Posted this in another thread
https://www.wxforum.net/index.php?topic=44811.msg455005#msg455005 if it helps anyone then all good:
Initial 7 day review of Wittboy station...
IntroductionIt has been 7 days since my Wittboy (WS90 + GW2000) has been running now, thought I would note down some initial feedback. I have owned a couple of basic fine offset weather stations over the years, the odd wireless rain gauge and cheap wireless temperature sensors!
HistoryHave admired the Davis VP2 Pro for many years, but, in the UK it would be around £600-800 for this setup, likely £1100+ for solar/UV bundle. For me that is a lot of money on a weather station. Now and again I have glanced at options on Amazon but nothing too much seemed to change. In December this year I stumbled on the Ecowitt brand, fast forward to the Wittboy mega thread and a WS90 combo was ordered.
Setup and build qualitySetup was a breeze, Energizer Lithium AA's inserted, some silicone grease on the rubber seal just in case. Upgraded firmware via USB and screwed onto the pole, job done. The GW2000 connection was painless also, done in about 2-3 minutes, all set and reading data from the WS90. The WS90 seems pretty solid to me, I have engineering background and am pretty critical! the GW2000 looks a bit 'cheap' in comparison but works as intended.
I spent some time looking over the ecowitt.net site, similar the iOS app, all seemed OK, main text on the app and website seemed a bit small, not so graphical but functional and with history.Days passed and I played with CumulusMX again, looked into Smartmixin app, was a little frustrated the Ecowitt app didn't update realtime (8.8 seconds) but hope that will come with time. Generally the data available is great,graphs are well laid out, no problem.
Rain and Wind readingsSadly I don't have much to compare accuracy against, manual rain gauge and that is it, generally the rain seems pretty close, I have tuned gain a bit, not much, tracks so far pretty good with the manual gauge. I suspect light rain is going to be the area for concern, also heavy dew potentially, but, lets see how that goes. Wind seems fine, I suspect maybe under reading a bit compared to what my eye's see but close enough when compared to very local weather stations, better in the sense it picks up the low strength winds which they often miss.
Solar and UVNow I like seeing the solar and UV, OK, maybe they aren't calibrated as such but it is nice to see, gives me an idea of what is going on, also good to link this with capacitor charge and voltage. Can easily see if it has been a real dull day or if the sun has been out for several hours, not essential but it was on my list if the Davis ever happened!
Voltage readingsHaving access to voltage for AA's and capacitor, plus soil moisture or other sensors is also useful, I added a soil moisture because, well, why not, they cost less than a good meal out and around 10x less than a Davis equivalent. It works in line with rainfall, after a dry day the moisture drops from maybe 68% to 62%, so you assume it is working as intended. This should prove interesting in summer when ground really dries out.
Temperature, humidity and accuracyTemperature accuracy I cannot say too much, I cross check various readings with local Fine Offset station and not quite so local Davis VP2's and they are close enough for me, within +/- 1 degree essentially, often less. Similar for humidity but this can be maybe a little more out. I have a WH32EP sensor awaiting install into a stevenson style shield, this should I hope cover that area pretty well for accuracy, also the height above ground will be addressed.
ConclusionIn conclusion I am pretty happy overall, I paid around £200 for the setup, soil moisture was £20 and WH32EP £55. My biggest concern is whether the setup will still be running in 2 years time, I hope so. In the meantime I like the fact it has no moving parts, a lot, accessing the data is easy, I've got an old iPad Mini acting as console for now, in general, it is nice to have a weather station running again. Hope that this might be useful for someone, this forum has been such a help for me while researching, contributors spend a lot of time testing and it is appreciated.
