Author Topic: Gaps in temperature and humidity data  (Read 412 times)
Offline JCA433
« on: November 22, 2020, 08:02:40 AM »
Large gaps with temperature and humidity graph data started appearing November 16 and have continued since.   There are no gaps with the wind speed /direction data.  Anyone else with similar problems?  There are no problems with weather data received by the indoor console.  I am using Mateobridge
Offline JCA433
Re: Gaps in temperature and humidity data
« Reply #1 on: November 22, 2020, 09:08:44 AM »
I removed the weather station from the mounting pole and found ant infestation in the transmitter.   The ants were very small and numerous . Not sure if this was the problem with date reception though. After remounting the Davis weather station, I applied tangle foot to the mounting pole
