Author Topic: GRLevel3.2 2.80 will not zoom up closer than 3.7 meters/pixel  (Read 867 times)
Offline thuman5
    • tkhuman.com
For the past few months, grlevel3.2 will not zoom any closer than 3.7 meters/pixel. I am not sure how far it would zoom before but I know it was a lot closer than that. I was in the past, able to zoom up to the trees in my yard but now I can barley be sure I am marking my house or the neighbors. When the zoom goes beyond that everything just goes white??
Offline SoMDWx
    • Southern Maryland Weather
Re: GRLevel3.2 2.80 will not zoom up closer than 3.7 meters/pixel
« Reply #1 on: May 21, 2021, 03:05:48 PM »
Not sure why you even need to zoom down that far for storm data..... Could be that the map service is incapable of that resolution down that far...
Offline thuman5
    • tkhuman.com
« Reply #2 on: May 21, 2021, 04:56:40 PM »
I want to zoom that far because I want to place my marker precisely on the spot and also because there is no good reason why in the 21st century, that I shouldn't be able to, especially since 6 months ago I could.
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #3 on: May 21, 2021, 07:39:18 PM »
I pulled this from the GRLevelX Users Forum.
Limit zoom level on NAIP imagery to around 3 meters/pixel
http://www.grlevelx.com/owners/viewtopic.php?f=34&t=11012
Steve
Offline thuman5
    • tkhuman.com
« Reply #4 on: May 22, 2021, 10:26:02 AM »
Thanks for the link however due to the inaction of the GRLevelX Owners Forum administrator, I am unable to access it even though I have purchased at different times, granalyst, grlevel2, and grlevel3. I never received, at least while I had the email address I purchased the software's from, the ok to join and access the site email.
Offline KaseyBear
« Reply #5 on: July 05, 2021, 12:35:28 PM »
http://www.grlevelx.com/owners/viewtopic.php?f=34&t=11012/employee monitoring
Steve
Offline cassins1824
« Reply #6 on: June 11, 2022, 05:03:49 PM »
Hello, did you ever find a resolution to this issue?  I'm having the same problem too.  I used to be able to zoom all the way down to rooftops, now it all goes white after 122 meters/pixel.  I too am unable to access the Users Forum (awaiting Administrator approval).  Thanks!  Scott
Offline thuman5
    • tkhuman.com
« Reply #7 on: June 11, 2022, 11:06:49 PM »
Not really. It has kinda started working on its own in that it at least doesn't go all white. But you have to know what you are looking at because its real blurry. I don't remember it being that blurry close in.
Offline cassins1824
« Reply #8 on: June 12, 2022, 08:31:27 AM »
Thank you thuman5!  Since my post, I realized I was using version 2.6, so I downloaded 2.93 and installed it.  Once reinstalled, I drilled down and got the same white screen, however, when I right-clicked on the map and selected "reload visible tiles", it must have downloaded the maps automatically.  I can now get down and select an accurate 'home' spot again.  Anyway, thanks for the reply and have a great Sunday.
