Author Topic: Software to grab a (portion) screen image and save for uploading?  (Read 482 times)
Offline DaleReid
    • Weather at Eau Claire, WI
I'm far from a programmer, but wonder if there is a commercial program that will do the following, with minimal fuss on my part, or something that is in the public domain for use.
I anticipate that a hardware piece I have will show up shortly and when installed, a program runs monitoring the unit and generating a fixed sized (not full screen) image of the status of the device.
I want to grab a .jpg of that (the software they provide unfortunately doesn't do that right now, sort of a screen grab) and take that stored image and FTP to my web site.  I'm checking for sure, but I think that Weather Display, which I use to make the base page, can upload additional images such as a web cam image, etc.
If that is the case, then if I can grab the graph that this device makes,I could send it to my web page for monitoring when I'm away from home.  I imagine there is such a utility as this, but don't know what to look for or try.  If the device would generate an image, I'd be golden, since it would be similar as to having NexStorm or Lightning2K do a screen shot of itself and save it to a chosen directory which I then uploaded.
Is there a utility that someone has heard of or uses that might work for my needs?
Dale
ECWx.info
ECWx.info/t/index.php
Re: Software to grab a (portion) screen image and save for uploading?
« Reply #1 on: March 04, 2021, 10:37:57 PM »
Autoit
Offline vdeal
« Reply #2 on: March 05, 2021, 01:43:18 PM »
You could always take a picture of the screen with a cell phone.
Offline DaleReid
« Reply #3 on: March 05, 2021, 06:24:43 PM »
Yes, but then my fingers would get sore from pushing the button!
And I get cranky when I loose sleep during storms I'm trying to capture. :grin:
ECWx.info
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« Reply #4 on: March 05, 2021, 06:38:32 PM »
I use https://getsharex.com/
It takes a picture of part of my desktop on a extra computer I have that has a program up that shows my smart UPS info https://www.desotowiwx.com/wxstatus.php
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #5 on: March 05, 2021, 08:21:11 PM »
I also vote for ShareX!
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline TrugWX
  • Senior Meteorologist (ret), Bureau of Meteorology
  • Truganina Weather
    • Truganina Weather
« Reply #6 on: March 05, 2021, 09:58:38 PM »
MWsnap ( http://www.mirekw.com/winfreeware/mwsnap.html )
This software allows you to take all or part of a screen, and even set up dimensions for frequent grabs.
Live Weatherwall for 5 minute weather updates at Truganina
Offline Tln7559
  • Slangenbeek
    • Weather&PV Hengelo_Slangenbeek
« Reply #7 on: April 05, 2021, 04:44:48 AM »
Does your meteo-software generate graphic files and locally store them in a folder?
Then several ways possible for upload:
1) if the meteo-software has an integrated (s)ftp-function, use it to upload the desired graphic file to the webserver
2) if running the meteo-software on a Raspberry (but without integrated (S)FTP-function),
then you might add on that Raspberry a separate (S)FTP-funtion or use RSYNC to perform the grab&upload function
3) if 1) or 2) is not applicable as ready 'inside-assistant',
then you might use auxiliary, external sync-software to 'grab' the file from the meteo-processor for subsequent upload to your webserver. Examples for such software are WinSCP, AllwaySync and SecondCopy [all running on Windows_PC].
« Last Edit: April 05, 2021, 04:56:43 AM by Tln7559 »
Sensors: TFA_Nexus + WS7000 + Tempest + DIY
Software: WsWin + Domoticz
