Author Topic: Solar and UV info missing  (Read 1264 times)
Offline Jumpin Joe
    • Joe’s Weather
« on: October 23, 2021, 01:36:09 PM »
WD is not showing the information for Solar and UV on my site. I have a Davis 6163 wireless with Solar & UV. I have UV and Solar checked in WD.
Can anyone tell me what be causing this?
Joe
https://joesweather.info
WeatherLink Live
Offline waiukuweather
Re: Solar and UV info missing
« Reply #1 on: October 23, 2021, 01:57:04 PM »
as in this site?
https://joesweather.info/
I would think you would need to enable that in the web page setup/script settings?
Offline Jumpin Joe
    • Joe’s Weather
« Reply #2 on: October 23, 2021, 02:52:12 PM »
as in this site?
Yes.
I have enabled them.
WeatherLink Live
« Reply #3 on: October 23, 2021, 06:57:05 PM »
maybe try contacting the author of the script maybe
but also make sure the switch is in WD under control panel, solar setup
Offline Jumpin Joe
    • Joe’s Weather
« Reply #4 on: October 23, 2021, 07:13:42 PM »
Thanks…. It is on.
I’m hoping Ken True or Brian from WD will see this post and reply with their thoughts.
WeatherLink Live
« Reply #5 on: October 24, 2021, 10:53:10 AM »
In your Settings-weather.php, you have
$SITE['UV']                = false;  // set to false if no UV sensor
$SITE['SOLAR']            = false;  // set to false if no Solar sensor
That should be
$SITE['UV']                = true;  // set to false if no UV sensor
$SITE['SOLAR']            = true;  // set to false if no Solar sensor
to enable the display of the station's UV and Solar sensor data.
Offline Jumpin Joe
    • Joe’s Weather
« Reply #6 on: October 24, 2021, 11:41:54 AM »
That should be
Never thought of checking that script.
Thanks, Ken!
WeatherLink Live
