Author Topic: What is the deal with these shield models?  (Read 335 times)
Offline hmderek
    • Meteodrenthe
« on: October 01, 2021, 04:40:31 AM »
So you have the R.M. Young 41003: https://www.youngusa.com/product/multi-plate-radiation-shield/
Then there is the Rotronic AC1000: https://www.rotronic.com/en/ac1000
They look very similar, though there are differences between them, (9 vs 10 plates for example). But the bracket looks suspiciously similar.
Then you have this model at Seeedstudio: https://www.seeedstudio.com/Solar-Radiation-Shield-for-Outdoor-Sensor-Protection-A10-p-4601.html
Totally different pricing, but once again they look alike and the bracket is the same.
And how about this? -> https://nl.aliexpress.com/item/32828473654.html?spm=a2g0s.8937460.0.0.4e882e0eg07DZZ
Also very similar, same bracket.
Aside from the Rotronic (with  9 in stead of 10 plates), are these clones? If so, would you expect one of the clones to perform similarly?
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Apogee Instruments TS-100
Barani Meteoshield Pro
Davis 7714
MetSpec RAD14
Davis AirLink
Wemos D1 Mini micro controllers
https://blog.meteodrenthe.nl
https://meteodrenthe.nl
Offline TheBushPilot
  • Storm chaser and independent researcher
    • Central Chasers
Re: What is the deal with these shield models?
« Reply #1 on: October 17, 2021, 02:30:45 PM »
Probably manufacturers using the same item from Young and rebranding them. That last one you posted however is probably a copied replica or mix and match of Young and their stuff, as noted with the different nuts on the bottom.
"There is — always — more than one thing influencing anything we are trying to measure." ~ Sherman Fredrickson
"Well right now I don't feel very damn researchy" ~ Tim Samaras
"Do it right or don't do it at all."
