Author Topic: Deciphering Error File  (Read 580 times)
Offline rlee171
« on: March 16, 2021, 12:57:42 PM »
I have a problem with my Cumulus Graphs updating, original topic https://www.wxforum.net/index.php?topic=41704.0. I am continuing my issue here because it is not related to Cumulus (Cumulus is updating properly). It finally dawned on me to look at my error logs. There are a host of errors but I am going to post a few that may or may not be related to my graphs not updating, but primaily as an example of how I do not understand how the error log functions. I believe it is my lack of understanding how the errors are generated. Possibly someone can explain to me how the errors process works, in other words, when a script is running and has an issue it reports that to the error file. The reason I am asking is when I look at the specific line # in the .php file referenced I don't see a problem, hence it is not the specific line in the code but when the code is executed. I am posting an example of some errors and then those error lines in the file referenced. I cannot see the error. This is all as clear as mud to me. Would someone explain how to decipher an error in the log file so I can use that information to actually attempt to find the problem.
Thanks in advance.
Error file:
/wxwugraphs/WUG-settings.php:
WU-History-inc.php:
Edit: The above example is not related to my wxcugraphs not updating, but more of a general question about how to use our error file to help understand where the problem actually exists.
« Last Edit: March 16, 2021, 01:17:13 PM by rlee171 »
Davis VP2
Blitzortung Stations: 1387  1445  2315
Cumulus
GRLevel3
Re: Deciphering Error File
« Reply #1 on: March 16, 2021, 01:36:06 PM »
Getting old code to behave can be a challenge.   Here's some thoughts about the specific errata you cited:
1) for "Undefined variable/index" errors, add a check to see if it is defined before using it.
Example:  instead of
if ($_GET['lang']) {
use
if (isset($_GET['lang']) ) {
and for the other one cited:
if ($_GET['i'] != '1' && $thisPag == 'graph') {
use
if (isset($_GET['i']) && $_GET['i'] != '1' && $thisPag == 'graph') {
For the non well-formed numeric value error, somewhere in the code the AddDate() function is being called with one of the variables ($month,$day,$year,$numdays) not having a number in it.  That will have to be chased down in the code.
« Reply #2 on: March 16, 2021, 02:18:04 PM »
In a browser, you can enable the Developer Tools, and it can show lots of information to you.  It won't display PHP errors per se..those are only in the error_logs on the server (and depending on your PHP settings, appear inline on the HTML page in the browser).
You can use the Developer Tools in the browser to spot missing images/css/js files (404s), and do some debugging with the page's CSS and JS.
In Firefox, enable the tools via CTRL-SHIFT-K (or menu Tools, Web Developer, Web Console).
Offline rlee171
« Reply #3 on: March 16, 2021, 03:07:07 PM »
Ok..  I will use those 'tools'
One more question about your original response.
« Last Edit: March 17, 2021, 10:50:50 PM by rlee171 »
Davis VP2
Cumulus
GRLevel3
Offline rlee171
« Reply #4 on: March 16, 2021, 11:35:23 PM »
I have scoured the script at least a dozen times and the following are all I can find relating to AddDate...   Unfortunately I wouldn't be able to tell if something is wrong with them or not.
Searching for problem as suggested, error added towards end
In Settings:
$Ltarget   = array("Day", "Week", "Month", "Year");
In Script:
if ($mode == 1) {
   $ndate = AddDate($mo, $da, $yr, -1);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode . '">&laquo; ' . $Lprev . ' ' . $Ltarget[0] . '</a --></td>';
} elseif ($mode == 2) {
   $ndate = AddDate($mo, $da, $yr, -7);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode  . '">&laquo; ' . $Lprev . ' ' . $Ltarget[1] . '</a --></td>';
} elseif ($mode == 3) {
   $ndate = AddDate($mo, $da, $yr, -30);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode  . '">&laquo; ' . $Lprev . ' ' . $Ltarget[2] . '</a --></td>';
} elseif ($mode == 4) {
   $ndate = AddDate($mo, $da, $yr, -365);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode  . '">&laquo; ' . $Lprev . ' ' . $Ltarget[3] . '</a --></td>';
if ($mode == 1) {
   $ndate = AddDate($mo, $da, $yr, +1);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode . '">' . $Lnext . ' ' . $Ltarget[0] . ' &raquo;</a --></td>';
   $ndate = AddDate($mo, $da, $yr, +7);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode  . '">' . $Lnext . ' ' . $Ltarget[1] . ' &raquo;</a --></td>';
   $ndate = AddDate($mo, $da, $yr, +30);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode  . '">' . $Lnext . ' ' . $Ltarget[2] . ' &raquo;</a --></td>';
   $ndate = AddDate($mo, $da, $yr, +365);
   echo '<td class="nobr noprint"><!-- a href="' . $_SERVER['PHP_SELF'] . '?ID=' . $WUID . '&amp;month=' . $ndate['mon'] . '&amp;day=' . $ndate['mday'] . '&amp;year=' . $ndate['year'] . '&amp;units=' . $units . '&amp;mode=' . $mode  . '">' . $Lnext . ' ' . $Ltarget[3] . ' &raquo;</a --></td>';
// End of the script all functions follow
Function with error
function AddDate ( $month, $day, $year, $numdays) {
   $nday = $day + $numdays;
   $newdate = mktime (0,0,0,$month,$nday,$year);      (line 1431 in error list shown above)
   return getdate($newdate);
/*   Returns Array (
    [seconds] => 40
    [minutes] => 58
    [hours]   => 21
    [mday]    => 17
    [wday]    => 2
    [mon]     => 6
    [year]    => 2003
    [yday]    => 167
    [weekday] => Tuesday
    [month]   => June
  •        => 1055901520*/
« Last Edit: March 17, 2021, 10:46:59 PM by rlee171 »
Davis VP2
Cumulus
GRLevel3
« Reply #5 on: March 22, 2021, 02:00:36 PM »
I just released an update to WU-History-inc.php (V3.4h - 21-Mar-2021) that fixes that problem.
Download from https://github.com/ktrue/WU-history or from https://saratoga-weather.org/WU-History-inc.php?sce=view
