Author Topic: Trying to install GW1000 API Driver  (Read 568 times)
Offline KD7GFL
« on: August 05, 2020, 08:29:23 PM »
Trying to install the GW1000 API driver according to the instructions:
https://github.com/gjr80/weewx-gw1000
I am stuck on Step 5.  When I try to test the driver using the provided Command it doesn't work.  Any ideas on what I need to do?
CWOP: KD7GFL (AV640)
WU: KMOAUXVA6
Ambient Weather: KD7GFL
Equipment: GW1000, WS-68, WH40 w/WH65 funnel (for testing), WH32-EP (Davis 7714), WH-31, WH-32, WH-57, HP2551-C, and an Ambient WeatherBridge.
Offline KD7GFL
Re: Trying to install GW1000 API Driver
« Reply #1 on: August 16, 2020, 07:32:11 PM »
Ok so after unsuccessfully trying to get WeeWX installed using the GW1000 API driver a few days ago and not getting any feedback, I "cleaned the chalkboard" so to speak this afternoon and reformatted my SD card and started from scratch.  I didn't figure out if I had done something wrong, missed a step, or a combination of both, but this time I think I got it working.
I installed the Apache Web server as directed in the WeeWX guide and I am able to view my data which updates every 5 minutes (have to do a manual refresh.)
Is there any other way to verify WeeWX is working properly using the GW1000 driver?
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
« Last Edit: August 16, 2020, 07:35:14 PM by KD7GFL »
WU: KMOAUXVA6
Offline Storm017
« Reply #2 on: August 16, 2020, 09:33:48 PM »
Try the following:
sudo weewxd /home/weewx/weewx.conf
or
sudo weewxd /etc/weewx/weewx.conf
Use one or the other depending what method of installation was used.  Also you might need to be in the directory that "weewxd" is installed to execute the command.
Offline KD7GFL
« Reply #3 on: August 16, 2020, 09:55:02 PM »
I guess this is a good sign:
WU: KMOAUXVA6
Offline Storm017
« Reply #4 on: August 16, 2020, 10:02:01 PM »
It does look like a good sign.  Does the your data match up?
Offline KD7GFL
« Reply #5 on: August 16, 2020, 10:14:48 PM »
It does I think except for lightning data.  I can see lightning data when it loops, but it did not populate to the browser.  Is that an issue?
WU: KMOAUXVA6
Offline Storm017
« Reply #6 on: August 16, 2020, 10:25:25 PM »
First I don't use this driver. All I can say is the mapping correct in weewx.conf file? Is your seasons skin pulling the lightning  data from the database?  You can post your question also @ https://groups.google.com/forum/#!forum/weewx-user
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« Reply #7 on: August 17, 2020, 07:54:07 PM »
Congratulations. It looks like it's working for you.
I don't have the lightning detector so I know little about it. But it may be that the Seasons template has not yet been modified for lightning.
And BTW, you don't have to install Apache to see the Seasons page.
