My problem was that recently (see below) my WH41 was reading excessively high values, in particular during high humidity. After seeing the video referenced above I cleaned the inside of the unit as best I could. It is not easy to get the level of access like shown for the Plantower units, but by removing the white "air" cover (clips on the side) you can get access to the sensor package. It has three rubber feet you can remove to be able to remove one cover. This gives you some access to the air inlet channels, which I cleaned with compressed air. You are also able to left the fan out to clean it. Mine didn't look dirty but I cleaned it. Access to the photo diode was not possibly using this method.
Perhaps more importantly I looked up the sensor manual and it speaks about correct, and incorrect, mounting. Basically if using the ecowitt unit on a flat horizontal platform you are going to be fine no matter orientation. If you are mounting on a vertical surface you should be mounting in such a manner that the air inlets are lower than the fan (outlet). See attached image.
To do this correctly, remove the white outer shell from the base and, issuing a flashlight or such to peek inside and located the fan. It easiest to then mark it on the white outside or inside with a sharpie or such. To get the right orientation against a vertical surface you must then mount the unit in a vertical orientation, not horizontal as I had it.
In my case this can also be remembered by making sure the internal USB port is on the top side, but I am not sure all units are manufactured identical in this manner.
After a brief test, inside the concentration dropped from some 160 µg/m3 down to 11 so it seems to be a huge improvement. No going to put it back outside to see what happens (humidity is higher than inside).
P.S. The "recently" above was after having the unit removed due to a painting job. I had it mounted on a vertical surface, but horizontal orientation. I may well have put it back 180 degrees rotated from how it was before, reversing between up and down for air inlet and outlet, which could easily have a detrimental effect. After some more testing I am going to mount it, still on a vertical surface, in the vertical orientation.
