Author Topic: Unable to install  (Read 299 times)
Offline soxfan2k4
Unable to install
« on: August 17, 2020, 01:49:43 PM »
Same problem I've had in the past, but cant seem to resolve it this time........
New computer.  Windows 10, 16gb RAM, i5 processor
My VantagePro2 is not being seen by Cumulus.  I know I need to install the USB to serial converter, but when I try, I get this:
DeviceName = (\\?\usb#vid_10c4&pid_ea60#0001#{a2a39220-39f4-4b88-aecb-3d86a35dc748})
Failed to open the device, error - 5 No Devices Found. Communication Error
 Error in CP210x_GetDeviceSerialNumber() :: Invalid Handle
 Error while talking to the device.
 Press any key to exit
I disconnected all other USB devices, and even took the laptop off the docking station.  I tried installing w. the console both connected and disconnected from the laptop
What is the simple thing I am missing?
Online galfert
Re: Unable to install
« Reply #1 on: August 17, 2020, 01:56:07 PM »
Are you trying to run both Cumulus and Weatherlink for Windows at the same time? Because you can't.
Offline soxfan2k4
« Reply #2 on: August 17, 2020, 02:05:58 PM »
No.  In fact, I have rebooted the machine.  Still no luck
Online galfert
« Reply #3 on: August 17, 2020, 02:06:38 PM »
See if this advice helps...checking time sync...etc.
https://cumulus.hosiene.co.uk/viewtopic.php?f=6&t=11116
Offline soxfan2k4
« Reply #4 on: August 17, 2020, 02:22:45 PM »
Yeah, I saw that thread earlier.  Nothing applicable
Hmmm........
Offline PaulMy
« Reply #5 on: August 17, 2020, 06:51:45 PM »
Are you sure that the logger has not been run in USB mode, and are you able to run the Weatherlink PC program in serial mode?
Good information on Davis USB logger here https://www.manula.com/manuals/pws/davis-kb/1/en/topic/understanding-usb-logger-modes
Enjoy,
