Author Topic: Why is Routerlogin net not working?  (Read 368 times)
Offline halsonhelly67
« on: April 22, 2021, 02:13:33 AM »
Every user should create a backup of the configuration settings of the routerlogin.net window within the computer. The reset or firmware update process may remove the configuration settings from your device after which you need to reconfigure your router. To avoid yourself from the reconfiguration process make sure to create a backup of the current configuration settings.
Re: Why is Routerlogin net not working?
« Reply #1 on: April 23, 2021, 11:32:24 AM »
That URL may not work if you have configured alternative DNS servers on your network. Meaning that you are not using the router as your DNS. Another possibility is that you are following instructions for Netgear router and you do not actually have a Netgear branded router.
But these helper URL addresses are not needed to log into your router. Just look at your computer's network configuration and use the IP address of the default gateway as that is the router's address.
