Author Topic: Davis FARS Board  (Read 754 times)
Offline dazza
Davis FARS Board
« on: March 18, 2021, 10:14:53 AM »
hi i hade some water on Davis FARS board and i need to get new Resistors but as it got reck in water it hard to see what the kind off Resistors i need ?
Offline azchrisf
Re: Davis FARS Board
« Reply #1 on: March 20, 2021, 02:54:59 PM »
Look at the color bands on the resistor, that can be entered online to tell you what it is. New boards are about 15 bucks if you can’t find resistors locally.
Also doing Soil and Leaf 4x
Offline dazza
« Reply #2 on: March 22, 2021, 06:16:05 AM »
ok i can only find one off then um where did u see if u can get the board for £15 as i olny see them as £40?
Offline azchrisf
« Reply #3 on: March 22, 2021, 10:18:32 PM »
Sorry I was incorrect on the price...bad memory :-(
Anyways R3 appears to be 0.5 ohm, R1 I can't tell if the first band is orange or brown, it's either a 0.1 or 0.3 ohm resistor.
Both are +/- 5% tolerance carbon resistors, not metal film (blue colored).
The diode is a 1N400x.
« Last Edit: March 22, 2021, 10:21:26 PM by azchrisf »
Offline dazza
« Reply #4 on: March 23, 2021, 05:46:35 AM »
hi i have a pack off them
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  will this be ok ?
https://www.ebay.co.uk/itm/1-4W-Metal-Film-Resistors-1-186-values-available-20-Pack-UK-Seller-Free-P-P/263898843941?ssPageName=STRK%3AMEBIDX%3AIT&var=563456881007&_trksid=p2057872.m2749.l2649
Offline azchrisf
« Reply #5 on: March 23, 2021, 11:41:55 AM »
No the resistance value is way too high. Those are a 100x more resistance than what's on the board.
You'll need to get the correct values or spring for a new board.
Offline dazza
« Reply #6 on: March 23, 2021, 11:57:25 AM »
ok im relly not good at all this can u pont me to ebay to get the right one plz?
Offline azchrisf
« Reply #7 on: April 03, 2021, 05:13:14 PM »
https://www.scaledinstruments.com/shop/davis-instruments/parts/vantage-pro2-parts/radiation-shield-parts/davis-7315-053a-pro2-24hr-spars-pcba-circuit/
That’s the one I remember for $15
His picture Is older but you will receive the same as you have that doesn’t have as much stuff on it.
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #8 on: April 03, 2021, 08:35:31 PM »
Hey dazza, I see the FARS PCB board is down in price,  https://weatherspares.co.uk/collections/davis-instruments-spare-parts/products/393
Regards Simon
Offline dazza
« Reply #9 on: April 04, 2021, 06:14:46 AM »
hi thank u for that i just orded  one god the new battery are a lote any cheaper one anyone knows off?
