Author Topic: Davis Airlink supported by Meteobridge (in parallel to other stations)  (Read 774 times)
Offline docbee
  • Moderator
    • smartbedded
I am happy to announce that current Meteobridge version supports the new Davis AirLink station. As Meteobridge can now handle 5 different weather stations (yes, from different manufucturers if you like) adding the AirLink to an existing Vantage or Envoy or WLL setup is done with a few clicks.
Meteobridge reports temperature, humidity and 3 air quality measures (for particle sizes of 1, 2.5 and 10 microns).
« Last Edit: September 15, 2020, 12:10:22 PM by docbee »
Offline wvdkuil
  • Wim van der kuil
Re: Davis Airlink supported by Meteobridge (in parallel to other stations)
« Reply #1 on: September 15, 2020, 12:18:58 PM »
Yep, see attached screenshot
Wim
Offline docbee
  • Moderator
    • smartbedded
« Reply #2 on: September 15, 2020, 12:27:14 PM »
Wim, thanks a lot for helping me on this!
Offline josecmorales
« Reply #3 on: September 15, 2020, 12:43:12 PM »
Wooow, great news! thanks.
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
Offline ToTo
« Reply #4 on: September 16, 2020, 01:05:17 AM »
That looks very good.
Airlink use WLAN connection to the local network. Then Meteobridge Nano SD should also be able to read the data from the IP?
PWS Magdeburg - Germany - https://wetter.de.cool MB-Smart HWS
Offline docbee
  • Moderator
    • smartbedded
« Reply #5 on: September 16, 2020, 05:45:38 AM »
yes exactly.  [tup]
Offline ToTo
« Reply #6 on: September 16, 2020, 06:59:31 AM »
Thanks  [tup]
Offline woolfg
« Reply #7 on: September 17, 2020, 07:31:04 AM »
Hi
Mine arrived this morning and I can confirm it all works as expected
Thanks for all the work
Regards
Graham
