Author Topic: Connecting to MyAcurite  (Read 460 times)
Offline only2goats
« on: January 14, 2022, 10:13:29 AM »
Greetings,
I have an Acurite #01516 with a 5 in 1 sensor.  It's connected to my home network, receives data from the 5 in 1 sensor, and is connected to Weather Underground.  However, I cannot seem to get it to connect to the MyAcurite mobile app or either the PC Connect app or the My Acurite website.  I'm using the correct device ID, but none of these apps will detect the device.  I've removed the batteries and power cord and reset the device 2 or 3 times.  What am I missing here?
Thanks in advance for any help on this.
Steve
Offline worachj
  • Twin Cities, Minnesota
Re: Connecting to MyAcurite
« Reply #1 on: January 14, 2022, 11:56:52 AM »
Is this the display that came with your bundle?  If so, it’s not a “Direct” connect to Wi-Fi device and only sends data to Weather Underground.
https://www.acurite.com/shop-all/weather-instruments/weather-sensors-and-parts/displays/wi-fi-display-for-5-in-1-sensor.html?ref=name
https://support.acurite.com/hc/en-us/articles/360021588833-Add-a-Connection-Device-to-My-AcuRite-
To monitor and view your AcuRite sensor readings from My AcuRite®, your AcuRite Access®, PC Connect Display, or Direct to Wi-Fi Display (Connection Device) must be added to your account. Once added, you can then link your AcuRite sensors to the AcuRite Access®, PC Connect Display, or Direct to Wi-Fi Display - allowing the readings to be sent to your Dashboard.
Direct to Wi-Fi Display Units Compatible with both My AcuRite® and Weather Underground
https://support.acurite.com/hc/en-us/articles/1260802415529-Direct-to-Wi-Fi-Display-Units-Compatible-with-both-My-AcuRite-and-Weather-Underground
AcuRite Atlas
KMNSAINT173
Offline only2goats
« Reply #2 on: January 14, 2022, 12:07:47 PM »
Thank you.  I guess that explains it.  I would have to spend another $99 to get the Direct to Wi-Fi Display to replace the one that came with the unit.
I appreciate the response.
Offline worachj
« Reply #3 on: January 14, 2022, 12:16:52 PM »
Or purchase an Access where you can monitor up to seven compatible sensors(Iris is compatible) on MyAcuRite.
https://www.acurite.com/shop-all/weather-instruments/weather-sensors-and-parts/displays/access-my-acurite-remote-monitoring.html
AcuRite Atlas
KMNSAINT173
