Author Topic: Space Weather Template  (Read 416 times)
Offline vinesweather
  • Firefighter
  • Be patient...I'm a firefighter not a computer whiz
    • The Vines Weather
« on: February 17, 2021, 04:09:48 AM »
Hi All
Is there an update for the Space Weather script? I get errors for Solar X-ray Flux and Satellite Environment Plot.
https://vinesweather.com/wxspace.php
Many thanks
Chris
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Space Weather Template
« Reply #1 on: February 17, 2021, 05:17:28 PM »
« Last Edit: February 17, 2021, 05:21:54 PM by ConligWX »
Regards Simon
Davis Vantage Pro2 Plus (6162UK) Daytime FARS WeatherLink Live AirLink PurpleAir PA-II-SD CumulusMX
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #2 on: February 17, 2021, 05:21:36 PM »
Regards Simon
  • Firefighter
    • The Vines Weather
« Reply #3 on: February 18, 2021, 07:26:18 AM »
Many thanks mate. Spaceweather still broken. I'll probably delete and just have a link to NASA
I'll update my uv files.
Appreciate the help.
Cheers
Chris
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #4 on: February 18, 2021, 08:54:27 AM »
did you download both files and dump all content into your web server?  they should just work.
AuroraFix.zip should be last to be dropped in.
if you post in the https://www.wxforum.net/index.php?topic=40479 thread @K6GKM maybe able to help.
« Last Edit: February 18, 2021, 08:59:59 AM by ConligWX »
Regards Simon
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #5 on: February 18, 2021, 09:04:55 AM »
try this, extract ALL contents to your main web folder
Regards Simon
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #6 on: February 18, 2021, 01:53:56 PM »
Could you upload your current wxspace.php file here either as a .txt or zipped?  It looks as if all the image links have been jumbled... not sure exactly what happened there.  :-k
Easiest thing to do is what ConlinWX suggested... replace your script package with the fresh copy.  I believe he posted a .zip package above, if that doesn't work, here's mine.
Replace everything in your server with these files and hopefully all should right itself.
Good Luck!
Grant Miles - Camarillo, CA, USA
Owner/Admin - CamWX.com
SKYWARN Spotter
Davis Vantage Vue, WD, GRLevel3
