Author Topic: Virtual vp no more avaiilable  (Read 9765 times)
Offline Guillaume_67370
    • METEO OFFENHEIM
« on: August 18, 2021, 03:07:26 PM »
Hello
I try to download again virtual vp but link softwx.com is no more available
http://www.softwx.com/weather/virtualvp/virtualvp1.2.4.zip
Please Can you help me
Thanks a lot
Offline davidg_nz
    • Sandy Bay Weather
Re: Virtual vp no more avaiilable
« Reply #1 on: August 18, 2021, 04:28:30 PM »
Port Charles, Coromandel, New Zealand | Wired Vantage Pro2+, Ubiquiti AirCam
Hamilton, Waikato, New Zealand | Wireless Vantage Pro2+, 24h FARS, Leaf+Soil Station, Envoy
« Reply #2 on: August 18, 2021, 05:32:17 PM »
Keep in mind that VirtualVP only works with the old Davis loggers (no 'green dot') and VP1 systems.  VP2 systems with new Davis loggers will not work.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #3 on: August 18, 2021, 10:18:27 PM »
Do you have the registration key ? If not it's
Serial # 99991
Registration  G8JW-JC7V-MBGZ
Works great with a serial and original usb logger as well a WiFi logger. I also use it to send the data over my inhouse network (Ethernet over power lines) to a back office pc. VP2 systems with Consoles/or Envoys with the above mentioned loggers work fine.
« Last Edit: August 18, 2021, 10:23:02 PM by Garth Bock »
    • METEO OFFENHEIM
« Reply #4 on: August 20, 2021, 03:41:49 AM »
Serial # 99991
Hello
Thanks a lot ;)
Another question i'm using Windows 10 Family 64 bits and i also need to create virtual COM port for another software
Can you please send the driver i need to install ?
Thanks a lot for your great help
Offline Garth Bock
« Reply #5 on: August 20, 2021, 09:01:05 AM »
You will need VSPE or Virtual Serial Port Emulator. The cost for this is only $24.95.
There are some free ones but some are only 32 bit and one I tried years ago is no longer supported. If you get VPSE I will send you my config file that will help jump start  your set up.
http://www.eterlogic.com/Products.VSPE.html
« Last Edit: August 20, 2021, 09:05:24 AM by Garth Bock »
    • METEO OFFENHEIM
« Reply #6 on: August 20, 2021, 08:16:04 PM »
ok i get VPSE thanks
please could you now send my how i can make the configuration
Thanks a lot for your great help  :grin:
« Reply #7 on: August 22, 2021, 04:58:08 AM »
 Are there other software programs to run WD and Weatherlink together?
Offline AZmonsooncats
  • Current weather conditions in North Phoenix, Ariz
  • Me & My Little Sis!!
    • Pepper Ridge North Valley  Weather and Lightning
« Reply #8 on: November 22, 2021, 08:11:43 PM »
Hello,
My hard drive recently crash and I trying to get Virtual Vp back up running again and I just just VSPE running again and downloaded Virtual Vp but it seems to not like this key listed below it excepts says it was successful it but then stills says trial expired and it won't connect at all my settings are just like Garth's listed above.  I using the same data logger that worked before. Any suggestions to fix this.
Serial # 99991
Hello
Thanks a lot ;)
Jeanette
UPDATE: Once I ran Virtual Vp as administrator It finally allowed the Registration to work so it is now working properly again  :grin:
« Last Edit: November 22, 2021, 08:45:37 PM by AZmonsooncats »
"Some dreams are in the night time, And some seem like yesterday
But leaves turn brown and fade, Ships sail away
You long to say a thousand words…but Seasons Change."
CWOP:CW3794, MesoWest: C3794, Facebook: https://www.facebook.com/PepperRidgeNorthValleyWX/
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #9 on: November 23, 2021, 06:02:20 AM »
THE key to solving this problem!
Regards, Jerry Wilkins
gwwilk@gmail.com
