Author Topic: RCL 410 no power on Ethernet  (Read 523 times)
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« on: April 27, 2021, 10:09:34 AM »
I got this Reo RCL 410 and if I plug the power into barrel connector it works fine.
Does not come on with power applied to the POE Injector.
I read 12 volts on 4/5 7/8 of the RJ45.
I wonder if it is just the simplistic injector I have.
Should the best solution be to jusr get a switch with POE built In?
I am guessing the injector I have is not 802.3af compliant? Could that be the issue.?
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: RCL 410 no power on Ethernet
« Reply #1 on: April 28, 2021, 06:47:10 AM »
That device uses either 12V DC from a power supply unit, PoE is usually not 12V  its either 24v 48v or 54v
« Last Edit: April 28, 2021, 06:52:34 AM by ConligWX »
Regards Simon
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #2 on: April 28, 2021, 08:48:46 AM »
Oh I C.
That's another arena of tech I must get informed about.
Thanks for the tip
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #3 on: April 29, 2021, 03:13:06 PM »
Awesome.
Next day delivery.
PoE Injector switch arrived.
Thanks for the tip.
Offline Bashy
  • brecklandweather.com/pws2021
    • Breckland Weather
« Reply #4 on: December 11, 2021, 10:31:40 AM »
What do you think about the camera, whats it like at night, does it show the clouds, stars etc? that's what I'm after and looking at the reo's at the minute, but obviously need one that can snapshot jpg, would prefer  one that can stream live but i think i may have to use a program to serve the stream?
Kind regards
Bashy
