Author Topic: ALERT: Changes Begin  (Read 6908 times)
Offline NWROrg Team
  • Save A Life
  • Moderator
    • NOAA All Hazards Weather Radio
« on: December 02, 2021, 12:26:32 PM »
As noted in previous messages, website notifications, and audio track alerts, station listing upgrades have begun.
Effective immediately, NO new streams will be accepted that are NOT from the WxRadio.org secure server.
SOME 'third party' or 'self-hosted' SSL servers MAY be accepted as 'alternates' if the provider has a  primary stream to wxradio.org
NOAAWeatherRadio.org continues to be YOUR community project, but it needs your continuing support.
The Following Streams have been removed as of 8 am 12/02/2021, having failed >100 consecutive hourly availability tests.
If your stream is 'wxradio.org', simply submit https://noaaweatherradio.org/addstream/addstream.html with the information, and note that you have reactivated the feed.
If your stream is 'other', you must first configure your encoder to wxradio.org per the instructions at https://noaaweatherradio.org/howto.html and following those specific protocols.
Use https://noaaweatherradio.org/N2radio-finder.php to help determine how your mountpoint should be named.
The few remaining NON-SSL streams will be removed today.  Third party streams are subject to removal at any time, if there is NO wxradio.org primary stream, and not all third party servers will be considered for alternates.  Self-hosted SSL encoders should also provide a stream to wxradio.org as soon as possible.
All streams must follow the naming protocol at https://noaaweatherradio.org/howto.html
For questions or inquiries, please use  https://noaaweatherradio.org/addstream/addstream.html
« Last Edit: December 03, 2021, 12:03:20 PM by NWROrg Team »
Offline NWROrg Team
  • Save A Life
  • Moderator
Re: ALERT: Changes Begin
« Reply #1 on: December 03, 2021, 11:43:19 AM »
NON WxRADIO.org streams
As mentioned, effective immediately NEW or UPDATED streams will only be accepted from the primary wxradio.org server.
The below streams are pointed at servers OTHER than wxradio.org.
Most are using the obsolete non-https wxradio.dyndns server and their SSL stream version is obtained through third party re-streamers.
In some cases there may be usage infringements. MOST third party sources are vulnerable to removal without notice, especially commercial sites.
Note that some specific third party hosts may remain as a secondary, or alternate, if a primary is pointed to wxradio.org.
Note that the original wxradio.dyndns server is now considered 'third party'.
#before call letters  indicates currently de-listed
This does not affect most 'self-hosted' ssl streams, though you should also encode to wxradio.org as the primary.
There may be listing errors in the above, apologies if so. :-(
Please check, and if your stream encoder is NOT pointed to wxradio.org please modify that ASAP following the protocols here
https://noaaweatherradio.org/howto.html#golive
Submit updates / changes ASAP using https://noaaweatherradio.org/addstream/addstream.html
Check for correct mountpoint at https://noaaweatherradio.org/N2radio-finder.php
If your weather website has changed to HTTPS, please include in comments on the change form, so we can update those... most remain http in listing.
« Last Edit: December 03, 2021, 11:57:18 AM by NWROrg Team »
