By the way - afaik luminosity is the field - provides data in Lux, need to be divided by 126.something to get the W/m2.
The exact number used by the firmware is mentioned somewhere in the manual. It refers to visible light of a certain frequency.
That's what the console firmware does.
@Gyvate is correct - you just need to add the following line under [[Corrections]] in the [StdCalibrate] area in weewx.conf file.
# This section can adjust data using calibration expressions.
[StdCalibrate]
[[Corrections]]
# For each type, an arbitrary calibration expression can be given.
# It should be in the units defined in the StdConvert section.
# Example:
radiation = luminosity/126.7 if luminosity is not None else None
I came across it a while back in the Weewx google group when I had the same issue!
@ navzptc
ooops - when I first read your reply, I thought it was meant for WA4OPQ and his issue. Especially as you quoted that part of my post regarding how the consoles create radiation values out of the luminosity they measure.
So, even though I thought that your remark was not for me, just confirming my statement about luminosity, I still sort of "just for fun" added that line in the [corrections] stanza of the weewx.conf file - and,
surprise, surprise, my solar radiation is back.
Thanks for that hint - that really worked !!
But then, I have no clue what that is supposed to have to do with calibration (but it's probably the if-clause that does the job
(weird looking logics - we call this in my language "shooting or stabbing someone from behind through the chest in the eye" if you see the picture/metaphor
Or is it just a possible place where to correct a missing feature that should have been done somewhere else in the coding earlier ???
[update, after receiving the mail from the weewx GW1000 API driver developer (see next post) - it's a feature the way weewx works, not a missing one, but a correction like the above mentioned one is needed]So far I had only an entry there to correct my relative pressure - as somehow the console calibration didn't change the value in weewx. I have the same situation in my Meteobridge - correction/calibration needed after the data logger has read the values from the GW1000. So the console calibration seems to become effective only for sending the data to Ecowitt.net (or to a custom server).
But that's just a side remark - otherwise I'm moving rather off topic I'm afraid.
