Author Topic: Cumulus MX Raspberry Pi - Help Please  (Read 333 times)
Offline PCM
  • Newark Novice.......
  • Very New to this,
« on: January 03, 2021, 08:12:29 AM »
I have CumulusMX  up on Raspberry pi. Version - Cumulus MX v3.9.4 build 3099, 30-Dec-2020
I also have CumulusMX running on windows laptop. Working and updating with Ecowitt GW1000 - Updating and running fine.
The raspberry pi installation is not updating. All display readings remain at 0.0
The last station update remains at 00:00:00 and flashes from green to red.
I have gone through ALL of the settings on the Raspberry Pi and checked they are the same as the windows working installation.
I believe they are the same yet Raspberry Pi does not update.
If anyone has a suggestion I would be grateful.
Cordially
Online galfert
Re: Cumulus MX Raspberry Pi - Help Please
« Reply #1 on: January 03, 2021, 08:30:13 AM »
Did you try stopping and restarting after making changes? I also prefer to uncheck the GW1000 auto detection option and just manually select the IP address of my GW1000. It gets consfussed with other consoles that are not my GW1000. I prefer to make a DHCP reservation for the GW1000 so that it always is guaranteed to have the same IP address.
Offline PCM
  • Very New to this,
« Reply #2 on: January 03, 2021, 09:10:16 AM »
***** ( Five Stars )
You should get a job in IT.......that is always first thing our IT help desk at works says.....
All working......
Just to recap for someone else.......
Uncheck Auto discovery & Check Dongle IP address is correct....
Thats a wrap.
