Hi Boris,
I've sent a separate mail, but I also think that the issue is worth being documented here.
the WH45 sensor or sensors (5 "pieces"), are displayed very peculiarly in the live data.
I think, there is still some streamlining necessary.
e.g. (see 1st picture) 338.0 looks like CO2 concentration and appears at Leak ...
Air #2 is probably the PM25 sensor of the WH45 - would fit ...
and then there is a lot of Soil#2x and Sol#3x data - actually too much.
Maybe the API (due to lack of comparison, the WH45 is brand new and I have one of the first models) "slipped" a bit here.
Brian Hamilton with his Weather Display ran in earlier times also in a similar issue, when there were new, previously unused sensors. (PM2.5, SM: WH41/43, WH51).
At Ecowitt the 5 sensors run with the prefix CO2-.
With the Min/Max display it is somehow even more confusing - there are missing entries (CO2) or 2 different PM2.5 sensors (WH41 and WH45)
appear with the same values (here 24 µg/m
3), which is not correct.
You can find the (my) current correct values under:
https://www.ecowitt.net/home/index?id=34418Not that this would help you, but weewx runs in a similar (even worse) issue - it crashes. Deactivating the sensor and restarting the GW1000 is the only remedy so far.
Meteobridge at least doesn't crash
- just shows additional rubbish so far.
If you need more info or want to connect to my test system, let me know. My email should be in your contact list.
