Author Topic: Yet another opensource weather station with ultrasonic anemometer  (Read 458 times)
Offline majianjia
    • QingStation
A few years ago, I found an ultrasonic anemometer by Hardy Lau https://www.dl1glh.de/ultrasonic-anemometer.html#advancement
It is so interesting and he kindly recorded all the related info such as math and schematics that are needed to build our own ones.
Early this year, I finally decided to build a replicate of the ultrasonic anemometer but also added more sensors to make it a complete weather station.
It has a name now call QingStation
The weather station is fully opensourced, people who are interested can find more details in the below repos
Build logs, PCB, cad are in main repo https://github.com/majianjia/QingStation
Firmware is in a dedicated repo https://github.com/majianjia/QingStation-Firmware
The plan was to make it small therefore can be installed on my small drone boat. So the overall design is very compact.
It took quite much time for me to debug and tune the ultrasonic transducer.
Specs
Features:
    MCU: STM32L476
    PCB dimension: Φ48 mm
    SDCard
    RTC
Sensor Integration:
    Anemometer (2x2 Ultrasonic transducer array 40k/200kHz)
    Rain sensor (IR Optical type)
    Lighting sensor (AS3935)
    IMU & eCampass (BMX160)
    RGBI light sensor (APDS-9250)
    Microphone (MP34DT05/6)
    Barometer, humidity, temperature sensor (BME280)
Communication Interfaces:
    2x UART
    I2C
    SPI
    CAN (FDCAN)
    USB (CDC and/or MassStorage)
Power Consumption
    Normal 20~22mA
    Normal + GNSS: ~45mA
    Normal + GNSS + ESP8266(MQTT @ 1Hz): ~100mA
    Sleep: unknown
External Communication
    ESP8266 (AT)
    ESP32 (AT)
    SIM800c
The below is windspeed vs GPS speed when the QingStation is mounted on my car.
I built a few more to test whether my algorithm can work on different hardware.
It can also use windspeed measurement to estimate temperature. This is an overnight test, shows the temperature is aligned with the onboard measurement.
For more photos and details, you could check the links to Github.
It now records data to the onboard SD card and can post data to the MQTT broker.
I am not familiar with weather software so I am not sure how to properly pack the data and send it to the software.
The principle for the above anemometer is to measure the time that the ultrasound beams propagate and reflects then receive by one of the transducers.
The size cannot be smaller than a threshold where the transducer cannot respond fast enough due to the physical momentum.
So the gap is quite large between the reflection plate and the transducer. The longer travel path also weakened the signals so it fails sometimes in strong winds.
Next step
There is another approach that bases on the phase shift instead of beam recognition.
It has a few advantages
1. It has one active transducer and 3 passive transducers, which reduces the complexity.
2. It sends a continuous waveform so the momentum doesn't matter now.
3. the gap is quite small so the amplitude of the signal will be very high.
The downside is
1. Smaller travel path, so the accuracy will not be that high.
2. Smaller gap will slow down the airflow. So it must be calibrated to produce an accurate measurement.
Now I have enough experience and I am planning to build another one with this new approach.
Offline parkview
Re: Yet another opensource weather station with ultrasonic anemometer
« Reply #1 on: October 18, 2021, 04:31:30 AM »
So much to learn from. I have just started on my own remote weather station so yours is very inspirational.  I love how your doing the rain and wind sensor.
What type of ultrasonic transducers did you use?  Are they water proof enough?
Offline majianjia
    • QingStation
« Reply #2 on: October 18, 2021, 11:40:53 AM »
I used small 10mm aluminium waterproof transducers brought from china P/N: EU10AIF40H07T/R. There are no holes on them so should be waterproof.
you probably can find some similar ones on aliexpress.
I use 10 VPP to drive one transducer at a time, the receiving signal on the other side is quite small, at ~10mv, a larger vpp might help.
