Author Topic: Can i select which Davis Anemometer to report to CWOP/WU with MB PI? **solved**  (Read 462 times)
Offline fkapp
If I setup a Meteobridge PI can I select which Davis Anemometer to send to CWOP and WU?
I have a VP2 and a Davis 6332 with a 2ndary anemometer which is on my roof top.
Have Weather link live running, but my issue is I can not select which anemometer to send to WU and CWOP.
I want to report the 6332 anemometer on CWOP and WU as the roof top is more accurate, so am wondering if the Meteobridge PI will allow me to accomplish this?
Please let me know so understand if this will work before spending the money on the MB PI if this will not meet this goal.
Thanks in advance for the help
Frank
Offline fkapp
Re: Can i select which Davis Anemometer to report to CWOP/WU with MB PI?
« Reply #2 on: October 09, 2021, 08:39:36 PM »
In the meantime I reviewed the mapping section on the Meteobridge Wiki page and this sounds possible.
Here is what I have found.
"Meteobridge has to find a way to tell which sensors of which station should be used for what purpose in regard to weather network uploads and other operations. This is done by mapping the "physical" sensors of a particular station to the "logical" sensors used for uploading data. The "mapping" tab is predefined with obvious mappings when having just one primary station connected, but you can chnage this by selecting a physical sensor with "select sensor" dropdawn. having selected a physical sensor you are asked to give it a meaning by mapping it to a logical sensor."
Will test this out once get the MB PI setup which will be the next challenge due to constrained required SD card availability.
Debated just deleting my post but figured would post in case helps someone in the future....
Frank
