Author Topic: Ethernet Logger has arrived  (Read 3755 times)
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: Ethernet Logger has arrived
« Reply #25 on: September 25, 2021, 03:10:10 PM »
If the logger is up to date, then what are you trying to do with the STM32 program?
Offline Sylver19
« Reply #26 on: September 25, 2021, 03:14:38 PM »
Enregistreur Wifi donne la procédure pour la programmation pour mettre en ligne? je ne sais pas ce n'est pas très clair
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #27 on: September 25, 2021, 05:34:29 PM »
OK. It shows you how to Update. If you have the current version, there is nothing required. It looks like you have attained how to connect if needed. But there is nothing required at this time.
Offline Sylver19
« Reply #28 on: September 25, 2021, 05:37:11 PM »
cela veut dire que l'on ne peut pas mettre en ligne la vp2 pour l'instant?
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #29 on: September 25, 2021, 07:42:22 PM »
I am not sure what that is.
Offline Sylver19
« Reply #30 on: September 26, 2021, 12:50:56 AM »
Davis vantage pro 2
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #31 on: September 26, 2021, 03:14:27 AM »
Oh. So are you saying that you cannot upload VP2 data to the internet with the current firmware in the Logger?
Offline Sylver19
« Reply #32 on: September 26, 2021, 05:35:22 AM »
Oui je ne peux pas mettre les données de la davis vantage pro 2 sur weatherlink.com
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #33 on: September 26, 2021, 11:50:48 AM »
What are your settings for upload? [ You are not allowed to view attachments ]
Offline Sylver19
« Reply #34 on: September 26, 2021, 02:41:41 PM »
Je le trouve comment ce tableau ? Car j'ai dejà installé des Wifilogger2  et il faut aller dans le setup du datalogger.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #35 on: September 26, 2021, 04:38:37 PM »
You need to find the IP address of the Ethernet Logger by using the administrator page of your WiFi router. Enter that into a browser the same way you go to your wifi logger.
Offline Sylver19
« Reply #36 on: September 26, 2021, 05:31:14 PM »
sur mon routeur Wifi ,je ne trouve pas l'Ethernet logger connecté pourtant j'ai branché le cable ethernet et les deux voyant sont allumés.Je pense qu'il faut activer la prise ethernet de l'ethernet logger avec une programmation?
« Last Edit: September 26, 2021, 05:46:22 PM by Sylver19 »
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #37 on: September 26, 2021, 08:49:15 PM »
There should be nothing to activate for the logger to connect.
It slipped my mind before but I should ask. Is your router for WiFi and ethernet cable the same device?
Can you look for the Ethernet logger from another device, like a laptop, that is plugged into ethernet cable?
Offline Sylver19
« Reply #38 on: September 26, 2021, 11:38:13 PM »
Ce soir , j'essayerais de brancher l'ethernet logger directement sur le routeur wifi (box)sans passer par un switch ou autre routeur wifi. 😉
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #39 on: September 27, 2021, 03:01:30 AM »
Yes, that is a good idea. I caused myself some confusion with devices connected to switches.
Offline Sylver19
« Reply #40 on: September 27, 2021, 02:57:10 PM »
je viens de brancher directement l'ethernet directement à une sortie de la box , toujours pas de connection  ](*,)
Offline Sylver19
« Reply #41 on: September 27, 2021, 11:41:42 PM »
Avant j'avais les petites lumières verte et bleus qui s'allumaient depuis plus rien .
Offline WiFiLogger
« Reply #42 on: September 28, 2021, 08:10:18 AM »
Green LED ON - this mean Ethernet connection is set. This mean cable is pluged in, DHCP procedure is finished, full set of IP number is set.
If GREEN LED will be not ON, nothing in Ethernet logger will work.
Please plug ethernet cable to the logger and to the switch,or router, then click on RESET button in Ethernet logger. It should start and set Ethernet connection.
You have to have GREEN LED ON.
Offline Sylver19
« Reply #43 on: September 29, 2021, 02:14:28 PM »
Hello, j'ai la LED verte allumée  et la LED jaune qui clignote ( coté prise Ethernet) , mais  les petites LED (ETH,EXPORT,TCP) et (DATA,COMMAND)  rien ne fonctionne  :-(
« Last Edit: September 29, 2021, 02:18:52 PM by Sylver19 »
Offline WiFiLogger
« Reply #44 on: September 29, 2021, 03:24:47 PM »
LED ETH - has to work, to allow any operation.
Interface is over web, so communication is needed.
There is a SETUP button. It has 2 features.
Please click it and hold.
1. After 5 sec. LEDs EXPORT and I think TCP should blink.
       This option is to enable DHCP. This is needed when user will set manual IP and change router.
2. After another 5-10 sec. All LEDs should blink and this mean settings are reset. Memory is cleared.
Please try reset settings to factory settings then click on RESET button to start from the begining.
Please write here, or email me here if it change anything.
Wojtek
Offline Sylver19
« Reply #45 on: September 29, 2021, 03:40:39 PM »
rien ne s'allume après avoir cliquer sur setup
Offline WiFiLogger
« Reply #46 on: September 29, 2021, 03:54:33 PM »
Please unplug power from it. Then when you plug in power again. Do you have one blink of LEDs? ETH, EXPORT, TCP?
The same should happen when you click on reset button. All LEDs should blink once.
Is that happen?
Offline Sylver19
« Reply #47 on: September 29, 2021, 04:01:34 PM »
l'autre jour  ,j'avais les petites LED qui s'allumaient ,j'ai du faire une mauvaise manip, maintenant plus rien ne s'allume .
Offline WiFiLogger
« Reply #48 on: September 29, 2021, 04:27:51 PM »
Did you checked BOOT slide switch? Maybe it is in programming mode? Please check if it is on the right.
Offline Sylver19
« Reply #49 on: September 29, 2021, 04:31:44 PM »
il est bien à droite .
depuis l'autre jour ,je n'arrive pas à faire cette étape:
https://www.wxforum.net/index.php?action=dlattach;topic=42225.0;attach=49719;image
