Author Topic: Esp32-Cam  (Read 940 times)
Offline Phil23
    • Phil's Backyard
Esp32-Cam
« on: June 02, 2021, 11:35:00 PM »
Anyone here played around much with ESP32's or ESP32-Cams?
At $10 a throw I'm planning on getting 4 camera's up NSEW.
Just succeeded in getting images uploaded.
Sample can be seen here.
http://weather.inverellit.com/images/Esp32-Cam.jpg
Uploaded with Agent DVR, but anything that can access the MJPG stream would do.
Any thoughts & input would be appreciated.
Phil.
Offline zoomx
Re: Esp32-Cam
« Reply #1 on: June 03, 2021, 04:54:24 AM »
I too have some of them.
This module can use internal or external antenna but the coiche is made with solder pad with a very small 0 ohm resistor, near the antenna.
Usually it is configured to use intenal antenna but sometimes to use the external.
Funny, I got the kit with external antenna but it has the resistor for the internal.
Offline Phil23
    • Phil's Backyard
Re: Esp32-Cam
« Reply #2 on: June 08, 2021, 01:20:58 AM »
Basically running Ok now on this firmware,
https://github.com/easytarget/esp32-cam-webserver
Big improvement on the official demo.
Current problem is what to use for enclosures;
Did order some fake security cameras, but the optical quality of their Domes is too poor for a good image.
For my location where the house in orientated almost NW-SE, I was thinking 2 cameras per enclosure at 90° to each other.
Front one would cover North & West, rear South & East.
Any lateral thinking on what might make a suitable enclosure?
Modules are about 30x40mm + some free space.
http://weather.inverellit.com/webcams2.htm
Phil.
Offline zoomx
Re: Esp32-Cam
« Reply #3 on: June 08, 2021, 02:14:01 AM »
Unfortunately most enclosures are not thought for optical quality.
But after a while I remembered this one
https://www.aliexpress.com/item/32867508689.html
It is the waterproof camera case for Sjcam SJ4000, a GoPro clone.
It is cheap like the ESP32-cam but it must be adapted for power, maybe using the button holes.
Problem: the objective screen is not flat but hemispheric, maybe for  underwater correction.
Offline doubleohwhatever
Re: Esp32-Cam
« Reply #4 on: June 19, 2021, 04:13:11 AM »
A 3d printed enclosure with a lens from flashlightlens.com might work.
