Zu,k mw6W(@44TRˣ,4q'wr>.'ߤns'AtL=d}ԋ '\&nt]ojЌi1eIfZܳR,z̦ Y-ۂ留KhR p0|1 &dB8f?߬bUȤ)($T慩5I8rO65Ba ]v J G^WSl<V㤳^՘">vOhCF/j=J'(Dzz6供Uje`.MZ̋R{nd`8:+ei,mV- Z ] ˄f`lW ڢk]zp0F-u ):)7|˓̕\ɮ{ث?8-QKkATHdѤo}|8!#o˻9:RשƛlvH;%Z\RANr bNV $9X5.]HzRڭ=i>9;wt:rPFw;kXTۇi!NZuUg5anV /5ޑ̓87V AIENDB`
« Reply #19 on: April 06, 2022, 01:29:17 PM »
Ahh.. PHP 8.1 is a gift that keeps on giving (Deprecated errata).
Download from here and try it (V1.04)
Offline andro700
  • Chuck
« Reply #20 on: April 06, 2022, 01:41:55 PM »
It worked. Will keep an eye on it. Yea 8.1 is a constant work in progress. JPgraph is half working with PHP 8.1. There is a version 10 of JPgraph out there. I have it running on my server. Mostly the Rain, Windspeed, Barometer graphs are not working. Will post it on JPgraph thread.
Chuck
« Reply #21 on: April 06, 2022, 01:50:39 PM »
Great.. I've pushed the change to the Base-USA distribution.  Keep me posted if more strangeness shows up :)
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #22 on: April 06, 2022, 01:59:02 PM »
What version of JPGraph are you using?
I have  v4.3.1.
http://cvweather.org/wxgraphs/wxgraphs_test.html and http://cvweather.org/wxastronomy.php
do not work with PHP 8.1
I reverted back to PHP 7.4 to test and they run OK.
Ed
Offline andro700
  • Chuck
« Reply #23 on: April 06, 2022, 02:16:37 PM »
I have version 10.4. Here is the link. https://github.com/mitoteam/jpgraph. I am starting a thread on Weather-Watch. But here is a link to my jpgraph test page and you can see the Windspeed, Barometer, and Rain graphs are broken.
Chuck
Offline ed2kayak
  • Ed
« Reply #24 on: April 06, 2022, 02:18:24 PM »
Thanks, I'll check it out.
Ed
