Author Topic: Writing software which ensures short term gusts are not missed  (Read 1792 times)
Offline Plainwind
« on: February 20, 2021, 12:37:07 PM »
In extreme wind conditions, the duration of gusts can be very short, typically much less than 1 second.  How can software be designed to avoid missing gusts?  For example, if my software is designed to continuously monitor wind speed but also periodically do some mean and max calculations and append a record to a database, how can I write my software to be sure that during the time it's doing the calculations and database append, no short duration gusts are missed?  By the way, I'm writing my code in Python and running it on a Raspberry Pi.
Offline davidg_nz
    • Sandy Bay Weather
Re: Writing software which ensures short term gusts are not missed
« Reply #1 on: March 03, 2021, 10:39:41 PM »
What sort of weather station are you talking to? Trying to measure an anemometer directly hooked up to one of the Pis GPIO pins or receiving data from an off-the-shelf weather station?
Port Charles, Coromandel, New Zealand | Wired Vantage Pro2+, Ubiquiti AirCam
Hamilton, Waikato, New Zealand | Wireless Vantage Pro2+, 24h FARS, Leaf+Soil Station, Envoy
Offline Mattk
« Reply #2 on: March 04, 2021, 05:32:38 AM »
Depends on your definition of what a wind gust is? This is going to be where the problem lies.
Offline Plainwind
« Reply #3 on: March 06, 2021, 03:20:05 AM »
Thanks for replying.  To answer your question - my sensors, including the anemometer, are currently directly connected to GPIO pins.  To calculate windspeed, I'm counting the rotations using Button().
However, having given this more thought, I think I can answer my own question.  Rather than connecting the anemometer direct to the Pi, I need to incorporate a data-logger which continuously monitors the anemometer output, regardless of what processing the Pi is doing.  So, I need to do some research on data-loggers and how to put a data-logger between the sensors and the Pi.
Offline Plainwind
« Reply #4 on: March 06, 2021, 04:11:03 AM »
So, I'm going to look at threading in Python with a view to using the Raspberry Pi to simultaneously be both a real-time data-logger and a device for processing and analysing the raw data collected by the data-logger.  Any pointers to help on this appreciated.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #5 on: March 06, 2021, 09:45:38 AM »
The problem is in your sampling rate. That is how gusts are missed. The higher the sampling rate the better way to catch a gust but the downside is the higher amount of data recorded approaching analog. The best way is to have a separate routine running that has a trigger with a limit where it determines if a gust is occurring and then starts the logging process.
Offline Plainwind
« Reply #6 on: March 07, 2021, 06:04:00 PM »
Garth, thanks for this insight.
Yes - I see what you mean.  Measuring wind speed digitally, i.e. by counting anemometer rotations over a given duration, say 1 second, has the limitation that it will not capture a gust of duration less than 1 second.  So, to be sure of capturing the true speed of a gust, you need either a method which produces multiple pulses per revolution (e.g. a slotted disk - like Vector Instruments) or a truly analogue method which represents wind speed by the magnitude of a voltage.
Offline sky_watcher
« Reply #7 on: March 08, 2021, 01:28:40 AM »
Ever considered using an interrupt driven counter? I do that on an Arduino for a radiation counter, so I can't imagine it won't work on a Pi.
If you are really serious about not missing anything, set up a hi-res counter-timer clock and record the time from that device each the interrupt fires. Within the resolution of the clock and physical limits of the anemometer, you can then calculate the instantaneous wind with just two anemometer pulses.
“The more a man knows, the more willing he is to learn. The less a man knows, the more positive he is that he knows everything...” ― Robert G. Ingersoll
Offline Mattk
« Reply #8 on: March 08, 2021, 02:58:57 AM »
The question still remains? What is a wind gust and how do you define it? At what point does all this become impractical and meaningless?
Offline sky_watcher
« Reply #9 on: March 08, 2021, 05:16:23 AM »
If you want to use the World Meteorological Office (WMO) standard definitions, just google their observational standards. It discusses things like the 3s Peak Average, the 10-min standard observation average, and so on.
If not, use whatever takes your fancy.
Offline Cutty Sark Sailor
« Reply #10 on: March 08, 2021, 06:59:54 AM »
Perhaps calculate your custom Gust definition based on maximum windspeed in sample period and/or data update period. More samples / shorter period will improve 'reolution'. Average as desired... say 20-50 samples per minute, database update 1 minute. you'll be limited by sensor's design, getting under one second period likely problematic off-the-shelf????. Get large storage device(s) for records. :)
Offline doubleohwhatever
« Reply #11 on: May 12, 2021, 01:03:20 PM »
I know this is an older topic but I just came across it and what the OP wants to do is fairly easy with a solution that hasn't been mentioned yet.
Alright, so definitions of "gust" aside, the goal here seems to be to log max/peak wind. To do this I would recommend going to with an ultrasonic anemometer like the ResponseOne 91000 from Young. I'm 100% sure there are other suitable makes/models out there but I *know* this model will work for this application.
With the 9100 you can set it to continuously output the readings every X milliseconds via RS-232 or RS-485. I've tested the similar Young 92000 down to 200ms. Most dataloggers including WeeWx on Raspberry Pi, store data as archive records every x minutes and record the low, high, and average value for the archive period as well as the timestamp for those values (low/high/average). You won't have to worry about large amounts of data being stored.
BTW, if you do decide to go the voltage output anemometer route, keep in mind that there will be a voltage loss between the anemometer and the datalogger. That voltage loss will vary based on the temperature. I tend to avoid those units when peak readings are important.
