Author Topic: Earthquake - the result of an explosion of magmatic gases  (Read 6394 times)
Offline Fermer05
« on: March 28, 2021, 01:04:32 PM »
The cause of earthquakes is the explosion of magmatic gases.
Community of Russian scientists. https://vk.com/rosuch
The tidal force stretches and compresses the Earth twice a day, due to which pressure fluctuations occur in the earth's crust, and as a result, air penetrates into the earth's crust through vertical faults.
At the same time, magmatic gases, being under high pressure, penetrate into the faults in which there is air. http://www.crust.irk.ru/spp2/pages/maps.htm
And as soon as the ratio of magmatic gases and air approaches 1 to 7, an explosion occurs, and the waves from the earthquake source scatter in different directions.
After the explosion, faults diverge from the source of the earthquake, into which the combustible mixture rushes, due to which aftershocks occur.
The duration of earthquakes and the number of underground explosions depend on the amount of combustible mixture in the epicentral region. https://en.m.wikipedia.org/wiki/Earthquake
Ignition of a combustible mixture occurs as a result of compression of the combustible mixture, contact of magma with a combustible mixture, or from an electric discharge. The self-ignition temperature of gases is about 500°C.
It is possible that the combustible mixture is formed as a result of magma degassing. https://www.ngpedia.ru/id659214p1.html
The presented hypothesis can be easily verified by blowing up a firecracker under the ice.
https://youtu.be/zFdF6-qaPSA https://youtu.be/UDLobrro2Ao https://youtu.be/U7pNie2403A
1. In the resulting faults, rarefaction occurs, due to which the faults draw in air and then close.
This can be easily verified by experiment.
2. As magmatic gases rise, they collect at the top of vertical faults and then explode.
3. In the faults, the combustible mixture explodes not all, but only that part that has reached the desired proportion.
4. As a result of the impact of pressure and temperature, the walls of the faults become stronger. https://uc.xyz/Xyzt0?pub=link
5. It is possible that the vertical faults are interconnected.
6. After seismic events, faults are filled with magma, due to which one of the types of folded mountains is formed.
7. It is possible that minerals are formed in vertical and horizontal faults under the influence of temperature, pressure and time.
The amplitude of a seismic wave can be determined by the following formula: A = m/h.
Where, m is the mass of the combustible mixture.
h is the depth of the combustible mixture. https://uc.xyz/188nSE?pub=link
In the epicentral region, a predominantly vertical oscillation of the earth's crust occurs with an amplitude of more than a meter, and waves with an amplitude of about a meter diverge from the epicentral region.
1. Before an earthquake, some animals leave the active fault zone.
I think the animals are alarmed by the smell of gas coming out of cracks.
https://uc.xyz/ZdxgO?pub=link
2. The gas content above the epicentral region can be determined using a gas trap in which there is a litmus test.
Litmus paper can be placed in basements that are on the fault line. https://m.fishki.net/3822287-kak-zhivotnye-predchuvstvujut-kataklizmy-i-katastrofy-kakaja-reakcija-na-stihijnye-bedstvija.html
3. The concentration of gases in the faults can be determined using wells.
4. An earthquake can be provoked artificially by drilling a well in fresh faults.
5. Small explosions before and after seismic events can increase the pressure of the combustible mixture in the faults, which causes a rumble, trembling and swelling of the earth's crust. https://uc.xyz/19nfzo?pub=link
6. The cause of anomalous phenomena in the atmosphere during seismic events may be the release of a combustible mixture into the atmosphere. https://uc.xyz/19nfqm?pub=link
The formation of planets is accompanied by the formation of cracks.
One of the fissures is the Mid-Atlantic Ridge, which is located in the Atlantic Ocean and diverges at a rate of 0 to 3 mm per year. https://uc.xyz/WRQJo?pub=link
The reason for the divergence of the ridge is volcanoes and earthquakes that occur at the junction of the crack, and as a result, the size of the ridge increases both in width and in height.
In the ridges, due to seismic events, vertical and horizontal faults are formed, due to which the crack expands by millimeters, the ridge by centimeters and the epicentral region by meters. https://en.m.wikipedia.org/wiki/Seafloor_spreading
Along the Mid-Atlantic Ridge there are dozens of islands through which air enters the Mid-Atlantic Ridge, and the more islands there are above the oceanic ridge, the higher the geological activity of the ridge.
The high geological activity of continental ridges can be explained by the fact that more air penetrates into continental ridges than into oceanic ones. http://www.garshin.ru/evolution/geology/geosphere/geophysics/lineaments.html
Gases move along the faults that stretch from the mountain systems into the seas and oceans, as a result of which seaquakes are formed, and as a result, the mountain systems attack the ocean.
Mountain systems formed hundreds of millions of years ago, after the formation of the earth's crust, when the earth's crust under the mountain systems was much thinner.
The higher the mountain systems grew, the more they sagged. Shifts, bends, dips in mountain systems are the result of uneven growth and subsidence of mountain systems. https://uc.xyz/17hxws?pub=link
I guess mountain systems are 90 percent submerged in magma, like icebergs in the oceans. https://uc.xyz/17hJcu?pub=link
Three types of mountains form along the fissures:
a) Horizontal folded mountains, formed due to numerous eruptions of lava on the surface of the Earth.
b) Vertical fold mountains are formed after seismic events when vertical faults are filled with magma.
c) Blocky mountains are formed when folded mountains collapse and grow due to explosions in vertical and horizontal faults.
https://shkola.obozrevatel.com/news/goryi-kakie-est-vidyi-i-kak-oni-obrazuyutsya.htm
Due to faults, the density decreases and, as a result, the buoyancy of the earth's crust increases.
 a) The height of the continent above the magma level depends on the density of the continental crust.
 b) The more faults and voids in the mountain systems, the higher the mountain systems. https://habr.com/ru/post/369749/
Earthquakes and volcanoes are natural phenomena, the role of which is the strengthening of cracks in the earth's crust. And mountain systems are patches on the cracks of the planets.
More than a million earthquakes are recorded annually on the continents, due to which the strength and buoyancy of the earth's crust increases.
It is believed that a volcanic eruption occurs as a result of the movement of plates and an increase in magma pressure.
At the same time, a volcanic eruption is accompanied by an earthquake. https://en.wikipedia.org/wiki/Types_of_volcanic_eruptions
a) The movement of magma under pressure cannot be the cause of the formation of seismic waves and earthquakes.
b) An earthquake is the result of an explosion of a combustible mixture in a volcanic chamber.
c) Why is a volcanic eruption most often accompanied by the release of gas and ash, and not lava?
Manifestations of volcanic earthquakes are almost no different from tectonic earthquakes, 90% of volcanoes are located in seismically active zones.
In Japan, an explosion of volcanic gases crushed a 670 m high mountain. https://uc.xyz/R6PC8?pub=link
In Indonesia, a combustible mixture explosion destroyed half of the volcano and caused earthquakes in several cities, and there are quite a few such facts. https://en.m.wikipedia.org/wiki/File:Geyser_animation.gif
I believe - an earthquake, this is a volcanic eruption towards the core of the Earth.
It is possible that only magma is located under the earth's crust, and the mantle is formed only in faults and volcanic chambers. https://images.app.goo.gl/yS56u6oYvaMtavLi6
There is a high probability that between the earth's crust and magma there is a gas layer (foam), due to which the earth's crust does not overheat and magma does not cool.
https://uc.xyz/10RTc4?pub=link https://uc.xyz/ZJuja?pub=link
1. The reason for the axial rotation of the Earth is cyclones and anticyclones, which move in the direction of the general transport of air from west to east.
Rotating the earth's crust carries away magma - which rotates after the earth's crust.
2. It is believed that the core of the Earth rotates synchronously with the Earth and is in a state of weightlessness.
http://www.alexeyk.com/ru/text/gravitation.html
a) There is a high probability that due to intraplanetary weightlessness, the gravity of the Earth's core is practically zero.
b) If the centrifugal force of the Earth's core is greater than the gravitational force, then the Earth's core will disintegrate.
c) Due to the rotation of the Earth, the pressure of magma along the axis of the Earth decreases. https://vladtime.ru/nauka/582546/amp
3. I believe that the reason for the circulation of magma in the bowels of the Earth is - weightlessness in the center of the Earth and the difference in the velocities of magma rotation at the equator and poles.
a) Due to its high viscosity, magma at the poles rotates faster than in the equatorial region, due to which magma moves from the poles to the equator, from the equator to the center of the Earth, and from the center of the Earth back to the poles.
b) Perhaps, in the equatorial region of the Earth, the geological activity and pressure of magma is much higher than at the poles, due to which magma moves from the equator to the poles, from the poles to the center of the Earth, and from the center of the Earth back to the equator.
c) The above can be easily verified by rotating a globe filled with a thick transparent liquid.
If you rotate water in a vessel with a thin metal plate at the bottom, the plate will float. https://youtu.be/yGl3JfuQmQE
4. The statement that the Earth's core consists of a solid inner core and a liquid outer core, between which a transition zone is sometimes distinguished, raises doubts. https://dic.academic.ru/dic.nsf/ruwiki/56263
a) How to understand the phrase - "between which the transition zone is sometimes allocated".
b) How it works and works in the transition zone - thermal insulation.
« Last Edit: February 12, 2022, 05:21:20 AM by Fermer05 »
Offline waiukuweather
Re: Earthquake - the result of an explosion of magmatic gases
« Reply #1 on: July 04, 2021, 03:10:30 PM »
just because you believe in something , does not mean it is factual
but that is just what I believe  [tup]
what you are displaying here is pseudoscience
i.e it sounds good, so must be true (but its actually not)
« Last Edit: July 04, 2021, 03:12:12 PM by waiukuweather »
Offline Wskye
« Reply #2 on: July 10, 2021, 10:19:58 PM »
If tectonic plates were constantly moving one on top of the other, then the entire globe would tremble and hum, especially in areas of seismic activity.
It does and I am one of those few who can hear it.
https://www.cnn.com/2020/01/09/world/seismic-hum-volcano-scn-trnd/index.html
https://www.livescience.com/underwater-volcano-hum.html
https://www.theguardian.com/books/2021/jul/07/the-hum-mystery-noise-says-a-lot-about-modern-life
It sounds like a diesel truck engine idling in the distance.  Do a search on Global Hum.
« Last Edit: July 10, 2021, 10:28:45 PM by Wskye »
Offline Wskye
« Reply #3 on: July 16, 2021, 12:45:08 PM »
No the tidal force (the moon's gravity) orbits (rotates) around the Earth causing a high tide on the near side and a medium tide on the opposite side and two low tides on the side perpendicular to the force.  It's too minimal to cause any effect on anything but the water which by comparative to the grand scale of things is also minimal.
Hope I am not walking into a discussion with another flat Earther who knows nothing about anything.
« Last Edit: July 16, 2021, 12:46:55 PM by Wskye »
« Reply #4 on: July 17, 2021, 02:11:52 AM »
actually the plates get stuck/locked in place...when they suddenly unstick,when the pressure gets to breaking point,  that causes an earth quake
there are some places though where they do slip slowly  and produce slow slip earthqaukes which can be detected with special equipment and also the movement detected with GPS
Offline zoomx
« Reply #5 on: July 17, 2021, 02:18:49 PM »
Unfortunately the pattern of first pulse recorded is not that one if the origin would be an explosion.
https://en.wikipedia.org/wiki/Focal_mechanism
Nuclear explosion doesn't show this pattern
https://eos.org/articles/quake-bomb-seismic-waves-speak-truth-even-nations-dont
Offline Fermer05
« Reply #6 on: July 18, 2021, 08:49:49 AM »
Criticism of the tectonic hypothesis.
1. Why do earthquakes occur both at the junction of tectonic plates and in the center of the plate?
2. The assertion that tension is accumulating at the junction of tectonic plates, unsupported information.
a) How much greater is the density of tectonic plates at the junction than in the middle of the plate?
b) Does tectonics affect the rate of well drilling?
3. A seismic wave on the surface of the earth can only be created by an impact, and not by compression of the lithospheric plates.
After compression, the earth's crust is not unclenched, but compacted.
The soil compaction ratio is 95%.
https://buildingclub.ru/kojefficient-uplotnenija/?amp=1
The above can be easily checked by setting up an experiment.
4. If the lithospheric plates were constantly moving one on top of the other, then the globe would tremble and hum, especially in zones of seismic activity.
5. Tectonic plates cannot have the properties of a spring or rubber.
a) this can be easily verified by experiment.
6. What happens to the islands when the continental crust creeps over the oceanic crust?
7. If oceanic lithospheric plates go under the continental ones - how did the fossils of marine animals end up high in the mountains? https://bigenc.ru/biology/text/2704413
a) At the same time, fossils of marine animals are found in Iceland, despite the fact that in Iceland, the lithospheric plates diverge. https://en.ni.is/geology/fossils
b) If the Indian Plate goes under the Eurasian Plate, how did the marine animal fossils end up in the Himalayas?
In the Himalayas, high in the mountains, fossils of land animals should be found. https://proekt7d.ru/okamenelosti/
c) Fossils of marine animals were found on the entire surface of the earth, including in deserts, but they were not preserved everywhere. http://evolution.powernet.ru/history/Earth_04/
d) If fossils of marine animals are found in mountain ranges, this means that as a result of seismic activity, the ridge rose from the ocean floor, like the Mid-Atlantic Ridge.
e) Fossils of marine animals on the surface of the earth - proof that the surface of the earth is not renewed.
8. If mountain systems were formed as a result of collision of lithospheric plates, the mountain systems would have a different shape and would be much higher, since the oceanic or continental crust that descends to the core of the Earth has a high buoyancy. https://autogear.ru/article/287/111/subduktsiya---eto-opredelenie-tipyi-i-protsess-subduktsii/
9. There is no information about the number, speed, direction of movement and size of tectonic plates.
a) if there are 13 lithospheric plates on the Earth, then there should be about 100 tectonic plates.
b) how many tectonic plates are there on the Eurasian lithospheric plate?
c) there is no description of the mechanism of interaction of tectonic plates.
d) Do tectonic plates sink into the Earth's mantle, reaching the depth of the outer core.
10. Why is the epicenter circular rather than elongated along the fault line?
11. Why is the epicenter circular rather than elongated along the fault line?
12. During earthquakes, people and objects that are at the epicenter are strongly thrown up. I believe only an underground explosion is capable of this.
Then, from the epicenter, waves spread in all four directions, due to which the buildings sway like ships on waves.
a) according to the tectonic hypothesis of earthquakes, vibrations from the epicenter should diverge not in four directions, but only in two directions. By forming a horizontal vibration of the earth's crust, which would be extremely destructive.
13. Vibrations from earthquakes are transmitted in the form of seismic waves over a distance of more than 10 thousand km.
a) then why seismic waves do not provoke earthquakes in other regions of the Earth.
http://www.evgengusev.narod.ru/spb/zhirnov-2011.html
14. According to the tectonic hypothesis of earthquakes, a seismic wave moves along the Earth's crust.
And according to the explosive hypothesis, a seismic wave can move both along the earth's crust and under the earth's crust (along magma - like a tsunami wave in the ocean).
https://youtu.be/9bJwTkruL0g
15. The volcano can erupt both upward and towards the core of the earth.
If a volcano erupts towards the core of the earth, then tsunami waves from the volcanic mountain scatter in different directions. https://m.youtube.com/watch?v=U7pNie2403A&feature=youtu.be
b) Perhaps one of these earthquakes occurred in the Sea of ​​Okhotsk, in 2013. Then the seismic tsunami wave reached Moscow. https://uc.xyz/SyD44?pub=link
https://news.ucsc.edu/2013/09/deep-earthquake.html
c) After major earthquakes, the seismic wave goes around half of the globe. I believe that only a seismic tsunami wave, which moves under the Earth's crust, is capable of this. https://www.hmong.press/wiki/1994_Bolivia_earthquake
16. There is also no exhaustive explanation of the mechanism of movement of seismic waves, from the source of the earthquake to the Earth's surface at a distance of more than 700 km.
a) as a seismic wave, moving from the source to the epicenter, over a distance of more than 700 km. falls exactly on the fault line. https://uc.xyz/SyD44?pub=link
17. According to the tectonic hypothesis of earthquakes, the diameter of the epicentral area depends on the depth of the source and can exceed 1000 km.
a) what will be the diameter of the epicentral area if the source depth is 700 km. https://uc.xyz/SyD44?pub=link
b) what will be the diameter of the epicentral region if the earthquake source is located in the center of the Earth?
18. How to explain the fact that all seaquakes occur only at the foot of the islands and continents.
Why, in a clear sea or ocean, seaquakes do not occur.
19. The tectonic hypothesis of earthquakes can be easily tested if two clay slabs are moved towards each other in a basin with water.
It is believed that cells are formed in the mantle, at the junctions of lithospheric plates, in which, due to convection, magma rotates at a speed of 1-5 cm per year.
The assertion that lithospheric plates move due to magma gates that rotate at the junctions of lithospheric plates is questionable.
Thanks to currents, eddies and magma-gates, only pits can form in the earth's crust, and not the drift of continents and "lithospheric plates". https://images.app.goo.gl/yS56u6oYvaMtavLi6
Questions arise:
1. How many cells move the lithospheric plate and how are they synchronized?
b) How are tectonic, lithospheric and continental magma-rotations synchronized? https://images.app.goo.gl/Lf2Xa6tYhE9JF4J99
2. What do magma-turns rely on when moving lithospheric plates?
a) Motion without support, contradicts the two-body problem - Newton's Third Law.
"The force of action is equal to the force of reaction."
b) Moreover, magma-turns themselves will repel from the lithospheric plates in the opposite direction. Since, lithospheric plates are much more massive than magma-rot.
c) oceanic and magmatic currents are too weak to move lithospheric plates or affect the axial velocity of the Earth.
d) the rotation of the planets, due to internal forces, contradicts the elementary laws of mechanics.
3. The width of the crack of the Mid-Atlantic Ridge is several meters, and the distance between the continents is several thousand kilometers.
4. The total length of the Mid-Atlantic Ridge is more than 18 thousand km. and is broken by transverse faults up to 600 km long.
https://images.app.goo.gl/cHbdb1i6RSeqDe7z6 https://uc.xyz/Xc1Ki?pub=link
a) what is the total length of the magma gate, under the Mid-Atlantic Ridge, and how does the magma gate affect transverse faults? https://images.app.goo.gl/cqn26EqbMcoqATp66
5. In North America, the movement of the Juan de Fuca ridge was observed for two years: no movement of the ridge was found. https://uc.xyz/10W5re?pub=link
a) No long-term data for the Mid-Atlantic Ridge, although the ridge is inland in Iceland. https://images.app.goo.gl/vabkhhfCca979hDJ9
6. Why, along the perimeter of the Atlantic Ocean, did not a ring of fire form, as in the Pacific Ocean? https://uc.xyz/10L8Sq?pub=link
7. Quote from Wikipedia: "Continents do not float on the oceanic crust, but move along the mantle, being passively soldered into lithospheric plates." https://uc.xyz/104XGE?pub=link
a) This means: "Continents do not move along the oceanic crust, but move along the mantle, on the oceanic plate."
At the same time, it is believed that the continents do not move on lithospheric plates.
b) How to understand the phrase "passively soldered".
It is believed that over hundreds of millions of years, the Earth's surface has been constantly changing, supercontinents formed and disintegrated.
The supercontinent Rodinia disintegrated about 750 million years ago. Then it formed and broke up into six continents - the supercontinent Pangea. https://uc.xyz/YBUBk?pub=link
Questions arise:
1. For Pangea to form, magma-convection currents must move to one point, and for Pangea to disintegrate, magma-convection currents must turn around.
a) How does the mechanism of reversal, magma-turns work?
2. In which sea did the Amazon and Congo rivers flow before the collapse of Pangea?
a) What mark did this sea leave?
3. Huge streams - water and air drift across the Earth with a specific purpose. And for what purpose are the continents drifting?
4. I believe that the evolution of the Earth was accompanied not by the drift of continents, but by a change in the inclination of the Earth's axis, due to which thermophilic plants and animals lived beyond the Arctic Circle.
For this reason, the remains of thermophilic plants and animals are found in Antarctica.
5.https://images.app.goo.gl/wJhvfGJ88jwUrKT86
The animation shows India crossing the equator and moving north, despite the magma gate cell remaining in the southern hemisphere.
a) The assertion that India is sailing from south to north at a speed of 4 cm per year, like an icebreaker in the ocean, is questionable.
b) With what speed and what was India sailing northward, before the collision with Eurasia? https://en.m.wikipedia.org/wiki/Subduction
6. It is believed that India, having collided with the Eurasian plate, turns 90 degrees and moves towards the core of the earth.
a) Why do not cracks form at the place of bending of the slab?
7. It is believed that when the oceanic plate goes under the continental, a depression is formed with a depth of more than 10 km. https://uc.xyz/15U4Da?pub=link
a) At the same time, most of the depressions in the oceans are too far from the continents and they are not everywhere. https://uc.xyz/16caO0?pub=link
b) If India goes under the Himalayas, why did not a depression or a reservoir form at the foot of the Himalayas?
https://images.app.goo.gl/EkLp3TDpVYcBf3MB8 https://images.app.goo.gl/pA2CmLgYpje7SzWC6
https://neftegaz.ru/tech-library/geology/148157-kraevoy-progib/
8. What plate goes under the Ural Mountains, and what depth was formed at the foot of the Ural Mountains? https://uc.xyz/15U2dY?pub=link
a) Is there a shear movement of plates in the south and north of the Ural Mountains? https://slide-share.ru/kak-dvizhutsya-litosfernie-pliti-69693
b) The Ural Mountains - a seismically active crack, which diverges at a rate of 0 to 5 mm per year, and not the result of "plate compression".
9. It is believed that the Eurasian, Indian and Philippine plates compress Lake Baikal.
a) Then why do the shores of Lake Baikal diverge at a rate of 2 cm per year.
10. There is an opinion that Lake Baikal was formed as a result of the divergence of the fault line at a rate of 2-4 cm per year.
a) Then why didn’t Baikal form along the entire fault line, both in length and in depth?
b) With what speed does the bottom of Baikal diverge?
c) What is the bottom of Baikal based on if the width of the fault under Baikal is several tens of kilometers?
https://uc.xyz/114cQG?pub=link https://uc.xyz/119ET4?pub=link
11. It is possible that deep-sea lakes, seas and rivers, as well as depressions in the oceans, are the result of successive explosions in a ridge crack followed by a sinkhole. https://uc.xyz/119hVG?pub=link
a) After the formation of lakes, the banks should converge, not diverge. https://uc.xyz/119hVG?pub=link
12. Perhaps the Red and Adriatic seas, lakes Baikal and Tanganyika were formed as a result of the collapse of the earth's crust. https://uc.xyz/11k3W8?pub=link
13. The assertion that lithospheric plates compress Africa from the east and west, thereby splitting Africa in two, is contrary to elementary logic. https://foxford.ru/wiki/geografiya/pliti-litosferi
a) If the East African Ridge is splitting for more than thirty million years at a rate of 1 cm per year, why is the crack width 3 meters, not 30 km.
b) The East African Ridge is a seismically active crack, which diverges at a rate of 0 to 2 mm per year, and not the result of "plate movement". https://wikiboard.ru/wiki/East_African_Rift
Continuation: Forum of Akademgorodok Novosibirsk. The science. https://forum.academ.club/index.php?showtopic=1235578
Forms of the Nizhny Novgorod State University named after N.I. Lobachevsky. http://forum.unn.ru/viewtopic.php?f=39&t=10331&sid=cfbc49e0cf32263eff20888ca205ab15
« Last Edit: April 29, 2022, 04:35:07 AM by Fermer05 »
« Reply #7 on: July 18, 2021, 04:57:23 PM »
yes there is likely gases released prior and also during an earthquake
and those can even get ignited or glow
search for strange lights etc during earthquakes
and yes there is likely an increase in things that humans cant detect that animals can
but all that detracts from the subject thread (which is not what actually occurs)
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #8 on: July 18, 2021, 05:52:26 PM »
it is possible that the behavior of some animals is influenced by gases that escape from the cracks, as a result of which the animals leave active faults.
I am going to say, I highly doubt it.
Walking in winter my dog sat and refused to continue. Momentarily a large snow/ice chunk slid off the metal porch roof, onto the sidewalk ahead of us.
I  am sure there was no gas release, he felt the vibrations of it cracking loose.
« Reply #9 on: July 18, 2021, 08:18:09 PM »
https://en.wikipedia.org/wiki/Earthquake_light
but they could be just transformers blowing like during a tornado (called power flashes) (due to power poles moving apart in the earthquake and breaking the wires sort of thing(
« Last Edit: July 18, 2021, 08:25:50 PM by waiukuweather »
Offline Fermer05
« Reply #10 on: July 24, 2021, 09:26:29 AM »
German scientists, who have been studying the behavior of ants at different periods of seismic activity for a long time, concluded that they radically changed their life schedule only on the eve of an earthquake, the strength of which is at least 2 points. According to scientists from the University of Duisburg, a stable change in the phases of activity and calmness was found in the behavior of the ants: a few hours before the earthquake, instead of the sleep phase, a burst of activity occurred, and the next phase of activity did not occur during the day. According to experts, this is due to the fact that a toxic gas can be released before an earthquake, which is invisible to humans, but affects the behavior of ants.
« Last Edit: October 19, 2021, 07:31:32 AM by Fermer05 »
« Reply #11 on: July 25, 2021, 01:23:14 AM »
sure trapped gases might be released just prior and during an earth quake
but the earth quake is not caused by an explosion of magmatic gases
unless maybe you are talking about volcanic earth quakes and not tectonic ones
Offline Fermer05
« Reply #12 on: August 04, 2021, 05:47:19 AM »
Why, in a clear sea or ocean, seaquakes do not occur. https://en.m.wikipedia.org/wiki/Seafloor_spreading
« Reply #13 on: August 07, 2021, 03:21:49 PM »
that is rubbish
there are lots of earth quakes that occur in the pacific ocean along the fault lines, and which can cause Tsunamis
but the problem with your reasoning is you are missing the point.. the island chains are there in the oceans because of the tectonic platest colliding on fault lines
Offline Fermer05
« Reply #14 on: August 09, 2021, 12:55:58 PM »
It is possible that the combustible mixture is formed as a result of degassing of the earth's mantle.
https://www.geokniga.org/books/22927
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #15 on: August 09, 2021, 02:51:33 PM »
It's possible there are thousands of quadrillions of dollars of precious metals in asteroids for the taking......but neither that nor anything here disproves plates moving, slipping, and quaking.
« Reply #16 on: August 09, 2021, 04:16:09 PM »
all i see from you Fermer05 is pseudoscience
i.e where you formulate a theory to explain your observations, and it sort of works, so you think it must be true
but there is already a extemely well established and accepted and peer review testable theory to explain earthquakes: plate tectonics
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #17 on: August 09, 2021, 07:38:34 PM »
There is even easy to see hard evidence of plates moving. [ You are not allowed to view attachments ]
« Reply #18 on: August 09, 2021, 11:22:51 PM »
and I think I know where that photo was taken too lol
Offline Fermer05
« Reply #19 on: September 16, 2021, 02:51:10 PM »
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • Living in the "Last American Frontier"
Offline Fermer05
« Reply #22 on: September 16, 2021, 08:00:12 PM »
Offline Fermer05
« Reply #23 on: September 16, 2021, 08:11:20 PM »
Offline Aardvark
« Reply #24 on: September 27, 2021, 08:40:37 AM »
I get the same effect eating at Taco Bell.
