Author Topic: How to set up custom FTP archive export  (Read 917 times)
Offline MatteoPV
« on: July 09, 2021, 08:06:34 AM »
I recently developed a media server style network drive that works very well. So I wanted to use the wifilogger 1 with firmware 2.38 to export the data via FTP more 'vole a day and save them on the network disk. I created a 'Weather' folder on the disk and set the WFL by entering the disk's IP address, user, password, full table address etc. When I try to press the Test button, no files appear in the folder ??? Where am I wrong?
Offline MatteoPV
Re: How to set up custom FTP archive export
« Reply #1 on: July 09, 2021, 11:34:47 AM »
I found this thread but didn't understand how it solved
https://www.wxforum.net/index.php?topic=37585.msg386763#msg386763
Offline dupreezd
« Reply #2 on: July 09, 2021, 12:38:21 PM »
This is my setup using WiFiLogger 1 and it works
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
Offline MatteoPV
« Reply #3 on: July 10, 2021, 02:53:46 AM »
Basically you also added the file name 'Archive.txt'. What does the system do with this adjustment ??? One upload per day? But if I press on 'test' nothing happens anyway
Why if I press on Test nothing happens ??? Does he create the Archive.txt file immediately at the beginning or do I have to create it myself?
« Last Edit: July 10, 2021, 03:58:09 AM by MatteoPV »
Offline MatteoPV
« Reply #4 on: July 10, 2021, 05:58:17 AM »
I adjusted it like you and it works. With this type of setting it does one upload per day ????? Does putting on 'enable' update in cotinuo? What do you do the next day? Create a new file?
Offline dupreezd
« Reply #5 on: July 10, 2021, 08:58:43 AM »
MatteoPV, I renamed my Archive.txt then pressed Test. A new Archive.txt was created containing all the records from yesterday and the ones from midnight today up to current time with a new line entry every 30 minutes.
I do not rename or do any file maintenance and only have one Archive.txt.
Under Weather Station setup, there is a place where you set the archive interval. Mine is set to 30min.
CWOP - FW0717
Blitzortung 2100
Offline MatteoPV
« Reply #6 on: July 10, 2021, 12:08:13 PM »
Mine updates the file every 15 minutes, that's fine by me. To use that type of file, what software do you use ??? Cumulus?
Offline MatteoPV
« Reply #7 on: July 11, 2021, 01:22:17 AM »
I tried to increase the archive days, at most it reaches 255 days, why doesn't it reach 365 ???
Offline MatteoPV
« Reply #8 on: July 11, 2021, 08:55:14 AM »
As an 'archive' I was thinking of something I could keep. In this case, however, the system stores the data for the days that I set, the next day, however, I am going to cancel the first day of departure. Isn't there a setting with which to save the data of a year starting from January 1st to December 31st?
