Author Topic: Solar powered remote WX station  (Read 5381 times)
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« on: November 12, 2020, 10:19:05 PM »
Here's my latest project, a solar powered station using ham radio to link to my base station. It uses an Ambient WS-2902 array, Ecowitt GW1000, and a raspberry pi zero running WeeWx. It's currently in my back yard, hopefully next year it'll be on a hill overlooking a cornfield.
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
Offline vreihen
  • El Niņo chaser
  • K2BIG
Re: Solar powered remote WX station
« Reply #1 on: November 13, 2020, 07:32:15 AM »
Out of curiosity, how does the VV-898 perform as an APRS transceiver?????
Offline rlee171
« Reply #2 on: November 13, 2020, 10:28:36 AM »
Very nice job!   Specs on the solar panel?
Davis VP2
Blitzortung Stations: 1387  1445  2315
Cumulus
GRLevel3
Offline WA4OPQ
« Reply #3 on: November 13, 2020, 01:11:47 PM »
It works quite well in a rural location. Low current draw and good sensitivity. I would not recommend it in suburban or city settings, however.
It's a 30W Newpowa panel. I thought it would be adequate for a station that draws 3.5 watts, but I appear to be mistaken. I am going to upgrade it to a 75 watt panel.
Offline roc121
« Reply #4 on: February 11, 2021, 09:58:01 AM »
This is really cool.
Offline WA4OPQ
« Reply #5 on: February 11, 2021, 11:22:48 AM »
Update:
I have made some modifications after testing. My previous method of burying the battery flooded so a larger battery is in a vault with good drainage. It now has a 75 watt panel and the solar controller has been moved into the cabinet.
I have also installed a voltage and current sensor and can read five parameters through telemetry. As a test I disconnected the solar panel and found that the battery alone will run it for 5 days and 20 hours.
« Last Edit: February 17, 2021, 11:04:56 AM by WA4OPQ »
Offline josecmorales
« Reply #6 on: February 17, 2021, 08:45:50 AM »
Great setup, would you mind to explain all you can did it (a little guide how to)
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #7 on: February 17, 2021, 09:08:55 AM »
Underground battery?
Keeps it warm?
« Reply #8 on: February 17, 2021, 09:27:00 AM »
Keeps it warm?
I dont think warm, maybe an stable temp.
Offline WA4OPQ
« Reply #9 on: February 17, 2021, 10:58:50 AM »
Thank you. It has turned out to be a much larger project than I envisioned. I am in the process of documenting all of it. I hope to have it published in QST, the journal for Amateur Radio in the US. If so I will supply a link or copy here.
As a note on the progress: My battery will power the station for almost six days, so of course Mother Nature tested me with eight cloudy days. I'm now working on a small UPS and shutdown device for the pi.
Offline WA4OPQ
« Reply #10 on: February 17, 2021, 11:03:22 AM »
Keeps it warm?
As mentioned before, just a bit more stable.A little less cold in the winter and not so hot in the summer. The vault lid has a provision for a security screw so it also makes it a bit more vandal proof.
Offline azchrisf
« Reply #11 on: April 14, 2021, 12:42:16 PM »
Excellent setup!
Also doing Soil and Leaf 4x
My setup:
https://www.wxforum.net/index.php?topic=41867.0
Offline nordos
« Reply #12 on: January 21, 2024, 11:19:02 PM »
Hello! Have you published somewhere what and how your weather station was assembled from? Please provide a link.
Ecowitt HP2560, WS90, WittCam HP10.
river Norilskaya (city Norilsk)
Ecowitt: https://www.ecowitt.net/home/share?authorize=8NN7J3
WeatherCloud: https://app.weathercloud.net/d6797820927
