Author Topic: WLL JSON File  (Read 1823 times)
Offline NK7Z
    • Amateur Radio, RFI and setup information
WLL JSON File
« on: August 20, 2020, 09:00:07 AM »
Is it just me, or does the RAIN data provided by the WLL JSON file, come as an integer, even though it is less than 1?  i.e., ".09" inch of rain = "9" on my JSON file.  Is there a way to change this?
Offline mcrossley
    • Wilmslow Astro
Re: WLL JSON File
« Reply #1 on: August 20, 2020, 09:40:09 AM »
Do you mean from the local API and broadcast messages? If so the rainfall is in tips.
Offline NK7Z
Re: WLL JSON File
« Reply #2 on: August 20, 2020, 11:26:33 AM »
Thanks for the quick answer, and yes I do...  Is the formula for tips to inch available someplace?
« Last Edit: August 20, 2020, 11:32:13 AM by NK7Z »
Offline mcrossley
    • Wilmslow Astro
Re: WLL JSON File
« Reply #3 on: August 20, 2020, 12:08:42 PM »
It depends on the bucket size, a 0.01" bucket is 0.01" per tip, a 0.2mm bucket is 0.2mm per tip   :lol:
Offline NK7Z
Re: WLL JSON File
« Reply #4 on: August 20, 2020, 04:06:22 PM »
Hi Mark,
Thanks for the info...  Duh...  Not sure why I did not put that together!  I think I was worried about losses, etc...  OK, tips*.01 will get me the number I need...  I am using a script to grab numbers every X minutes from the WLL, then writing a file with the data in it.  I then use a program called Conky, to display the weather data on my desktop.  If you want to see the results, let me know and I'll put a screen shot on my web site...
THANKS!!!
