Author Topic: WeeWx and Pi  (Read 2862 times)
Offline rlmarcum22
    • East-Central Kentucky Weather
Re: WeeWx and Pi
« Reply #25 on: August 16, 2020, 06:16:12 PM »
I got the interceptor.py working as to where when it’s running in a terminal window the data it updates is current and accurate from my ws! I just have to figure out how to connect this to weewx, I can’t find the interpreter section in the config document!
Re: WeeWx and Pi
« Reply #26 on: August 16, 2020, 09:29:36 PM »
There are two lines to edit I believe.
You need:
[Station]
station_type = Interceptor
...and a bit lower down you need:
[Interceptor]
device_type = ecowitt-client
...but there is a lot more you should configure if you just read the weewx.conf file you'll notice that there are plenty of other things to fill out...especially in the [Station] section. It isn't a requirement for it to work ....but you'll want to do thing like Lat/Long, elevation...etc.
« Last Edit: August 16, 2020, 09:31:58 PM by galfert »
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #27 on: August 16, 2020, 09:59:23 PM »
It made me do latitude and longitude and location when I first set it up, but I will look right now.  Thanks!
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #28 on: August 16, 2020, 10:01:25 PM »
Every time I try to open and edit the file it won’t allow it?
Offline Storm017
Re: WeeWx and Pi
« Reply #29 on: August 16, 2020, 10:10:29 PM »
sudo nano /home/weewx/weewx.conf
or
sudo nano /etc/weewx/weewx.conf
Use one or the other depending what method of installation was used.
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #30 on: August 16, 2020, 10:25:29 PM »
I’m sorry for all this needed help but someone recommended I try thins one on the weewx forums. https://github.com/gjr80/weewx-gw1000  I got down to the part where i’m supposed to copy the file gw1000.py to the $BIN_ROOT/user directory but when i run the command it says cp: cannot create regular file ‘/user’ :Permission denied?
Offline Storm017
Re: WeeWx and Pi
« Reply #31 on: August 16, 2020, 10:28:33 PM »
You don't have permission to write to that directory. What you need to add is "sudo" in front of command.
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #32 on: August 16, 2020, 10:29:06 PM »
Ok thanks! I’m sorry, i’m new to all this stuff!
Offline Storm017
Re: WeeWx and Pi
« Reply #33 on: August 16, 2020, 10:32:53 PM »
No problem. So it worked? Believe me, I'm still learning Linux.
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #34 on: August 16, 2020, 10:33:28 PM »
I haven’t tried yet, i’m taking a break from it from now!
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #35 on: August 17, 2020, 01:05:05 AM »
ok so it’s going good until i got to step five. i’m supposed to input PYTHONPATH=/etc/weewx/bin python -m user.gw1000 —test-driver. It then says no module named user.gw1000!
Offline KD7GFL
Re: WeeWx and Pi
« Reply #36 on: August 17, 2020, 01:15:35 AM »
Try one of these:
PYTHONPATH=/etc/weewx/bin python3 -m user.gw1000 --test-driver
PYTHONPATH=/usr/share/weewx python3 -m user.gw1000 --test-driver
Somewhere below that I recall it said to add a 2 or 3 depending on what vers of python you are running.
« Last Edit: August 17, 2020, 01:19:06 AM by KD7GFL »
CWOP: KD7GFL (AV640)
WU: KMOAUXVA6
Ambient Weather: KD7GFL
Equipment: GW1000, WS-68, WH40 (w/WH65 Funnel for improved accuracy), WH32-EP (Davis 7714), WH-31 X 2, WH-32, WH-57, HP2551-C, and an Ambient WeatherBridge.
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #37 on: August 17, 2020, 01:17:23 AM »
now it says no module named user
Offline KD7GFL
Re: WeeWx and Pi
« Reply #38 on: August 17, 2020, 01:23:48 AM »
Did you try both?  This is what worked for me:
WU: KMOAUXVA6
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #39 on: August 17, 2020, 02:49:46 PM »
Ok so i’ve finished all this now and got down to step seven where i can run weewx directly and i put in the command and now nothing is happening? What did i do wrong? My gw1000 was sending data to to my pi but now weewx isn’t working?
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #40 on: August 17, 2020, 02:49:56 PM »
Offline waiukuweather
Re: WeeWx and Pi
« Reply #41 on: August 17, 2020, 03:03:08 PM »
why not use consolewd like you were?
much easier to setup
Offline gjr80
Re: WeeWx and Pi
« Reply #42 on: August 17, 2020, 04:44:58 PM »
Can’t comment on the ease or otherwise of setup of consolewd but when setting up WeeWX it does help if the commands are entered as per the instructions:
https://groups.google.com/g/weewx-user/c/YJ2_-rKdcXA
Gary
Offline rlmarcum22
Re: WeeWx and Pi
« Reply #43 on: August 17, 2020, 04:45:54 PM »
I figured it out! Thanks!
