Author Topic: New to Cumulus, Time issue  (Read 968 times)
Offline kg4ooz
« on: June 24, 2021, 11:24:58 PM »
I am as new to Cumulus as I can be and am in need of help.  I installed CumulusMX on a Raspberry pi 3B+ using a ethernet logger installed in a Davis VP2.  I got cumulus communicating with the logger but the "last station update time" does not match either of the times.  The times matches the minutes and seconds but is 8 hours behind.  This seems to be also causing my records times to be off along with the Sunrise/sunset times.  I have checked everything I can find to do with time and rebooted everything involved.  Every time matches except for that one.  Logger, console, and cumulus all match.  Any help would be greatly appreciated.
Offline kg4ooz
Re: New to Cumulus, Time issue
« Reply #1 on: June 24, 2021, 11:38:42 PM »
I found my problem, the time of the RaspberryPi itself was incorrect.
