Author Topic: W56868  (Read 1508 times)
Offline somename t
W56868
« on: December 30, 2020, 04:18:58 AM »
Hello,
having some issues with out door sensor, resently started showing -40 degrees, i opened sensor it sems to have some water damage, tryed to clean it but sensor seems to be damage, maybe anyone know where can i get spare parts or how can i fix it ?
Offline somename t
Re: W56868
« Reply #1 on: January 02, 2021, 02:58:41 AM »
Maybe someone has any ideas ?
Re: W56868
« Reply #2 on: January 02, 2021, 07:26:48 AM »
That doesn't look fixable to me. That looks like a heck of a job even for someone skilled in SMD soldering. Probably best to find a replacement, not for the sensor, but for the station.
Offline somename t
Re: W56868
« Reply #3 on: January 02, 2021, 07:33:11 AM »
i thought so too but i think only temperature sensor is broken, it still works and send signal
Re: W56868
« Reply #4 on: January 02, 2021, 08:11:11 AM »
Well the temperature and humidity sensor is that little black square looking thing with a hole in the middle. Looks like a Sensirion SHT30 most likely. But the problem could be any of the other supporting SMD parts.
« Last Edit: January 02, 2021, 09:15:31 PM by galfert »
Offline somename t
Re: W56868
« Reply #5 on: January 02, 2021, 07:48:28 PM »
maybe you know where i can get a replacement ?
Re: W56868
« Reply #6 on: January 02, 2021, 09:11:01 PM »
Digikey or Mouser. I'm in the US....don't know if that helps. But if you don't have the means or knowhow to do SMD soldering...then this fix is not for you.
