Author Topic: wxgr3hanis-dbZ Script Winter Changeover  (Read 209 times)
Offline gwwilk
  • Southeast Lincoln Weather
« on: October 18, 2020, 10:22:34 AM »
For those of you who are using my wxgr3hanis-dbZ script to display your local radar images, sometime sooner or later you will need to switch over to the winter scale and push the 'T' button on your GRLevel3 program in order to better display the local radar conditions.
T-Button:
There's a switch, 'winter = false', that should be set to 'winter = true' in 'wxgr3hanis-dbZ.php' and 'wxgr3hanis-dbZ-SA.php' so that the appropriate scale is displayed to the left of your radar images.
Of course this procedure should be reversed come Spring in your area.
The script is available on my scripts page.
« Last Edit: October 18, 2020, 10:37:26 AM by gwwilk »
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline gwwilk
Re: wxgr3hanis-dbZ Script Winter Changeover
« Reply #1 on: March 24, 2021, 09:22:58 AM »
Just a reminder that sometime this Spring, depending upon your latitude, you need to switch back to 'Summer' if you're using this script. :-)  (I just did so this morning.)
gwwilk@gmail.com
