Author Topic: temis.nl may be giving erratic data or my script may be out of whack  (Read 484 times)
Offline AmateurExtra
  • Amateur Radio Operator Extra Class - N3UVR
    • N3UVR's Backyard Weather Station
When I check https://www.temis.nl/uvradiation/nrt/uvindex.php?lon=-75.5639&lat=41.4911 this is what is returned:
                  UV
                      index       ozone
   Date                          column
  29 May 2021    8.7      326.8 DU
  30 May 2021    8.3      336.6 DU
  31 May 2021    8.0      348.6 DU
  1 Jun 2021    8.1      344.5 DU
  2 Jun 2021    8.2      340.9 DU
  3 Jun 2021    8.9      321.7 DU
UV grid cell data:
centre lon, lat = -75.625, 41.375
average elevation = 442 (± 120) m
Last modified: 25 February 2021
29 May 2021 was overcast with rain
30 May will more likely be the same and https://k3csg.altervista.org/index.php is showing 0.0 UV but the label appears as "extreme." So either temis is down or my script is out of whack. Solution?
"And therefore never send to know for whom
the bell tolls; it tolls for thee."
"For Whom the Bell Tolls"
by John Donne
Offline wvdkuil
  • Wim van der kuil
This tool returns the forecasts  . . .
at local solar noon of today . . .
 for clear-sky conditions and in the absence of snow.
This is a UV forecast showing the theoretical "maximum" amount
It calculates the UV value without clouds , air-polution and all other items which inhibit the UV radiation to reach ground-level.
Nothing wrong with the Temis values theoretical values.
Forecast-scripts use these values to combine UV with  all other items into a more "real-life" UV-forecast.
Your page probably has a small script error as it shows the real-life UV value as measured by your weather-station as"no radiation present"  and the text "extreme" is not the correct text for that value.
Your station should have a functioning UV-sensor to use this part of the dashboard.
Check the Meteobridge upload file to see what values are uploaded.  A "--" value could be the cause of the word "extreem"
Wim
« Last Edit: May 30, 2021, 02:35:30 AM by wvdkuil »
Thank you for your reply. I now understand that the UV forecast is theoretical and not the actual conditions present. I did find the error. I wanted to display Meteobridge system uptime and changed the conds.php upload to include [mbsystem-uptime] which caused the UV Index on index.php to become erratic. I removed the variable and now the page reads UV Index 0.6 Low. Since that was the only variable changed I figured that it was the cause of the error. I do have the system uptime on the status page using gen-MBtags.php writing to MBtags.php and all is working fine. Thank you.
by John Donne
