Author Topic: Mounting suggestion?  (Read 404 times)
Offline jcookjr82
« on: April 08, 2021, 02:10:41 PM »
My apologies if this does not belong in this section, but I am looking for a cheap way to mount my Davis Vue. I thought I found it by purchasing this pipe tower through Home Depot (https://www.homedepot.com/p/Winegard-Universal-Pipe-Tower-Mount-for-Antenna-DS-2000/204701089) and the recommended mast extension of the same brand, but the extension is too small for the pipe and I have found it nearly impossible to find a mast extension with a swedged end that will fit in this pipe (1.66" outer diameter). I currently have the Vue mounted on the end of the tower, but because the roof is asphalt shingles, I am concerned that it is causing heat radiation and would like to raise it at least 3 feet higher, ideally 5 feet. I would like to keep the same tower mount, but I will need to find a smaller pipe with more easily accessible mast extensions. It seems as if 1.25" is the standard. I have the Ambient one of similar design for my station at home, but don't really want to spend $100 for the station at our cabin. Thank you for you time and suggestions, in advance.
« Last Edit: April 08, 2021, 02:19:05 PM by jcookjr82 »
Davis Vantage Vue
LaCrosse 2813 (retired 1/17/2018)
Offline Notsorusty
Re: Mounting suggestion?
« Reply #1 on: April 08, 2021, 02:34:36 PM »
I used the same mounting set-up. I was also able to get a length of pipe from a muffler shop that fit into the top of the pipe. They should be able to sell you the length you need but you will have to clean, prime and paint the pipe as it will probably rust rather quickly. I also painted the mount the same color.
Station Name: Silver Creek
Latitude / Longitude: 41.925 N, -87.872 W
Elevation: 633
City: Franklin Park
State: IL
Hardware: Ambient Weather WS-2902
Software: AMBWeatherV4.0.0
Offline azchrisf
« Reply #2 on: April 12, 2021, 02:43:09 PM »
Redneck solution: 1.25 inch PVC pipe cut very short to fit into the Vue, drill it and the metal pipe for a bolt, insert bolt and set of washers on both sides in pipe to center it. Wa'la.
Also doing Soil and Leaf 4x
Offline Great.Gonzos
« Reply #3 on: April 12, 2021, 05:30:54 PM »
Will it "wiggle" any? If this "adapter pipe" is long enough and fits close enough, it should be good.  if not, try making it longer and then put two bolts through it (going through both pipes), one at the top and one at the bottom of this "adapter pipe" that are 90 degrees to each other.
Viola! A fix from outside the box.
Hardware: Ambient Weather 2902C
                Ecowitt GW1000 Console
                Ecowitt WH57 Lightning Detector
                Acurite bits
Station ID: GWX1935
Offline azchrisf
« Reply #4 on: April 12, 2021, 06:21:30 PM »
I was thinking that after I posted - glad you caught it!
