Author Topic: Meteo-Pi Ethernet WU Key problem  (Read 240 times)
Offline rcnz
« on: January 09, 2022, 10:32:54 PM »
Greetings.
Very excited to install my new Ethernet logger.
It's exporting to WL, WOW and CWOP, but WU isn't working.
I read all of this: https://www.wxforum.net/index.php?topic=36260.msg374636#msg374636
Then pasted the Key from my WU Member Settings page = no joy.
Previously uploaded via my WFL/WeeWX setup, so never used/needed a key before.
Thanks for any advice!
Robin..
(I've tried the "Enable" and "RapidFire" drop-down options).
Davis Vantage Pro 2
WeeWX 4.7.0 | Meteo-Pi Ethernet Logger
AWEKAS
CWOP
PWS Weather
WeatherCloud*
Windy
WL
WU
* = awaiting fix
https://www.wunderground.com/dashboard/pws/IAUCKLAN159
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • Living in the "Last American Frontier"
Re: Meteo-Pi Ethernet WU Key problem
« Reply #1 on: January 10, 2022, 02:47:29 AM »
Your WU key should be 8 characters. If you log in to your WU station page, go to My Profile then my devices and you will see your station key. Do not use the API key tab. You should also have received this key when you first signed up for WU. Another note type in directly do not C&P, this can add unwanted spaces.
« Last Edit: January 10, 2022, 02:53:30 AM by Weatheroger »
Offline rcnz
« Reply #2 on: January 10, 2022, 04:33:41 AM »
Thank you SO much!
Breakdown of understanding at my end.
 [tup]
Davis Vantage Pro 2
AWEKAS
CWOP
PWS Weather
WeatherCloud*
Windy
WL
WU
* = awaiting fix
