No, it has a three position switch and a button for C/F
This is the photo taken from FCC site
As you can see there are pads for the 4 switched that are unused.
However the model in photo is different from mine since this one has pressure sensor soldered on the left and none temp/hum sensor, mine has only the SHT30.
It seems that all that sensor have the same PCB (PCB has changes over time but is the same for all models at that time) and I believe that it is possible to convert a WH31 into a WH32 changing the solder pads. But I am not sure.
In some WH31 models all pads are visible, in some others some of them are under the little switches.
