Author Topic: Firmware wifi for HP 2551C  (Read 160 times)
Offline Geornat
« on: October 21, 2020, 03:05:31 AM »
Hello
How can find wifi firmware for HP2551C or Froggit HP1000SE PRO.
Thank.
Offline Mandrake
Re: Firmware wifi for HP 2551C
« Reply #1 on: October 21, 2020, 03:27:23 AM »
This is updated only via the WSView application for smartphones.
Using the app when you first connect to your weatherstation it will prompt immediately if the Wifi firmware needs to be updated.
So it pays to periodically check using WSView or keep an eye on this forum where it will be flagged.
Retired: Old Maplin N96Y/FO Weather station
G1ZFO
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WH57 Lightning Sensor (pre-prod test)
Ecowitt WH32-EP (SHT35)
Offline Geornat
« Reply #2 on: October 21, 2020, 03:37:17 AM »
Ok  thanks
