Author Topic: Fine Offset Clone Models,sensor compatibility,firmware + other info - MUST READ  (Read 17133 times)
Offline Gyvate
Fine Offset (FOSHK) Weather Stations i.e. consoles, sensors and clones (Ecowitt, Froggit, Ambient, ....)
There are several companies selling Fine Offset hardware. We informally call them all Fine Offset clones. Fine Offset doesn't directly sell any hardware. These reseller companies put their branding on the hardware and often use different model numbers and even different part numbers for the same stuff. There can be several differences though to keep in mind. For example one reseller brand may only provide a certain frequency for their sensors and consoles, which means that mixing brands would not work as the frequencies could be different. Even when the frequencies match sometimes the parts can possibly not be compatible because of firmware differences by each company. The purpose of this thread is to explain these differences and help users to better customize their stations and provide more options. Do also keep in mind that some reseller companies sell Fine Offset hardware along with other hardware that comes from yet different manufactures and consoles and sensors not listed here are most likely that and therefore not compatible with the Fine Offset hardware.
Can't decide which console to get? Then get more than one console! It is a popular option to have both an HP2551-C console and a GW1000/GW1100 for example sharing the same sensors. You can have multiple consoles (with or without display)
The latest console, the GW1100, is a matchbox size low-cost but very powerful display-less console
<--------Viewing this post on mobile or small display? ---- SCROLL RIGHT -------->
(or right click and open image in new tab)
Table of Contents
1. consoles and sensors (plus related information)
     - matrix
     - footnotes
     - acronym scheme
2. the HP2551 console
3. firmware - update - versions
4. (WiFi) consoles and sensor packages ("stations")
5. changelog
1. Console to sensor compatibility table / matrix (update status: 02-Dec-2021 - what's new ? see changelog)
(consoles and sensor pictures shown are not to scale with respect to each other) 16
Using Ecowitt part numbers listed (Other vendor's part numbers like Ambient, Froggit, etc.are shown in respective lines) - These are not intended to match complete model numbers. If these parts match a complete station model, it is a coincidence.
clicking on the pictures below will magnify them in the browser
this is a view-only / read-only thread
if you want to contribute, report errors, gaps, ask related questions etc., please use the related discussion thread:  https://www.wxforum.net/index.php?topic=40837.0
T&H&P = Temperature, Humidity, Pressure (or Thermometer-Barometer-Hygrometer in Ambient terms)
(I) - I-shape
(Y) - Y-shape, osprey
REMARKS:
General:
sensor frequencies used/allowed for PWS in different areas of the globe:
Americas (North/South)                            - 915 MHz
Europe                                                    - 433 MHz or 868 MHz
Asia and Oceania (Australia/New Zealand)  - 433 MHz (or 915 MHz)
(want more detail ? see https://www.analog.com/en/analog-dialogue/articles/wireless-short-range-devices.html)
In general a console works (receives RF signals) at a (one !) dedicated frequency (433, 868 or 915 MHz) - hence it can only receive the signals of sensors which transmit at the same frequency.
In principle more than one console can receive the signal of a particular sensor in parallel, provided it operates at the same radio frequency and the firmware allows for the sensor reception. (e.g. a GW1000, a HP2551 and a WH2320E can all together in parallel receive the signals of one and the same WH65 sensor array. If it were the WH57 lightning sensor, a GW1000 and a HP2551 could both receive its signal, however the WH2320E could not as its firmware doesn't allow for that).
Ambient consoles don't display Ecowitt sensors, whereas Ecowitt consoles are compatible with Ambient sensors (provided they run on the same frequency [915 MHz] and are Fine Offset clones). Only Ambient consoles can post weather data to AmbientWeather.net and not to Ecowitt.net and vice versa.
footnotes:
a: Ecowitt (Hongkong, China) sell 433, 868 and 915 MHz sensors/consoles (www.ecowitt.com); Ecowitt don't sell all their sensors in/to the U.S. (contract due to Ambient contract with Fine Offset), Ecowitt sell some models/parts in the U.S. via Amazon and to the rest of the world directly or via Amazon in Canada and Australia
b: Froggit (Germany, Europe) sell only 868 MHz sensors/consoles directly (www.froggit.de), via Amazon (D, UK) or eBay
c: Ambient Weather (U.S.A.) sell 915 MHz sensors/consoles only (www.ambientweather.com). Ambient consoles are not compatible with Ecowitt sensors due to different console firmware; Ecowitt 915 MHz consoles can read Ambient sensors of the same frequency (915 MHz)
d: other brands (list may not be complete) are: ChiliTec, DNT, ELV, GARNI, Misol, PanTech, Renkforce, Sainlogic, Steinberg Systems, Ventus, Waldbeck, Watson ...etc. - however not all of their weather stations offered are Fine Offset clones
1: HP3501/3500 looks like the Ambient WS-3000 console but is totally different. The Ambient WS-3000 is running different firmware and only works with Temp/hum sensors and is not intended to be a complete weather station. Needs firmware > 1.6.2 for extra sensors.
2: here is a non-WiFi version of this console sold by some resellers like Ambient, model WS-1900. It looks identical but costs less and makes for an excellent 2nd display.
3: functionality-wise same as GW1000, needs/comes with an extra T&H&P sensor and has a 5V barrel connector (the Renkforce WH2600 is the legacy LAN model, not the new WiFi model, see also footnote 6)
4: e.g. Meteobridge [Pro], Weather-Display, CumulusMX, WeeWX, GW1000live app, PersonalWeatherTablet (PWT) app (Android) ...
5: not sold by Ecowitt to the U.S. - based on Ambient contract with Fine Offset
6: not the same as WH2600 LAN or Ambient ObserverIP (WS-1400IP, WS-1550-IP); the WH2650 is a Fine Offset model, not part of the Ecowitt portfolio - however you can get it as WH2600Pro WiFi from Froggit or e.g. under the Waldbeck Halley/Steinberg SBS-WS-600 brands from www.amazon.de or www.expondo.de (868 Mhz only) as a Weather station set ([displayless] console + T&H&P sensor + WH65 osprey 7-in-1 sensor array).
7: the predecessor model of the WH32 is the WH26 which is no longer built. It comes in two versions:WH32 and WH32-EP (extra precision). The WH32-EP has an external probe.
If the WH32 sensor is activated together with a WH65, the GW1000, HP2551 and WH2650 consoles overwrite the WH65 values i.e. use the WH32 data instead.
The same applies for a WS68 or WS80 sensor array active together with a WH65. The hierarchy is: WH65/WS69 --> WS68 --> WS80 --> WH32 (lowest to highest).
The GW1000/WH2650/HP2551 consoles allow selective activation or deactivation of sensors. Per console there can be only one WH32 sensor active (either WH32 or WH2-EP). If it is active in the console, it overwrites all other outdoor temperature sensors which are active for the console. If you wanted e.g. to get the outdoor temperature sensor data of a WH65, a WS80 and a WH32 altogether, you would need to deploy three consoles (i.e. consoles from the GW1000/WH2650/HP2551 models).
A similar situation exists with the wind sensor data from WH65/WS69, WS68 and WS80 running in parallel - the consoles prefer WS80 data over WS68 over WH65/WH69 sensor array data. You want both (all three), you need two (three) consoles with selective activation/deactivation of WH65, WS68 and WS80.
8: the whole number of indoor and outdoor PM2.5 sensors (WH41 and WH43) must not exceed four (4) devices (per console). You can have more than four such sensors, but they will then need to be distributed over more than one console. The same applies to the WH55 water leakage sensor.
9: the whole number of WH31 and WN30 extra sensors (WH31 and WH31-EP) must not exceed eight (8 ) devices (per console).
 :!: A number of WH31-EP sensors have been erroneously labeled WN37AS and have been shipped - they are still WH31-EP sensors. (07-Jul-2021)  :!:
10: the WS6006 is a display-less console and a WH65/WH69E array with the possibility to add two extra sensors. Target area is agriculture. The current model uses mobile networks with 3G (UMTS), 4G (LTE) standards. The predecessor didn't have extra sensors and ran on 2G / GPRS. The still to-be-released WL6006 will run on LoRa (Long Range) technology. Number and type of extra sensors still to be determined.
11: Weather Networks - WU=Weather Underground (www.wunderground.com), E=Ecowitt (www.ecowitt.net), WC=WeatherCloud (www.weathercloud.net), WOW=MetOffice WeatherObservationsWebsite (wow.metoffice.gov.uk), A=Ambient Weathernet (www.ambientweather.net), C=custom server [W= WU protocol, E= Ecowitt protocol, A=Ambient protocol]
The rebranded models in the matrix ("others") support the same Weather Networks and can use a custom server as the Ecowitt models
12: 433 MHz only
13: 915 MHz only
14: 868 MHz only
15: 868 MHz only; the Ventus W830 console displays digits only in white whereas the other brands have colored digits
16: console with screen sizes (screen diagonal):
      HP2551: 7"/17 cm, HP3501: 4.3"/11 cm, WH2910: 6"/15 cm, WS2320: 7.1"/18 cm
      (the WS2320/WH2320E/WH4000SE console has a 4:3 LxW ratio, the other console screens have a 16:9 LxW ratio)
      display-less console sizes (LengthxWidthxHeight):
      GW1000: 2.3 x 1.2 x 0.4" / 6 x 3 x 1 cm, WH2650: 3 x 2.1 x 2.2" / 7.7 x 5.5 x 5.7 cm (height including antenna), WS6006: ~4 x 2 x 0.6" / ~10 x 5 x 1.5 cm
17: sold by Ambient ( 915 MHz) and Froggit (868 MHz), and since 30-Apr-2021 also by Ecowitt (433, 868, 915 MHz); this sensor is part of the WH31 multi-channel family (WH31x, WH31-EP and now also WN30). This means you can have maximum 8 sensors of WH31 multi-channel type (WH31, WH31B etc.) per console (see footnote 9); remember: Ambient consoles don't display Ecowitt sensors, whereas Ecowitt consoles are compatible with Ambient sensors (provided they run on the same frequency [915 MHz, 868 MHz] and are Fine Offset clones).
18: sensor data from non-Ambient Fine Offset clone consoles which have the custom server option in Ecowitt format available (WSView app --> Device list --> Weather services --> Customized) can be received and processed by Weewx with the so-called Interceptor driver. For the GW1000/WH2650 a dedicated API driver is available. The proprietary Ambient format is not compatible with any so far existing weewx driver (as per 17 January 2021).
19: The Tycon ProWeather TC3000WC has a console display with black letters/numbers on greenish-grayish background, similar to the Davis consoles. The other clone models have bright yellow letters/numbers on a dark blue background.
20: The 2910C console (and clones on latest firmware, both console and WiFi firmware) can receive extra sensor data from WH31 and WH41/43 sensors and publish them on Ecowitt.net. These readings CANNOT be displayed on the console.
21: the WN1900 (not to be confused with the Ambient WS1900  :!:) is a "low-cost console" together with a light-weight WH65 sensor array (WN67) without solar panel, solar and UV sensors and longer sensor sending intervals.
The console itself has the same API as a GW1000/WH2650 but with a grey-green LED display and about palm-size (i.e. can be held in one hand).
8 WH31 multi channel temp/hum sensor recycle display on the console. Other extra sensors data (same as GW1100) is not displayed on the console (pass through to ecowitt.net only); sensor management/calibration via WS VIEW app only. It comes with a greyish/black display (WN1900) or a color display (WN1910)
22: the WH32B has a predecessor model by the name WH25 - it's no longer built. A HP2551 or a WH2650 console should be able to get readings from it as T&H&P sensor.
23: the WN67 (N=no solar panel) is a light-weight WH65 with no solar radiation reading. It has a longer reporting interval (48 s) and runs on batteries only. It comes with the WN1900 console (still to-be-released). The sensor array which comes with FineOffset WN5300, WN5350, WN2080 is NOT a WN67. It is a WN14 and uses a different modulation method for transmitting the sensor readings. WN14 uses ASK=amplitude shift keying and the WN67 uses FSK=frequency shift keying. So they are not interchangeable and cannot be received by the consoles in our matrix. The sensor arrays of Aercus 2085 and Aercus 3085 also use ASK.
24: the WH65 comes as Y-shape and the newer WS69 arrays as I-shape arrays  (as per Ecowitt engineering). The WS69 can use the BP0001 battery extension pack.
25: the GW1100 can also be configured and connected to WiFi via a WebUI, not only via the WSView app
26: CumulusMX V13 (b3145) can use a console/server which posts in Ecowitt, Ambient or Wunderground protocol (e.g. custom server option) as a full or complementary station (adding sensors to main station)
27: the WS90 is still in beta testing, it will be an all-in-one outdoor array with a haptic rain counter and ultrasonic anemometer; it's not meant to be a replacement for the WS80 - It's part of a new station (Wittboy) with an all-in-one outdoor sensor array (WS90) and a new gateway/hub GW2000 which will become home automation etc. capable in the future
28: in Europe the WH31 comes also in a special edition with a DCF77 chip (radio controlled time signal) - this is not necessary for the normal consoles (GW1x00, HP2551 etc.); it works like anormal WH31 sensor
(868 MHz) - it's sold by dnt
#: released 10-Dec-2020
&: in beta testing
%: WN51 = soil moisture sensor with ceramics covered probe; under revision; no more sold
: Fine Offset Electronics Ltd are the manufacturer, the factory (target group: resellers/business customers e.g. Ambient, Froggit, Misol, ...) whereas Ecowitt are FineOffset's private customer outlet/front (target group: retail, private users) which is also involved in research and product development. Often the same people just wear a different hat i.e. play the same or similar roles in both companies.
Acronym scheme
Ecowitt
HP  xxxx weather station with TFT color panel, e.g. HP2551
WS xxxx weather station with solar panel, e.g. WS2320
WH xxxx weather hub (old[er] stations), e.g. WH1080
WN xxxx weather station without solar panel, e.g. WN1900
GW xxxx gateway series, e.g. GW1000
exceptions:
the WH2320E/WH2350E using the WH65/WH69E has a solar panel (meanwhile renamed to WS2320E and WS69)
the WH2650 WiFi [sold by Fine Offset only or by European resellers (868 MHz)] is also a gateway console
the WH0290 Air Quality Monitor is not a full-fledged weather station. It's a console for one WH41/WH43 PM2.5 sensor
a GW1000 433 MHz would not show as GW1000C-xxxx in the device list of the WSView app but as GW1000-xxxx only
(announced to be changed in a future firmware version)
XXnn[nn]A, XXnn[nn]B, XXnn[nn]C  A= 868 MHz model, B=915 MHz model, C=433 MHz model. e.g. HP2551A
(exception: WH0300B, station is only transmitting at 433 Mhz)
further differentiation:
S: soil, L: water (liquid), B: barometer (WH32B = WH32 T/H outdoor + B = WH32B (indoor))
e.g. WN34AS = 868 MHz, soil temperature sensor; WN34BL = 915 MHz, water temperature sensor (WN34 sensors still to be released as per 24-Nov-2020)
E: extended edition (e.g. WH2320E), SE: special edition [Froggit only] (e.g. WH3000SE, WH4000SE, HP1000SE)
numbering:
The last number of the model number usually refers to the product development time order. e.g. The GW1002 is developed after the GW1001.
(that's a marketing thing: from GW1001 through GW1003 new console/sensor combinations are offered - see also below under packages)
The GW1000 console in these packages is the same.
Froggit
all weather stations (console + sensor array + indoor sensor where applicable) start with either WH or HP
all extra sensors fall under their DP series (including the DP1500 which is the rebranded GW1000)
Ambient
all weather stations start with WS, extra sensors are either WHxx or WSxxxx-SENSOR (SENSOR is usually ARRAY or RAIN etc)
firmware - types of firmware - firmware update - latest firmware versions:
see separate post below
(WiFi) console/sensor combinations and packages ("stations"):
« Last Edit: December 02, 2021, 02:32:25 PM by Gyvate »
Froggit WH4000SE (=EW 2320E) 1.6.0/GW1100 2.0.6/Froggit DP1500 1.6.8 (+EW GW1000 (4) 1.6.8 test/backup)/HP1000SE Pro (HP2551) 1.6.0/1.7.6, WH2650 WiFi (2) 1.6.8
Ecowitt WS80,WH40,WH65,WH31(5),WH31-EP(1),WN30/DP30 (1),WH32(1),WH32-EP(1),WH32B [T/H/P] (1), WH57 [Lightning] (1), WH41 [PM2.5] (2), WH51 [SoilMoisture] (5), WH45, WH55 (2)
Meteobridge Pro (2) [test,prod] 5.2 Oct 8 2021, 14568 - Blake-Larsen Sun Recorder - RPi4/weewx 4.5.1/CumulusMX 3152/MB RPi4 (2643)
Meteoshield Pro, MetSpec Rad02
Ecowitt 5763,34418;WU ISAARB3(WH4000SE), ISAARB22(HP2553);Weathercloud 3011399141, http://meshka.eu/
Offline Gyvate
2. HP2551 console
2.1 main display/interface
(1) the WH55 water leak sensors (1-4) also appear here as green drops with the channel number inside
(3) with console firmware 1.7.6 the time stamp of the last strike is now maintained over a reboot or restart
     (before it would disappear after a reboot/restart of the console)
(5) the console does not show 24h rain [yet]  (=rainfall during the previous 24 h - not to be confused with 24 h/daily total rainfall)
(9) with firmware release 1.7.1 the PM2.5 sensors (WH41/WH43) are now also scrolling - previously only the first one (out of possible four) was shown.
2.2 editing sensor display names
As the console firmware update to V1.7.3 in quite a few cases purged the name of the indoor temperature/humidity sensor shown on the main display and replaced it with the text "WH32", the question arose how to fix this.
Below the answer which is somewhat tricky and not clearly documented in the HP2551/2553 manual.
On the main setup pages (pressing the wheel/gear button 1-4 times - the position changes on the 1st setup page !! - or "setup - More" on the 1st setup page) you only find the possibility to change the display names of your WH31 extra sensors (1st setup page).
Ecowitt somehow considers the WH32B sensor, the indoor temperature/humidity/pressure not as a basic sensor (what common sense would expect as the sensor comes with the HP2551/2553 packages) but as an OPTIONAL sensor.
Hence you have to look somewhere else: on the "Optional Sensor Display Mode" page ( press 4 x ▼▲ from the main display). There you suddenly find your WH32B T/H/P sensor under the name it shows on the main display.
However the example in the manual does NOT show this sensor ....
On this page the display names of all sensors shown (all optional sensors including the WH32B) can be edited.
Select the sensor with the ▼▲ key and press the (-) key to enter the editing dialogue.
The sorting order is alphabetic for the sensor model names where e.g. the WH45 starts with "C" for CO2, indoor was considered "WH32" (correct would have been "WH32B") and the PM2.5 sensors are WH41/43.
2.3 the SensorsID submenu
The sensors ID submenu is not properly described in the HP2551 manual (October 2021) and people trying to install a WH32B (e.g. for the HP251 or the WH2650) or the WH32(-EP) - the WH32 manual only shows how to get a WH32 installed for a GW1000/WH2650 but not for a HP2551 console where WS View only works for weather network configuration - are confronted with obstacles, I have decided to explain the SensorsID submenu below.
By the way - there are two submenus. The 2nd one is found by pressing the arrow-right key when you are on the 1st SensorIDs page. The 2nd is for the WN34 and WN35 sensors, whereas the rest of possible sensors shows on sensorIDs page #1.
It's a table with three main columns, each of which has three resp. four sub-columns.
it is quite self-explanatory, except for the 1st main column where you find the "T&HP" and "T&H" entries.
T&HP is the WH32B sensor - the indoor temperature/humidity/air pressure sensor
T&H is the WH32 sensor - the single temp/hum outdoor sensor (all other outdoor T/H sensors are integrated in one of the three outdoor arrays, WH65, WS68, WS80) - if you use an outdoor array and a WH32(-EP) outdoor T/H sensor in parallel, you will to register it here - and its readings will override the outdoor T/H readings of all the other arrays.
The WH57 lightning detector and the WH45 indoor 5-in-1 air quality combo sensor also show in the first column.
The same with the WH65/WS69, WS68 and WS80 outdoor arrays.
In order to either register of deactivate a sensor, you will have to select its ID field with the up/down arrow keys and then press the (-) key.
A little pop-up window appears where you have four options:
1. Register (the console will automatically look for the sensor);
2. enter its ID and register (this is useful if you have sensors of the same type and are not happy with the console's choice - or want to assign a particular sensor to a channel (see WH41/43, WH51, WH55, WH31/WN30));
3. select "disable" to deactivate the sensor
4. save (always needed except for 5.)
5. cancel
The 2nd main column houses the WH41/43 PM2.5 sensors (4 channels) and the WH31/WN30 Extra Temperature/Humidity sensors (8 channels)
The 3rd main column houses the WH51 soil moisture sensors (8channels) and the WH55 water detectors (4 channels)
« Last Edit: November 07, 2021, 04:05:54 AM by Gyvate »
Offline Gyvate
3. firmware
firmware update procedure:
there are two types of firmware for the FineOffset/Ecowitt (clone) consoles:
a) WiFi firmware for the upload to the Weather Networks and a customer server (if the console supports), usually starting with EasyWeatherVa.b.c (or AMBWeatherVa.b.c for Ambient devices)
b) console firmware, usually just the version like Va.b.c (a, b, c = major version, minor version, patch level)
the GW1100/GW1000/WH2650 consoles have a combined WiFi/console firmware
below shown is the update via WSView app
When new firmware (WiFi and/or console) is available for the GW1000 and WH2650, an automatic pop-up will appear when selecting it from the device list (GW1000A,B,C-WIFIxxxx).
When new WiFi firmware is available for the remaining consoles, an update pop-up will appear when you select the console entry from the device list.(EasyWeather-WiFixxxx or AMBWeather-WiFixxxx)
You must acknowledge the message by pressing OK. In the next step you can accept or cancel the update.
On the device list itself a note will be displayed for each affected device in green bold letters saying "New Firmware". When you canceled the update proposal before, an extra button will appear with the text "Update Firmware to a.b.c"
Both notes will disappear after the update was successfully performed.
console firmware update for the HP2551 and HP350x consoles is done via microSDcard. Download from Ecowitt.com or ambientweather.net [https://help.ambientweather.net/help/ambient-weather-ws-2000-firmware-download-center/]. Copy the file user.bin (HP2551 or clone) or firmware.bin + picture.bin (HP350x)  or factory.bin (WS-2000/WS-5000 console) to the FAT32 formatted SD card's ( :!:SDHC type only max 32 GB :!:) root directory on a PC and insert it into the console. HP350x will need a power-cycle [switch off/on].
The Ambient firmware update file may come with different names when you download it (factory_1.bin, user.bin, user.zip (needs to be unpacked first), user_1_6_3.bin etc.).
If the name is not factory.bin or user.bin, it needs to be renamed to user.bin resp. factory.bin . Updates from newer firmware version work with both names for Ambient consoles.
(difference: user.bin will be deleted automatically after the update, factory.bin needs to be deleted manually).
latest firmware versions (revisions): (02-Dec-2021)
FineOffset/Ecowitt
WiFi: EasyWeatherV1.6.0 (HP2551, HP3501, WH2910, WS2320) - issue date: 20-July-2021
shows in the device list for your console as EasyWeather-WIFI-xxxx where "xxxx" are the four last characters in HEX format of your console's MAC address.
console: V1.7.6 (HP2551, issue date:28-Sep-2021), V1.6.9 (HP350x - released 01-Jul-2021): update via SD card - V.1.6.8 (GW1000, WH2650): update via WSView app
V2.0.8 (GW1100 - released 02-Dec-2021) - the update can be checked and applied in the WebUI; since version 2.0.21 also in the WS View Plus app
[visible in the settings/setup of consoles with display and in the WSView app] - WH2650 now also on 1.6.8 (issued: 01-Jun-2021)
(Firmware 1.6.7 solved an issue which occurred when a WH2650 and a WH45 were used together. Then the WH32B of the WH2650 would not display pressure data anymore).
Change log for GW1100 firmware 2.04, 2.05, 2.06, 2.07, 2.08 versions
V2.0.8 release
 1.   Optimize distribution network function
 2.   Fix SNTP function bug
 3.   Add new version information prompt
 4.   Support wh25,wh26 data protocol new
V2.0.7 release
 1,fixed bug for wind speed error on WOW.
 2,Lightning data stored locally and the pattern of displaying has been updated.
 3,rain reset time is user define enabled now.
 4,Sensor data priority has been changed so that wh40 will override WS65,69, WS90.
V2.0.6 release
1、change sntp time update from once per day only to every one hour
2、fix rain month no reset bug.
3、fix bug for wow wind speed upload error.
V2.0.5 release
1、fix web live data page for invalid data of co2, pm25 handling.
2、upgrade WIFI(server led) status:
      1)off - no router connected.
      2)on - data has been published to server successfully.
      3)flash 1hz router connected, but not able to publish data to weather server.
V2.0.4 release
1、support new sensor WH90
2、HTTPD web server turned on
3、change RF chip AFC:0x8F :AFC OFF to   0x9F:AFC ON.
4、update  soil ad setting page
WH6006/WS6006: WiFi 1.1.21 (01-Mar-2021) update with Weather Logger software (1.6.6) via USB
WL6006: WiFi 1.0.24 (02-Sep-2020)
this also applies to FineOffset clones - see rebrander model number in the matrix
HP2551: changes, improvements, bug fixes coming with the firmware releases: https://www.ecowitt.com/shop/goodsDetail/1
HP3501: changes, improvements, bug fixes coming with the firmware releases: https://www.ecowitt.com/shop/goodsDetail/33
Ambient
there are also two types of firmware for the Ambient consoles:
a) WiFi firmware for the upload to the Weather Networks and a customer server (if the console supports), usually starting with AMBWeatherVa.b.c
Ambient have a different numbering of the firmware version as their firmware is brand-customized
WiFi: AMBWeatherV4.3.2 (30-Oct-2021) (WS-2000, WS-5000, WS-2902A, B, C) update via awnet app (ambientweather.net not yet updated, still shows 4.3.1)
console: V1.7.4 (WS-2000, WS-5000) update via SD card (issue date 21-Jul-2021)
[visible in the settings/setup of consoles with display and in the awnet app]
changes, improvements, bug fixes coming with the firmware releases: https://help.ambientweather.net/help/firmware-changes-ws-2902a/
« Last Edit: December 02, 2021, 07:00:25 PM by Gyvate »
Offline Gyvate
4. Console (WiFi) + sensor combinations / packages ("stations")
 Ecowitt GW1x01: GW1x00 console + WH65 (I) 7-in-1 sensor array
 Ecowitt GW1x02: GW1x00 console + WS68 5-in-1 sensor array + WH40 rain gauge + WH32 outdoor Temp&Hum sensor
 Ecowitt GW1x03: GW1x00 console + WS80 6-in-1 sensor array + WH40 rain gauge
 (x=0,1)
 Ecowitt HP3500B:  HP3500 TFT console + WH65 (I) 7-in-1 sensor array + indoor T&H&P 3-in-1 sensor (WH32B)
 Ecowitt HP3501:    HP3500 TFT console + WS68 5-in-1 sensor array + indoor T&H&P 3-in-1 sensor (WH32B) + WH32 outdoor temperature/humidity sensor + WH40 rain gauge
 Ecowitt WH2320E: WH2320E LED console + WH65 (I) 7-in-1 sensor array
 Ecowitt HP2551: HP2551 console + WH65 (I) 7-in-1 sensor array + indoor T&H&P 3-in-1 sensor (WH32B)
(Ecowitt HP2552 <---not a real model number: HP2551 console + WS68 5-in-1 sensor array + indoor T&H&P 3-in-1 sensor (WH32B) + WH32 outdoor temperature sensor + WH40 rain gauge)
 [user customized by adding components to the console]
 Ecowitt HP2553: HP2551 console + WS80 6-in-1 sensor array + indoor T&H&P 3-in-1 sensor (WH32B) + WH40 rain gauge
beyond these sets/packages Ecowitt also sell the single components (sensors, consoles)  so you can compose your own console/sensor "fleet"
 Froggit WH4000SE:                          WH4000SE console (WH2320E console) + WH65 (I) 7-in-1 sensor array (+ local PC console software and database)
 Froggit DP1500:                               DP1500 console (GW1000) + DP50 (WH31) + WH65 (Y) 7-in-1 sensor array [called WH3000SE outdoor array]
 Froggit HP1000SE Pro:                     HP1000SE Pro console (HP2551) + indoor T&H&P 3-in-1 sensor (WH32B)
                                                       + WH65/WS69 (Y) 7-in-1 outdoor sensor array
 Froggit HP1000SE Pro Single sensor: HP1000SE Pro console (HP2551) + indoor T&H&P 3-in-1 sensor (WH32B)
                                                       + WS68  5-in-1 outdoor sensor array + WH32 outdoor T&H sensor  + DP80 (WH40) rain gauge
 Froggit HP1000SE Pro Ultrasonic:     HP1000SE Pro console (HP2551) + indoor T&H&P 3-in-1 sensor (WH32B)
                                                       + WS80 6-in-1 sensor array + DP80 (WH40) rain gauge
 Froggit WH2600 Pro WiFi: WH2600Pro console (WH2650) + T&H&P 3-in-1 indoor sensor (WH32B) + WH65 (Y) 7-in-1 sensor array
Froggit only sell the rebranded Ecowitt packages as full packages. Some but not all sensors/consoles can be purchased alone as spare parts
 Ambient WS-2000: WS-2000 console (HP2551) + indoor T&H&P 3-in-1 sensor (WH32B)
                             + WH65 (Y) 7-in-1 outdoor sensor array
 Ambient WS-5000: WS-2000 console (HP2551) + indoor T&H&P 3-in-1 sensor (WH32B)
                             + WS-5000-ARRAY (WS80) 6-in-1 sensor array + WS-5000-RAIN/WH40-RAIN (WH40) rain gauge
Ambient Weather WS-5050: WS-2000 console (HP2551) + indoor T&H&P 3-in-1 sensor (WH32B)
                             + WS-5000-ARRAY (WS80) 6-in-1 sensor array (ultrasonic) - NO (!) rain gauge
Ambient only sell the rebranded Fine Offset packages as full packages. Some but not all sensors/consoles can be purchased alone as spare parts.
Ecowitt sensors are not compatible with Ambient consoles (modified Ambient firmware), i.e. Ambient consoles don't display Ecowitt sensors,
Watson sell a HP2551 clone as Watson W8686 (433 or 868 Mhz) [HP2551 console + WH32B + tri-wing WH65] in the UK.
ELV, Waldbeck, Steinberg Systems sell Fine Offset clones (868 MHz) in Germany via amazon.de or other online market places (e.g. expondo.de + country sites in the EU)
Misol sell Fine Offset clones in Asia Pacific (433 MHz) also via aliexpress.com or banggood.com
« Last Edit: November 16, 2021, 06:04:20 AM by Gyvate »
Offline Gyvate
5. change log:
(14-Nov-2020) added Froggit DP70 (=Ecowitt WH55)
(14-Nov-2020) updated sensor hierarchy (footnote 7)
(17-Nov-2020) included Watson as Fine Offset clone seller to footnote d and to the packages
(20-Nov-2020) added acronym scheme (source: Ecowitt)
(21-Nov-2020) updated table: added WS6006/WL6006 and updated footnote 10 on WS6006/WL6006 (source: Ecowitt)
(22-Nov-2020) added Ambient PM2.5 indoor (WH43) and WH31LA (WH55), updated HP3501 sensor compatibility, added Weather Network information
(23-Nov-2020) updated WL6006 info
(24-Nov-2020) added console clone models/brands and their frequencies
(25-Nov-2020) updated HP3501 sensors (with console firmware 1.6.9), added console/screen sizes, added firmware info
(03-Dec-2020) updated WiFi firmware version for Ecowitt and compatible
(07-Dec-2020) added WH31P (Ambient) to the matrix
(10-Dec-2020) added picture of newly released WH45 (release date 10-Dec-2020)
(26-Dec-2020) added picture for HP2551/WS-2000/WS5000 console display overview
(30-Dec-2020) marked WH32E for Ambient as "end-of-life" (exactly "end-of-support" as they have taken it off their portfolio)
(03-Jan-2021) added reference to related discussion thread  https://www.wxforum.net/index.php?topic=40837.0
(03-Jan-2021) added remark regarding past 24 h rainfall display of the HP2551 console
(05-Jan-2021) added PanTech as another reseller brand in Australia (HP2551, HP2553 and extra sensors)
(13-Jan-2021) added Froggit DP30 water temperature sensor to the matrix
(17-Jan-2021) added Meteobridge/Weewx/CumulusMX/WeatherDisplay console support info
(22-Jan-2021) updated footnote 9 with the new WN30 (temperature only, waterproof probe, 3 m cable) sensor
(29-Jan-2021) updated firmware info for WIFI firmware 1.5.7 Ecowitt / 4.2.9 Ambient
(02-Feb-2021) update WS68 signal indicator in console pictogram overview - updated announcement for PM2.5 sensor cycling (1-4) in current position with next firmware version
(30-Jan-2021) added Tycon ProWeather TC3000WC (WH2350 Fnbe Offset clone) to the matrix
(02-Feb-2021) updated WS68 signal indicator position on console screen, announcement by Ecowitt to implement PM2.5 indicator (1-4, WH41/43) cycling with next firmware
(26-Feb-2021) added WH35 Leaf Moisture sensor (1-8) to the matrix - sensor already part of firmware 1.6.5
(27-Feb-2021) created a temporary warning regarding firmware 1.6.5 in the firmware section of the matrix footnotes
(02-Mar-2021) updated firmware 1.6.6 for GW1000 - FW 1.6.5 withdrawn, also for WH2650 => latest available FW for WH2650 is 1.6.3 (1.6.5 for early adopters - WH2650 users were not affected by the 1.6.5 side-effects on the GW1000 together with a WH32B - they have another side effect: loss of pressure/barometer data from WH32B)
(03-Mar-2021) moved firmware info into separate post (as the post is reaching its maximum number of characters [2000]); added picture of device list and console identifiers plus update pop-up
(12-Mar-2021) added information about WH2910C console and sensor data uploaded to Ecowitt.net - info on to-be-released FW 1.6.7
(19-Mar-2021) added information about beta-phase WN1900 "low-cost" weather station
(25-Mar-2021) added footnote for WH32B predecessor (WH25)
(27-Mar-2021) added info about firmware 1.7.1 for the HP2551 (and clone) console - main visible feature: WH41/53 PM2.5 sensors are now also scrolling on the main screen
(29-Mar-2021) added ChiliTec and DNT as FO clone resellers
(02-Apr-2021) added WN67 info to matrix
(07-Apr-2021) added info on WiFi firmware upgrade V1.5.8 claiming solving the following issues: 1. Optimize domain name resolution.;2. Optimize the uploading stability of custom servers
- for affected consoles see firmware post / section
(12-Apr-2021) updated HP2551 console info and pictogram
(22-Apr-2021) updated information regarding console firmware update (1.7.1 for HP2551, 1.6.7 for HP350x) and WiFi firmware V1.5.9 (claiming solving the same issues as V1.5.8: 1. Optimize domain name resolution.;2. Optimize the uploading stability of custom servers)
(30-Apr-2021) added WN30 multi-channel waterproof temperature sensor with external probe to the matrix
(10-May-2021) added DP250, the Froggit version of the WH45 5-in-1 indoor air quality sensor to the matrix
(13-May-2021) minor updates to the firmware section
(24-May-2021) added information in footnote 23 regarding the WN67 sensor array which looks similar to the WN14 array (but is different technology) which comes with FineOffset low cost stations, e.g. WH5300, Aercus 2085, Aercus 3085.
(27-May-2021) updated firmware information for GW1000/WH2650 - now V1.6.7
(01-Jun-2021) updated firmware information for GW1000/WH2650 - now V1.6.8
(03-Jun-2021) updated firmware information for HP2551 console - now V1.7.3 (fixes some bugs and may purge the text for the Indoor T/H(/P) sensor and replace the original text (usually "Indoor") by "WH32")
added info on how/where to fix the purge/replace issue in the console post
(04-Jun-2021) added footnote 24 on WH65/WS69 sensor arrays and BP0001 (external battery pack) compatibility
(01-Jul-2021) latest firmware V 1.6.9 for HP350x console released
(02-Jul-2021) latest firmware V 1.7.4 for HP2551/HP2553 (Froggit HP1000SE Pro, Watson 8686, .... see matrix for other clone brands) released
(07-Jul-2021) A number of WH31-EP sensors have been erroneously labeled WN37AS and have been shipped - they are still WH31-EP sensors.
(20-Jul-2021) latest WiFi firmware V1.6.0 for consoles HP2551, WS2320E, HP350x, WH2910 and non-Ambient clones of these consoles published
(21-Jul-2021) added the new GW1100 console with the WebUI configuration option to the matrix
(22-Jul-2021) latest console firmware V1.7.4 for Ambient WS-2000 and WS-5000 stations released
(24-Jul-2021) added ProTech WiFi gateway (GW1000 clone, 868 MHz) to the matrix
(25-Jul-2021) added firmware info for WS-2000/WS-5000 console: file name is factory.bin (whereas for HP2551 and clones it is user.bin)
(30-Jul-2021) added new CumulusMX V12 (3141) functionality - can now use all consoles/servers which post in Ecowitt protocol (e.g. custom server option) as station
(31-Jul-2021) WN34L, WN34S (1-8) and WN35 (1-8) sensors released
(05-Aug-2021) added the WH55 signal position to the HP2551 console pictogram
(06-Aug-2021) added info for WN1900 console features in footnote 21
(09-Aug-2020) Meteobridge application software now supports the WS2320E/Froggit WH4000SE WiFi/Misol WS-2320/ ELV WS980 WiFi, Steinerg sbs-ws-400 consoles
(13-Aug-2021) added GW1100 firmware information
(17-Aug-2021) added Ambient AQIN sensor (the equivalent to Ecowitt WH45 5-in-1 air quality sensor T/H/PM2.5,PM10,CO2)
(01-Sep-2021) added latest firmware (2.0.3) for GW1100 and update method
(09-Sep-2021) added Ambient latest WiFi firmware version 4.3.0 (issue date 07-Sep-2021)
(17-Sep-2021)  added Ambient latest WiFi firmware version 4.3.1 (issue date 13-Sep-2021)
(21-Sep-2021) added latest firmware (2.0.4) for GW1100
(28-Sep-2021) added Ecowitt latest console firmware for HP2551 V 1.7.6
(22-Oct-2021) added the description of the SensorsID submenu in the HP2551 console
(26-Oct-2021) updated WN1900 console info as the console/station is released meanwhile
(28-Oct-2021) added firmware change log for GW1100 V2.04, 2.05, 2.06 in firmware section
(30-Oct-2021) added Ambient WiFi firmware change to V 4.3.2
(03-Nov-2021) added the new WS90 all-in-one outdoor array (beta testing phase) and the WH31 with DCF77 support (868 MHz, Europe only)
(06-Nov-2021) added information about new Wittboy station (WS90 + GW2000) - footnote 27
(07-Nov-2021) added information that with firmware 1.7.6 the HP2551 console keeps last lightning strike time stamp over a reboot/restart
(14-Nov-2021) added change log for GW1100 firmware V2.0.7
(16-Nov-2021) added Ambient WS-5050 station (=WS-5000 without rain gauge)
(21-Nov-2021) added info about GW2000 (still in beta testing phase)
(02-Dec-2021) added info about GW1100 firmware update 2.0.8
« Last Edit: December 02, 2021, 02:37:27 PM by Gyvate »
Offline Gyvate
technical post: please ignore
