Author Topic: space-weather.php  (Read 19395 times)
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
space-weather.php
« on: September 24, 2020, 12:21:27 PM »
Where can I find a current copy of space-weather.php to replace the depreciated wxspace.php?
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: space-weather.php
« Reply #1 on: September 24, 2020, 01:27:57 PM »
Don't think there is one really. The website keeps changing urls
I can through in a copy of mine if you like when I get home from work.
https://www.conligwx.org/wxspace.php
Regards Simon
Davis Vantage Pro2 Plus (6162UK) • Daytime FARS • WeatherLink Live • AirLink • PurpleAir PA-II-SD • CumulusMX • ADSB.im • Pi 4 • AirSpy mini • Uputronics Filtered 1090 Preamp
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #2 on: September 24, 2020, 01:31:54 PM »
I've managed to get mine a little bit more current, though I haven't been able to find a reliable source of solar cycle tracking graphics yet, so the deprecated graphs are still there.
CamWX.com/wxspace.php
-Grant
« Last Edit: September 24, 2020, 01:44:08 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
Owner/Admin - CamWX.com
SKYWARN Spotter
Station Hardware: Davis Vantage Pro2 Plus w/ 24hr FARS
Station Software: Weather Display, Weather Message, FWI Calculator, StartWatch, with social media & messaging automation using Make.com, Twilio, and Brevo.
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #3 on: September 24, 2020, 01:45:02 PM »
Ok here's the package with the script and image handler scripts included.  Hope it helps.
-Grant
Update - Newer .zip file below...  [tup]
« Last Edit: September 25, 2020, 06:36:44 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
« Reply #4 on: September 24, 2020, 02:03:09 PM »
Thank you
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #5 on: September 24, 2020, 05:03:49 PM »
Thanks for the info.  updated mine slightly just now.
Regards Simon
Offline CrondallWeather
  • Crondall Weather
  • Still a classic - like so many of us....
    • Crondall Weather
« Reply #6 on: September 25, 2020, 03:43:03 AM »
Works great for me as well - many thanks
 [tup]
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #7 on: September 25, 2020, 06:48:58 AM »
Great work!  Thanks. [tup]
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
« Reply #8 on: September 25, 2020, 09:19:28 AM »
Working great - thanks
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #9 on: September 25, 2020, 06:15:40 PM »
Tweaked it a bit more - added a few more images and updated some of the captions and verbiage.  As for the solar cycle graphs that got all fancy on the SWPC website with no image to link to... they update so slowly that I guess the best option right now is to download and host the current state of the graphs on my server, which is what I'm doing.  Included in the package are the latest images... we'll just have to upload current images every few months to keep the data fresh until someone can work out a solution.
-Grant
Updated .zip package below
« Last Edit: October 05, 2020, 01:07:02 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline Ian.
    • Chatteris Weather
« Reply #10 on: September 27, 2020, 02:52:07 PM »
Grant
Thanks for the tweaks, works just great.
CWOP - DW3371
PWS - ICAMBRID16
https://www.chatteris.biz
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #11 on: October 05, 2020, 01:06:03 PM »
Cleaned up the code a little bit more, removed some now-unused image handlers, and took my site's meta tags out of the header (something I really should have done from the get-go...  #-o).
This should do it for a while, but I am working on animating the entire WSA-Enlil solar wind forecast...
-Grant
 :!: See update below!
« Last Edit: October 08, 2020, 12:58:47 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #12 on: October 08, 2020, 12:58:14 PM »
Ok, last update for a while.  The WSA-Enlil forecast now animates through the entire solar wind outlook.  Many thanks to the beteljuice for his help with the javascript to get this to work!  You can adjust the speed of the animation by modifying the wsa-enlil.js file on the noted line, but the higher the speed, the more you risk a jerky animation for slower network connections.
Demo at CamWX.com/wxspace.php
Current users need only replace the wxspace.php file and add the wsa-enlil.js file.
Grant
« Last Edit: October 09, 2020, 10:12:14 AM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline the beteljuice
  • the beteljuice
    • test site
« Reply #13 on: October 08, 2020, 06:59:44 PM »
250ms is way too fast for a 'comfortable' grab .....
Imagine what you will KNOW tomorrow !
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
« Reply #14 on: October 08, 2020, 07:43:46 PM »
Thank you [tup]
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #15 on: October 09, 2020, 10:11:52 AM »
A few updates and fixes were made to the javascript code.  Current users need only replace the wsa-enlil.js file.
Thanks.
 :!: Updated package below...
« Last Edit: November 02, 2020, 11:57:42 AM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #16 on: November 02, 2020, 10:53:20 AM »
Thanks.
seems the Auroral Activity Forecast is broken now. (this time and date)
I think the URLs have moved.
« Last Edit: November 02, 2020, 10:55:33 AM by ConligWX »
Regards Simon
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #17 on: November 02, 2020, 12:05:10 PM »
Man, SWPC is moving fast with their website upgrades.  Thankfully this was just a change in directory structure and a few updated links.
Fix attached.  Just unzip and replace the wxspace.php file along with the two included image handlers and all should once again be right.  Also updated the script package for new installers.
Grant
 :!: Newer files below.
« Last Edit: March 28, 2022, 06:06:19 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
« Reply #18 on: November 02, 2020, 12:34:40 PM »
 [tup]
Offline NK7Z
    • Amateur Radio, RFI and setup information
« Reply #19 on: November 02, 2020, 01:42:26 PM »
If anyone is interested, I have a script in perl that will collect a pile of data, from NOAA, all Space Weather related I can attach to a post here...  It is very well commented.  Let me know if interested.  It collects a lot of data from the NOAA JSON data, and some from more normal channels...
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #20 on: March 28, 2022, 06:04:58 PM »
Looks like the realtime solar images got broken due to some updates at Nasa.gov.  The links have been updated in the image handlers to reflect the new location of the realtime solar images and all should be well again.  Updates only as well as the complete package for new installers are available here.  Thanks!
 :!: Latest package in a newer post
« Last Edit: May 15, 2023, 12:01:21 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline Ian.
    • Chatteris Weather
« Reply #21 on: March 29, 2022, 02:14:36 AM »
Many thanks for your efforts, all back working :-)
CWOP - DW3371
PWS - ICAMBRID16
Offline zeppline
    • Las Vegas Weather Guy
« Reply #22 on: March 29, 2022, 12:10:17 PM »
Thanks again back and working.
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #23 on: March 30, 2022, 02:56:33 PM »
All,
With the uptick in space weather activity over the past 72 hours, there has been an increase in web traffic to the websites that host some of the images that we source for our Space Weather pages on our own sites.  Some of these sites have not been able to keep up with demand and are experiencing downtime, notably soho.nascom.nasa.gov and even swpc.noaa.gov sporadically.  As a result, you'll see errors and failures to load some images on your space weather pages (That's the Error: 019 message you're seeing where your images should be).  Hopefully this should resolve as these agencies mitigate the issues caused by the sudden influx of web traffic as folks scramble to find out more about these recent solar flares and upcoming geomagnetic storms.
In the meantime, I hope those of you at the northern latitudes can see and enjoy some really spectacular aurora over the next few days!
« Last Edit: March 30, 2022, 04:01:51 PM by K6GKM »
Grant Miles
Camarillo, CA, USA
SKYWARN Spotter
Offline W7DRM (old call was W3DRM)
    • Emmett Weather
« Reply #24 on: April 03, 2022, 03:04:18 PM »
The updated files work great to download and display the Real time Images of the Sun. However, when I click on the images to view the time-lapse image that are in mp4 format, nothing happens except for an empty screen with the viewer grayed-out. When I click on the SDO/HMI Continuum and SDO/HMI Magnetogram images that are mpg files, I get a prompt to save the file to my hard drive.
Do I need some kind of a video player to get these images to automatically play or is there a problem elsewhere?
Don - W7DRM - Emmett, Idaho --- Blitzortung ID: 808 (temporarily off-line) --- FlightRadar24 ID: F-KBOI7
Davis Wireless VP2, WD 10.37s151,
--- RIPE Atlas Probe - 32849
