Author Topic: Multiple Server type uploads fail WOW + Custom  (Read 300 times)
Offline wardie
« on: January 08, 2021, 05:14:01 PM »
I donít know if this is a known issue Iíve missed, user error or a niche problem that needs fixing. Is there some sort of limit of how many different type of server uploads any given console can do?
Iíve notices that if I program any of my consoles to try and upload to both the WOW website and the Custom Server,
This works:
GW1000: Ecowitt ON, Wunderground ON, Weathercloud OFF, WOW OFF, Customised ON
HP2551C: Ecowitt ON, Wunderground OFF, Weathercloud OFF, WOW ON, Customised OFF
But if I switch the WOW ON on the GW1000 instead of HP2551C, the Custom Upload on GW1000 fails to work (even though itís switched on). I think it may be some coding / software error as Iíve noticed that when this happens the Customised ďPathĒ field seems to get wiped. So to make it work I have to go switch off the WOW upload and als add back the field contents for Customised Path. From what I remember previously, I noticed the same behaviour on HP2551C and prior WH2910C I think - but Iíd need to go double check.
Any ideas?
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
