Author Topic: Utility to get encoder information about a video file  (Read 321 times)
Offline DaleReid
    • Weather at Eau Claire, WI
« on: December 05, 2021, 05:58:53 PM »
Years ago there was a neat little utlity called GSpot (yeah it makes for some interesting hits on Google when you look it up without the modifier 'encoder', that would be able to analyze a video file and tell you tons of stuff about the file, like the encoder used for video and audio, the bit rate, and on and on.
Like all good things, that came to and end when the developer stopped updating back in 2007.
Are there any current programs which can tell you the encoders used?
Thanks for any leads.  Dale
ECWx.info
ECWx.info/t/index.php
Offline Bashy
  • brecklandweather.com/pws2021
    • Breckland Weather
Re: Utility to get encoder information about a video file
« Reply #1 on: December 05, 2021, 08:54:14 PM »
How about here https://www.metadata2go.com/ this tells you no end about a video, codecs etc, just tried it, there's a lot of info
Kind regards
Bashy
Offline DaleReid
« Reply #2 on: December 05, 2021, 10:57:26 PM »
Thanks a bunch.  I will try it soon, got another project right now.
thanks again.  The collective experience and knowledge of this group is always impressive. Dale
ECWx.info
Offline Bashy
    • Breckland Weather
« Reply #3 on: December 05, 2021, 11:10:21 PM »
No probs, hope it helps :)
Kind regards
Bashy
Offline jimi
    • Well Road Weather
« Reply #4 on: December 06, 2021, 05:07:52 AM »
Open the file in VLC and select video info  ;)
Black is not a colour ! .... Its the absence of colour
Offline Bashy
    • Breckland Weather
« Reply #5 on: December 06, 2021, 07:49:23 AM »
Just looking at one of my videos in VLC and it's quite limited to what it shows, it does, however, show the codec used and i assume that that is what Dale is after, see the image attacthed?
That link i put up, i found it on google this morning and the amount of info it shows is vast, probably useless mind but i have enclosed a PDF of what it comes up with for the same video
Kind regards
Bashy
