Author Topic: Barometer data for FW2458 is very wrong  (Read 340 times)
Offline chrispyt2
  • Student - Meteorology PSU 2022
    • Weather Underground
« on: August 14, 2020, 05:59:23 PM »
For some reason, I just noticed that my CWOP barometer data is very wrong. I am not sure why this is happening all of the sudden. It is displaying the incorrect values on all the sites that show MADIS stations (finds.com, PWS Weather, NOAA, Utah MesoWest). The values are running very high for some unknown reason. The barometer is correct on my Davis Vantage Pro2 console and the data appears to be correct on my Ambient WeatherBridge. I did have an internet outage due to Tropical Storm Isaias and I had to reset my meteobridge and reconfigure everything. I don't know how that would only be messing up my CWOP data, however. Is anyone else experiencing issues with their CWOP barometer data, or is it just me?
http://www.findu.com/cgi-bin/wx.cgi?call=FW2458 (incorrect values)
https://www.wrh.noaa.gov/mesowest/getobext.php?wfo=lox&sid=f2458&num=48 (incorrect values)
https://www.pwsweather.com/station/mid/f2458 (incorrect values)
https://www.wunderground.com/dashboard/pws/KNJMONTV22 (Not CWOP - shows the correct value)
« Last Edit: August 14, 2020, 06:13:00 PM by chrispyt2 »
My Sites
WU: KNJMONTV22
CWOP: FW2458
PWS: KNJMONTV22
NWS: FW2458
Re: Barometer data for FW2458 is very wrong
« Reply #1 on: August 14, 2020, 06:13:33 PM »
Log into the Meteobridge.
Then go to the Weather Station tab.
Scroll down and see what the Station Altitude is set for?
Offline chrispyt2
« Reply #2 on: August 14, 2020, 06:17:43 PM »
Whoops. I set that to 324 meters instead of feet. That explains a lot. Data is being reported normally again.
« Last Edit: August 14, 2020, 06:20:24 PM by chrispyt2 »
My Sites
WU: KNJMONTV22
CWOP: FW2458
PWS: KNJMONTV22
NWS: FW2458
« Reply #3 on: August 14, 2020, 06:30:33 PM »
 [tup]
Offline GreyOwl
  • Station up and running, No RH or Pressure sensors
« Reply #4 on: August 19, 2020, 12:32:46 AM »
At least yours was an easy fix. Mine has been screwed up for years with no idea how to get it fixed. My station has no pressure or humidity sensors or any data sent for these, but everyone has the worst data shown ever.
Station ID cw8399 if anyone wants to look
CWOP: CW8399
KNVNORTH32
Weather Wizard III, wired
Homebuilt DFARS
Weather Link 5.9.0, serial version
Logitech 9000PRO Webcam
« Reply #5 on: August 19, 2020, 07:08:59 AM »
I think you are about 10 years overdue for a station upgrade out of that Weather Wizard III.
There is nothing to fix. Literally with no humidity and no pressure sensor. The sensors that you do have...well eh.. Ummm... yeah the whole thing needs to go into a museum. You darn squeezed all that it had out and you got your money's worth out of that station.
Time for a new station bud. A Davis VP2 is going to make a dent in your wallet, but you could also get an Ambient or Ecowitt and end up quite happy for a more modest cost. Let us know if you need more help selecting the right system as there are many options.
« Last Edit: August 19, 2020, 07:33:10 AM by galfert »
Offline GreyOwl
« Reply #6 on: August 19, 2020, 01:43:53 PM »
Yeah I know it’s old but at my age and length of time planned in this location, a new one is not in the picture. It used to be fine until some update along the way added out of this world numbers to the mix.
If necessary I will just quit uploading and use it for my info only.
CWOP: CW8399
KNVNORTH32
Homebuilt DFARS
« Reply #7 on: August 19, 2020, 02:38:05 PM »
For $169 you can have a decent weather station with the all the basic set of sensors. It is easy to install because it is wireless. It will upload to Weather Underground and to a few more services. The station is also expandable so you can add extra sensors and even displays which you can do later. You can also add software to allow you to upload to more online services. Even if you later move it shouldn't be that difficult to take it with you.
Ecowitt GW1002 $169 (and there is currently a 5% discount on top of this)
https://www.amazon.com/ECOWITT-Wireless-Anemometer-Self-Emptying-Collector/dp/B07YB6WZNH/
