Author Topic: WeatherCloud device "Unlinked"  (Read 738 times)
Offline rcnz
« on: November 28, 2021, 06:10:49 PM »
Pi 4 32 GB, Meteo-Pi;  Vantage Pro2
WC ran perfectly in WeeWX 3.9.2 (Logger was WFL)
Recently upgraded to 4.5.1; changed from WFL to Meteo-Pi
Removed WeeWX, Python 2 (reinstalled Python 3); reinstalled WeeWX via setup.py
Reinstated weewx.conf site outputs via pastes from previous weewx.conf
WU came straight up, RF fine.
Debug = 2,
Got CWOP, PWS Weather, AWEKAS, Windy, WOW all going.
Debug = 1,
WC showed previous Device now as "Unlinked". (Has never been seen in syslog, any WeeWX version AFAIK)
Deleted WC Device
Created new WC Device
From mail:
"The link details for your device KauriPoint are provided below:
Weathercloud ID
dc7d9a32ec7a1f4f
Key
3af03a5b2STUFF0b8713b489e586
https://app.weathercloud.net/d6691990330#profile
Linking instructions followed to the letter:
Download last extension file (weewx-wcloud-0.11.tgz)
Run the extension installer as follows:
wee_extension --install weewx-wcloud-x.y.tgz
wee_extension --install /home/pi/Downloads/weewx-wcloud-0.11.tgz
pi@wxpi4:/home/weewx/bin $ wee_extension --install /home/pi/Downloads/weewx-wcloud-0.11.tgz
Request to install '/home/pi/Downloads/weewx-wcloud-0.11.tgz'
Extracting from tar archive /home/pi/Downloads/weewx-wcloud-0.11.tgz
Saving installer file to /home/weewx/bin/user/installer/wcloud
Saved configuration dictionary. Backup copy at /home/weewx/weewx.conf.20211128123237
Finished installing extension '/home/pi/Downloads/weewx-wcloud-0.11.tgz'
pi@wxpi4:/home/weewx/bin $ sudo /etc/init.d/weewx restart
[ ok ] Restarting weewx (via systemctl): weewx.service.
Several restarts, with zero debug ERROR or CRITICAL syslog messages; typical 30-minutes' syslog entries attached. (N.B.: Multiple WU RF lines deleted to save space)
Thanks for any clues!
Robin..
Davis Vantage Pro 2
WeeWX 4.10.2 | Meteo-Pi Ethernet Logger
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
https://www.wunderground.com/dashboard/pws/IAUCKLAN159
Offline Gyvate
Re: WeatherCloud device "Unlinked"
« Reply #1 on: December 06, 2021, 03:27:55 PM »
1. need the syslog with debug = 1 in weewx.conf over two archiving cycles including the startup
2. try to enter enable = true before the credentials in the [[WeatherCloud]] section in weewx.conf
3. I'd expect to see a service under restful_services = weewx.restx.StdWU, ......, weewx.restx.Stdwcloud (or similar) in the [Engine] [[Services]] section,
but there isn't ...
do a step by step approach:
a. change weewx.conf like in 1. and 2. and restart weewx and provide the syslog as mentioned in 1.
b. repeat the installation process and provide the syslog again as under 1.
use https://github.com/matthewwall/weewx-wcloud
(the link at weathercloud.net/info/weewx redirects to the wiki home - and there the link is shown as above)
Offline rcnz
« Reply #2 on: December 07, 2021, 02:15:13 PM »
Outstanding!
Thanks, Gyvate: I went through your steps one at a time.
At first, no joy, then 3b - ran the install again: bingo!
In other weewx.conf edits, I simply wrote out the change, then restarted WeeWX - all good.
With WeatherCloud running, and I do that, I get red warning [File on disk has changed]. If I accept change, sometimes WC data aren't posted. re-running the install fixes that every time.
Thanks again!
(Cheeky ask): In WeeWX 3.9.2. I'm sure I got data to the Weatherlink site, but I don't have all my files from then. Any ideas?
Davis Vantage Pro 2
AWEKAS
CWOP  (MPiE Direct)
OpenWeatherMap
PWS Weather
WeatherCloud
Windy
Windfinder
WL (MPiE Direct)
WOW ((MPiE Direct)
WU
WU:
Offline Gyvate
« Reply #3 on: December 07, 2021, 02:20:55 PM »
Outstanding!
Thanks again!
Sorry, no experience with Weatherlink - somebody else from the Davis ecosystem might help out or have ideas
